ComboSearchGrid
Re: ComboSearchGrid
Hola AidTIC
Tienes algún ejemplo funcional de tu problema ?
AidTIC
Re: ComboSearchGrid
Post by AidTIC »
Hola andyglezl,
esta es la ventana.
Y cuando le doy valor a "DEFINE COMBOSEARCHGRID NEMP" en la funcion "_CSGItemSelected" con " SetProperty( cParentName, "NEMP" , "VALUE", cListBanEmp ), me hace búsqueda del dato en "COMBOSEARCHGRID" sin haberse salido del primero.
Si os dais cuenta en la imagen el primer combosearchgrid aun esta abierto.
El segundo funciona hasta que le doy a enter que se sale de la aplicación sin mas.
Hello andyglezl,
This is the window.
And when I give value to "DEFINE COMBOSEARCHGRID NEMP" in the function "_CSGItemSelected" with "SetProperty (cParentName," NEMP "," VALUE ", cListBanEmp), I search the data in" COMBOSEARCHGRID "without having left the first one.
If you notice in the image the first combosearchgrid is still open.
The second works until I give to enter that it leaves the application without more.
Function Gestion_Bancos
aBancos := BancosOpen()
    DEFINE WINDOW Win_Ban ;
  	AT 10, 20                 ;
                    WIDTH   800 ;
				    HEIGHT  600 ;
					TITLE 'Mantenimiento de Bancos' ;
                    modal
       ON KEY ESCAPE ACTION ThisWindow.Release()
      DEFINE LABEL label01
             ROW    11
             COL    10
             WIDTH  80
             VALUE  'Banco'
             FONTNAME fNAME
             FONTSIZE fSIZE
             TOOLTIP ""
             FONTBOLD .T.
             FONTCOLOR BLUE
      END LABEL
      DEFINE COMBOSEARCHGRID NBAN
             ROW      10
             COL      100
             WIDTH   500
		     ITEMS   aBancos
		     TOOLTIP ""
             FONTBOLD .F.
			 FONTNAME  fNAME
             FONTSIZE  fSIZE
			 FONTCOLOR BLACK
			 HEADERS { 'Codigo' , 'Banco' , 'Empresa' }
             WIDTHS  {    150    ,   200   ,    300    }
             JUSTIFY {     0    ,     0   ,      0    }
			 ONENTER Win_Ban.tBanDes.SetFocus
		     anywheresearch .t.
             showheaders .t.
      END COMBOSEARCHGRID
      DEFINE LABEL label02
             ROW   41
             COL   10
             WIDTH 150
             VALUE 'Descripcion'
		     FONTNAME fNAME
             FONTSIZE fSIZE
             TOOLTIP ""
             FONTBOLD .T.
             FONTCOLOR BLUE
      END LABEL
      DEFINE TEXTBOX tBanDes
             ROW    40
             COL    170
             WIDTH  360
		     FONTNAME fNAME
             FONTSIZE fSIZE
			 ONENTER Win_Ban.NEMP.SetFocus
             TOOLTIP ""
             FONTBOLD .F.
      END TEXTBOX
	  DEFINE LABEL label03
             ROW   71
             COL   10
             WIDTH 150
             VALUE 'Empresa'
		     FONTNAME fNAME
             FONTSIZE fSIZE
             TOOLTIP ""
             FONTBOLD .T.
             FONTCOLOR BLUE
      END LABEL
             ROW      70
             COL      100
             WIDTH   500
		     ITEMS   aEmpresas
		     TOOLTIP ""
             FONTBOLD .F.
			 FONTNAME  fNAME
             FONTSIZE  fSIZE
			 FONTCOLOR BLACK
			 HEADERS { 'Codigo' , 'Empresa' }
             WIDTHS  {   50  ,   300  }
             JUSTIFY {     0  ,     0  }
			 ONENTER Win_Ban.tBanCue.SetFocus
		     anywheresearch .t.
             showheaders .t.
      END COMBOSEARCHGRID
	  DEFINE LABEL label04
             ROW   101
             COL   10
             WIDTH 150
             VALUE 'Cuneta Contable'
		     FONTNAME fNAME
             FONTSIZE fSIZE
             TOOLTIP ""
             FONTBOLD .T.
             FONTCOLOR BLUE
      END LABEL
      DEFINE TEXTBOX tBanCue
             ROW    100
             COL    170
             WIDTH  360
		     FONTNAME fNAME
             FONTSIZE fSIZE
			 ONENTER Win_Ban.Btn_Guardar.SetFocus
             TOOLTIP ""
             FONTBOLD .F.
      END TEXTBOX
	  DEFINE GRID Grid_Banc
        ROW    130
        COL    10
        WIDTH  740
		HEIGHT 330
        VALUE Nil
        HEADERS {'Cod.Comun' , 'Cod.Propio' , 'D/H' , 'Concepto' , 'NºAsiento'}
        WIDTHS  {     60     ,      60      ,   40  ,     200    ,    60      }
	    JUSTIFY { GRID_JTFY_RIGHT, GRID_JTFY_RIGHT , GRID_JTFY_CENTER , GRID_JTFY_LEFT, GRID_JTFY_RIGHT}
	    //DYNAMICFORECOLOR { fColor  , fColor ,  fColor   , fColor   , fColor  ,    fColor,    fColor  ,  fColor ,  fColor   , fColor      }
	    //DYNAMICBACKCOLOR { bColor  , bColor ,  bColor   , bColor   , bColor  ,    bColor  ,  bColor  , bColor ,  bColor   , bColor      }
        FONTNAME fNAME
        FONTSIZE fSIZE
		FONTCOLOR  BLACK
        TOOLTIP ""
		EDITOPTION GRID_EDIT_DEFAULT
      END GRID
	  DEFINE BUTTON Btn_Guardar
         ROW 490
         COL 70
		   CAPTION '&Guardar'
			ACTION  Guardar_Emp ()
			WIDTH 120
         HEIGHT 27
		   FONTNAME fNAME
         FONTSIZE fSIZE
         TOOLTIP "Guardar Cliente"
	 END BUTTON
     DEFINE BUTTON Btn_Eliminar
         ROW 490
         COL 230
		 CAPTION '&Eliminar'
		 ACTION Eliminar_Emp ()
		 WIDTH 120
         HEIGHT 27
		 FONTNAME fNAME
         FONTSIZE fSIZE
         TOOLTIP "Eliminar Cliente"
	 END BUTTON
    DEFINE BUTTON Btn_Cancelar
         ROW 490
         COL 390
		 CAPTION '&Cancelar'
		 ACTION Win_Ban.Release
		 WIDTH 120
         HEIGHT 27
		 FONTNAME fNAME
         FONTSIZE fSIZE
         TOOLTIP "Cancelar Registro"
	END BUTTON
	DEFINE STATUSBAR FONT fNAME SIZE 10
    	   STATUSITEM "Consolidador Extractos Bancarios (c) 2017 Skydone Solutions, S.L." STYLE RAISED
           KEYBOARD
	       DATE
		   CLOCK WIDTH 100
	END STATUSBAR
   Win_Ban.CENTER
   Win_Ban.ACTIVATE
STATIC PROC _CSGItemSelected( cParentName, cTxBName, lTab )
   local lOk := .f.
   local i := 0
   local j := 0
   local cQStr := ''
   if GetProperty( ThisWindow.Name, "_csList", "VALUE" ) > 0
      nListValue  := GetProperty( ThisWindow.Name, '_csList', "VALUE" )
	  Do Case
	     Case cParentName = "Win_Ban" .and. cTxBName = "NBAN"
  MSGINFO("1" , 415)
			//	MSGDEBUG(_HMG_CSG_aTable)
	          	  cod_emp     := VAL(_HMG_CSG_aTable [ nListValue, 4 ])
                  cListItem   := _HMG_CSG_aTable [ nListValue, 1 ]
				  cod_ban     := _HMG_CSG_aTable [ nListValue, 1 ]
	              cListBanDes := _HMG_CSG_aTable[ nListValue, 2 ]
	              cListBanEmp := _HMG_CSG_aTable[ nListValue, 3 ]
	              cListBanCue := _HMG_CSG_aTable[ nListValue, 5 ]
	              aLineData   := _HMG_CSG_aTable[ nListValue ]
                  cQStr := 'update itemselected set tblrowid = ( select rowid from ' + cTblName + ' where '
                  for i := 1 to _HMG_CSG_nCols
                     cQStr := cQStr + 'col' + alltrim( str( i ) ) + ' = ' + _HMG_CSG_C2SQL( aLineData[ i ] )
                     if i < _HMG_CSG_nCols
                        cQStr := cQStr + ' and '
                  next i
                  cQStr := cQStr + ')'
	             //  msginfo(cQStr)
                  lOk := _HMG_CSG_MiscSQL( _HMG_CSG_DBO, cQStr )
                  if .not. lOk
                     msgstop( 'Error in ComboSearchGrid!' )
                     return nil
 //               MSGINFO(cListProGra)
                  SetProperty( cParentName, cTxBName  , "VALUE", cListItem )
	              SetProperty( cParentName, "tBanDes" , "VALUE", cListBanDes )
	              SetProperty( cParentName, "tBanCue" , "VALUE", cListBanCue )
	              mostrar_opciones ()
                  SetProperty(cParentName,cTxBName,"CARETPOS",;
                                LEN( cListItem ) )
                  DoMethod( ThisWindow.Name, "Release" )
                  if pcount() == 3
                     if lTab
                        _Pushkey(VK_TAB)
		 Case cParentName = "Win_Ban" .and. cTxBName = "NEMP"
	          	  cod_emp     := VAL(_HMG_CSG_aTable [ nListValue, 1 ])
                  cListItem   := _HMG_CSG_aTable [ nListValue, 2 ]
                  next i
                  if .not. lOk
                     return nil
                                LEN( cListItem ) )
                  if pcount() == 3
                     if lTab
                        _Pushkey(VK_TAB)
         OtherWise
            	  cListPATCU  := _HMG_CSG_aTable[ nListValue, 3 ]
            	  cListPATDI  := _HMG_CSG_aTable[ nListValue, 4 ]
            	  cListPATEN  := _HMG_CSG_aTable[ nListValue, 5 ]
            	  cListProGra := _HMG_CSG_aTable[ nListValue, 6 ]
            	//MSGINFO(cListProGra , Valtype (cListProGra))
                  next i
                  if .not. lOk
                     return nil
                  SetProperty( cParentName, cTxBName, "VALUE", cListItem )
            	  SetProperty( cParentName, "tCuenta", "VALUE", cListPATCU )
            	  SetProperty( cParentName, "tDiario", "VALUE", cListPATDI )
            	  SetProperty( cParentName, "tElntace", "VALUE", cListPATEN )
            	  SetProperty( cParentName, "rProgram", "VALUE", VAL(cListProGra ))
            	   mostrar_bancos ()
                                LEN( cListItem ) )
                  if pcount() == 3
                     if lTab
                        _Pushkey(VK_TAB)
       EndCase
    //  ( GetProperty( ThisWindow.Name, "_cstext", "VALUE" ) )
	  SetProperty( cParentName, cTxBName, "VALUE", GetProperty( ThisWindow.Name, "_cstext", "VALUE" ) )
	//  SetProperty( cParentName, tEnlace, "VALUE", GetProperty( ThisWindow.Name, "_cstext", "VALUE" ) )
      if pcount() == 3
         if lTab
            _Pushkey(VK_TAB)
RETURN // _CSGItemSelected()
Skydone Solutions
www.skydone.com
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: ComboSearchGrid
Post by dragancesu »
If I understood correctly
You have data (DBF or MySQL) and you want to quickly load on it
I do not understand what the content of the field is from the program, but for the field character can be TEXTBOX and ON ENTER, when the contents change the filter is made and it works
Can you show/upload little data, it's hard to see something from the blank screen
AidTIC
Re: ComboSearchGrid
Post by AidTIC »
A ver si con este video se ve mas claro el problema.
y este es el error, porque coge la anterior array
Let's see if the problem is clearer with this video.
and this is the error, because it takes the previous array
Date:07-02-2019 Time: 17:29:41
Error BASE/1132 Bound error: array access
Called from _CSGITEMSELECTED(417)
Called from (b)CREATECSGRID(295)
Called from EVENTS(828)
Called from DOMESSAGELOOP(0)
Called from CREATECSGRID(333)
Called from (b)_DEFINECOMBOSEARCHGRID(187)
Called from EVENTS(1861)
Called from SETWINDOWTEXT(0)
Called from _SETVALUE(536)
Called from SETPROPERTY(7931)
Called from _CSGITEMSELECTED(444)
Called from (b)CREATECSGRID(319)
Called from EVENTS(3244)
Called from DOMETHOD(9003)
Called from GESTION_BANCOS(196)
Called from (b)MAIN(154)
Called from EVENTS(1756)
Called from MAIN(300)
Skydone Solutions
www.skydone.com
Re: ComboSearchGrid
No entendí, en el combo "BANCO" estás buscando la "Empresa" ???
y después de seleccionarla, te pasas al otro combo para seleccionarla de nuevo ???
Una pregunta:
Cuantos registros de Bancos y de Empresas tienes como para no utilizar
un ComboBox normal. (Que pienso yo, sería más rápido)
I did not understand, in the "BANK" combo are you looking for the "Company" ???
and after selecting it, you go to the other combo to select it again ???
A question:
How many records of Banks and Companies do you have so as not to use
a normal ComboBox (What I think, it would be faster)
tonton2
Re: ComboSearchGrid
Post by tonton2 »
Bonjour,
voici un exemple de cherche client,j’espère que cela
Search_Customer.rar
(21.42 KiB) Downloaded 310 times
va vous aider
L'Algerie vous salut
Y.TABET
tonton2
Re: ComboSearchGrid
Post by tonton2 »
Y.TABET
AidTIC
Re: ComboSearchGrid
Post by AidTIC »
a ver andyglezl , si se preve que cuando se trabaje con el , tenga mas de 100 empresa y a una media de 4 o 5 bancos por empresa.
Lo que estoy intentando es que cuando den de alta una cuenta de banco, puedan seleccionar a que empresa corresponde, peo si existe, que me la muestre. Por eso estoy intentando gastar 2 ComboSearchGrid. Cuando el primero detecta que existe el banco, muestra entre otros datos que empresa esta asignada, con intención de poder modificar el resto de datos.
tonton2, gracias, pero ya lo estuve viendo, pero me ese ejemplo no me vale, pues solo gasta un ComboSearchGrid.
to see andyglezl, if it is expected that when you work with it, you have more than 100 companies and an average of 4 or 5 banks per company.
What I am trying to do is that when you register a bank account, you can select which company it corresponds to, if it exists, show it to me. That's why I'm trying to spend 2 ComboSearchGrid. When the first detects that the bank exists, it shows, among other data, which company is assigned, with the intention of being able to modify the rest of the data.
  tonton2, thanks, but I've already seen it, but that example is not worth it, because it only spends a ComboSearchGrid.
Skydone Solutions
www.skydone.com
Re: ComboSearchGrid
Es solo una forma (claro que hay muchas) de como yo hago un busqueda...
Tengo 2 TextBox y 2 ComboBox
Si encuentro el código, despliego la informacion, pero a la
vez lleno los 2 Combobox, uno con los registros que contengan
lo que teclee en el código ( "1254" ), y el otro con los registros
que contengan los nombres iguales ( "OBADIA" ) al registro encontrado.
Y a la vez, en el segundo TextBox puedo hacer cualquier busqueda en el NOMBRE.
(Esta busqueda la hago en un DBF con 20,000 registros.)
It's just one way (of course there are many) of how I do a search ...
I have 2 TextBox and 2 ComboBox
If I find the code, I display the information, but to the
once filled the 2 Combobox, one with the records that contain
what you type in the code ("1254"), and the other with the records
that contain the same names ("OBADIA") to the found record.
And at the same time, in the second TextBox I can do any search in the NAME.
(This search is done in a DBF with 20,000 records.)
dragancesu
Re: ComboSearchGrid
Nice, what program do you use to make this video?
