Postgres or MariaDb
- karweru
- DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Postgres or MariaDb
Dear Friends,
I have been using Sqlite for many years now. However, I have an urgent need to move to PostGres or MariaDb and is desperate for a step-by-step guidance of how to do it...a working sample i can compile from the IDE would really be useful.
I'm getting an error when i try the sample for postgres
I cant find examples for MariaDb
Kindly assist.
Kindly assist.
Kind regards,
Gilbert.
Gilbert.
- dragancesu
Re: Postgres or MariaDb
I tried PostgreSQL and Oracle, with failed, mysql works great.
examples are \ hmgx.x.x \ Samples \ HCFL \ sql \ mysql
1.install mysql ( recommendation 5.5 or 5.6 )
2 In the program folder to copy libmysql.dll from mysql \ bin folder
3 to do compilation
MariaDB do not use, but it should be similar
3 to do compilation
Hi Gilbert,
I work with MySQL/MariaDB and it works perfect.
Your postgres error-file do not show exact error message?
- karweru
Thank you Serge for your quick reply. The error I'm getting for postgress is;
I have also downloaded mariadb, will try the steps above. A quick question though,...does it mean one has to supply libmysql.dll to clients with the applications executable?Harbour 3.2.0dev (r1601151502)
C:\hmg.3.4.3\SAMPLES\HFCL\SQL\POSTGRESQL_1\demo.prg(85) Error E0030 Syntax error "syntax error at '.'"
C:\hmg.3.4.3\SAMPLES\HFCL\SQL\POSTGRESQL_1\demo.prg(91) Error E0030 Syntax error "syntax error at '.'"
2 errors
No code generated.
hbmk2[demo]: Error: Running Harbour compiler (embedded). 1
(C:\hmg.3.4.3\harbour\bin\harbour.exe) -n2 C:\hmg.3.4.3\SAMPLES\HFCL\SQL\POSTGRESQL_1\demo.prg -DHBMK_HAS_HMG32=1 -q -DHBMK_HAS_DEMO=1 -oC:\Users\gkarweru\AppData\Local\Temp\hbmk_1urbk2.dir\ -iC:\hmg.3.4.3\harbour\include -i. -iC:\hmg.3.4.3\include
Kind regards,
Gilbert.
Gilbert.
MariaDB is good and widely used.
Yes, we need libmysql.dll at runtime.
As Rathi said: libmysql.dll is indeed needed.
This could be a problem when you want to remote-distribute your application. I used to check with a small program which checks if it present. If not I copy it.
- dragancesu
I do not know how many know MySQL,
I recommend to start the portable version, like http://www.uniformserver.com/ZeroXI_doc ... guide.html
(new version include module MariaDB)
It is portable Web server but has more or can only be started MySQL which is enough and make a basic database administration and users
For MySQL to recommend databse manager https://www.heidisql.com/
It's can be install or use portable
Hint for first use, start database, create user, then create database
- karweru
Thanks everyone,
Is there away (or even an RDBMS) that one can connect to from a HMG application, as easily as with sqlite, without the need to supply libraries beside the executable? Sorry, too many questions
Kind regards,
Gilbert.
Gilbert.
