Postgres or MariaDb
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Postgres or MariaDb
Post by karweru »
Dear Friends,
I have been using Sqlite for many years now. However, I have an urgent need to move to PostGres or MariaDb and is desperate for a step-by-step guidance of how to do it...a working sample i can compile from the IDE would really be useful.
I'm getting an error when i try the sample for postgres
I cant find examples for MariaDb
Kindly assist.
Kind regards,
Gilbert.
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Postgres or MariaDb
Post by dragancesu »
I tried PostgreSQL and Oracle, with failed, mysql works great.
examples are \ hmgx.x.x \ Samples \ HCFL \ sql \ mysql
1.install mysql ( recommendation 5.5 or 5.6 )
2 In the program folder to copy libmysql.dll from mysql \ bin folder
3 to do compilation
MariaDB do not use, but it should be similar
Hi Gilbert,
I work with MySQL/MariaDB and it works perfect.
Your postgres error-file do not show exact error message?
karweru
Post by karweru »
Thank you Serge for your quick reply. The error I'm getting for postgress is;
Harbour 3.2.0dev (r1601151502)
C:\hmg.3.4.3\SAMPLES\HFCL\SQL\POSTGRESQL_1\demo.prg(85) Error E0030 Syntax error "syntax error at '.'"
C:\hmg.3.4.3\SAMPLES\HFCL\SQL\POSTGRESQL_1\demo.prg(91) Error E0030 Syntax error "syntax error at '.'"
2 errors
No code generated.
hbmk2[demo]: Error: Running Harbour compiler (embedded). 1
(C:\hmg.3.4.3\harbour\bin\harbour.exe) -n2 C:\hmg.3.4.3\SAMPLES\HFCL\SQL\POSTGRESQL_1\demo.prg -DHBMK_HAS_HMG32=1 -q -DHBMK_HAS_DEMO=1 -oC:\Users\gkarweru\AppData\Local\Temp\hbmk_1urbk2.dir\ -iC:\hmg.3.4.3\harbour\include -i. -iC:\hmg.3.4.3\include
I have also downloaded mariadb, will try the steps above. A quick question though,...does it mean one has to supply libmysql.dll to clients with the applications executable?
Kind regards,
Gilbert.
MariaDB is good and widely used.
Yes, we need libmysql.dll at runtime.
As Rathi said: libmysql.dll is indeed needed.
This could be a problem when you want to remote-distribute your application. I used to check with a small program which checks if it present. If not I copy it.
dragancesu
I do not know how many know MySQL,
I recommend to start the portable version, like http://www.uniformserver.com/ZeroXI_doc ... guide.html
(new version include module MariaDB)
It is portable Web server but has more or can only be started MySQL which is enough and make a basic database administration and users
For MySQL to recommend databse manager https://www.heidisql.com/
It's can be install or use portable
Hint for first use, start database, create user, then create database
karweru
Post by karweru »
Thanks everyone,
Is there away (or even an RDBMS) that one can connect to from a HMG application, as easily as with sqlite, without the need to supply libraries beside the executable? Sorry, too many questions :(
Kind regards,
Gilbert.
