ComboSearchGrid
Re: ComboSearchGrid
Hola AidTIC
Tienes algún ejemplo funcional de tu problema ?
Re: ComboSearchGrid
Hola andyglezl,
esta es la ventana.
Y cuando le doy valor a "DEFINE COMBOSEARCHGRID NEMP" en la funcion "_CSGItemSelected" con " SetProperty( cParentName, "NEMP" , "VALUE", cListBanEmp ), me hace búsqueda del dato en "COMBOSEARCHGRID" sin haberse salido del primero.
Si os dais cuenta en la imagen el primer combosearchgrid aun esta abierto.
El segundo funciona hasta que le doy a enter que se sale de la aplicación sin mas.
Hello andyglezl,
This is the window.
And when I give value to "DEFINE COMBOSEARCHGRID NEMP" in the function "_CSGItemSelected" with "SetProperty (cParentName," NEMP "," VALUE ", cListBanEmp), I search the data in" COMBOSEARCHGRID "without having left the first one.
If you notice in the image the first combosearchgrid is still open.
The second works until I give to enter that it leaves the application without more.
esta es la ventana.
Hello andyglezl,
This is the window.
Function Gestion_Bancos
aBancos := BancosOpen()
DEFINE WINDOW Win_Ban ;
AT 10, 20 ;
WIDTH 800 ;
HEIGHT 600 ;
TITLE 'Mantenimiento de Bancos' ;
modal
ON KEY ESCAPE ACTION ThisWindow.Release()
DEFINE LABEL label01
ROW 11
COL 10
WIDTH 80
VALUE 'Banco'
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP ""
FONTBOLD .T.
FONTCOLOR BLUE
END LABEL
DEFINE COMBOSEARCHGRID NBAN
ROW 10
COL 100
WIDTH 500
ITEMS aBancos
TOOLTIP ""
FONTBOLD .F.
FONTNAME fNAME
FONTSIZE fSIZE
FONTCOLOR BLACK
HEADERS { 'Codigo' , 'Banco' , 'Empresa' }
WIDTHS { 150 , 200 , 300 }
JUSTIFY { 0 , 0 , 0 }
ONENTER Win_Ban.tBanDes.SetFocus
anywheresearch .t.
showheaders .t.
END COMBOSEARCHGRID
DEFINE LABEL label02
ROW 41
COL 10
WIDTH 150
VALUE 'Descripcion'
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP ""
FONTBOLD .T.
FONTCOLOR BLUE
END LABEL
DEFINE TEXTBOX tBanDes
ROW 40
COL 170
WIDTH 360
FONTNAME fNAME
FONTSIZE fSIZE
ONENTER Win_Ban.NEMP.SetFocus
TOOLTIP ""
FONTBOLD .F.
END TEXTBOX
DEFINE LABEL label03
ROW 71
COL 10
WIDTH 150
VALUE 'Empresa'
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP ""
FONTBOLD .T.
FONTCOLOR BLUE
END LABEL
ROW 70
COL 100
WIDTH 500
ITEMS aEmpresas
TOOLTIP ""
FONTBOLD .F.
FONTNAME fNAME
FONTSIZE fSIZE
FONTCOLOR BLACK
HEADERS { 'Codigo' , 'Empresa' }
WIDTHS { 50 , 300 }
JUSTIFY { 0 , 0 }
ONENTER Win_Ban.tBanCue.SetFocus
anywheresearch .t.
showheaders .t.
END COMBOSEARCHGRID
DEFINE LABEL label04
ROW 101
COL 10
WIDTH 150
VALUE 'Cuneta Contable'
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP ""
FONTBOLD .T.
FONTCOLOR BLUE
END LABEL
DEFINE TEXTBOX tBanCue
ROW 100
COL 170
WIDTH 360
FONTNAME fNAME
FONTSIZE fSIZE
ONENTER Win_Ban.Btn_Guardar.SetFocus
TOOLTIP ""
FONTBOLD .F.
END TEXTBOX
DEFINE GRID Grid_Banc
ROW 130
COL 10
WIDTH 740
HEIGHT 330
VALUE Nil
HEADERS {'Cod.Comun' , 'Cod.Propio' , 'D/H' , 'Concepto' , 'NºAsiento'}
WIDTHS { 60 , 60 , 40 , 200 , 60 }
JUSTIFY { GRID_JTFY_RIGHT, GRID_JTFY_RIGHT , GRID_JTFY_CENTER , GRID_JTFY_LEFT, GRID_JTFY_RIGHT}
//DYNAMICFORECOLOR { fColor , fColor , fColor , fColor , fColor , fColor, fColor , fColor , fColor , fColor }
//DYNAMICBACKCOLOR { bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor }
FONTNAME fNAME
FONTSIZE fSIZE
FONTCOLOR BLACK
TOOLTIP ""
EDITOPTION GRID_EDIT_DEFAULT
END GRID
DEFINE BUTTON Btn_Guardar
ROW 490
COL 70
CAPTION '&Guardar'
ACTION Guardar_Emp ()
WIDTH 120
HEIGHT 27
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP "Guardar Cliente"
END BUTTON
DEFINE BUTTON Btn_Eliminar
ROW 490
COL 230
CAPTION '&Eliminar'
ACTION Eliminar_Emp ()
WIDTH 120
HEIGHT 27
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP "Eliminar Cliente"
END BUTTON
DEFINE BUTTON Btn_Cancelar
ROW 490
COL 390
CAPTION '&Cancelar'
ACTION Win_Ban.Release
WIDTH 120
HEIGHT 27
FONTNAME fNAME
FONTSIZE fSIZE
TOOLTIP "Cancelar Registro"
END BUTTON
DEFINE STATUSBAR FONT fNAME SIZE 10
STATUSITEM "Consolidador Extractos Bancarios (c) 2017 Skydone Solutions, S.L." STYLE RAISED
KEYBOARD
DATE
CLOCK WIDTH 100
END STATUSBAR
Win_Ban.CENTER
Win_Ban.ACTIVATE
STATIC PROC _CSGItemSelected( cParentName, cTxBName, lTab )
local lOk := .f.
local i := 0
local j := 0
local cQStr := ''
if GetProperty( ThisWindow.Name, "_csList", "VALUE" ) > 0
nListValue := GetProperty( ThisWindow.Name, '_csList', "VALUE" )
Do Case
Case cParentName = "Win_Ban" .and. cTxBName = "NBAN"
MSGINFO("1" , 415)
// MSGDEBUG(_HMG_CSG_aTable)
cod_emp := VAL(_HMG_CSG_aTable [ nListValue, 4 ])
cListItem := _HMG_CSG_aTable [ nListValue, 1 ]
cod_ban := _HMG_CSG_aTable [ nListValue, 1 ]
cListBanDes := _HMG_CSG_aTable[ nListValue, 2 ]
cListBanEmp := _HMG_CSG_aTable[ nListValue, 3 ]
cListBanCue := _HMG_CSG_aTable[ nListValue, 5 ]
aLineData := _HMG_CSG_aTable[ nListValue ]
cQStr := 'update itemselected set tblrowid = ( select rowid from ' + cTblName + ' where '
for i := 1 to _HMG_CSG_nCols
cQStr := cQStr + 'col' + alltrim( str( i ) ) + ' = ' + _HMG_CSG_C2SQL( aLineData[ i ] )
if i < _HMG_CSG_nCols
cQStr := cQStr + ' and '
next i
cQStr := cQStr + ')'
// msginfo(cQStr)
lOk := _HMG_CSG_MiscSQL( _HMG_CSG_DBO, cQStr )
if .not. lOk
msgstop( 'Error in ComboSearchGrid!' )
return nil
// MSGINFO(cListProGra)
SetProperty( cParentName, cTxBName , "VALUE", cListItem )
SetProperty( cParentName, "tBanDes" , "VALUE", cListBanDes )
SetProperty( cParentName, "tBanCue" , "VALUE", cListBanCue )
mostrar_opciones ()
SetProperty(cParentName,cTxBName,"CARETPOS",;
LEN( cListItem ) )
DoMethod( ThisWindow.Name, "Release" )
if pcount() == 3
if lTab
_Pushkey(VK_TAB)
Case cParentName = "Win_Ban" .and. cTxBName = "NEMP"
cod_emp := VAL(_HMG_CSG_aTable [ nListValue, 1 ])
cListItem := _HMG_CSG_aTable [ nListValue, 2 ]
next i
if .not. lOk
return nil
LEN( cListItem ) )
if pcount() == 3
if lTab
_Pushkey(VK_TAB)
OtherWise
cListPATCU := _HMG_CSG_aTable[ nListValue, 3 ]
cListPATDI := _HMG_CSG_aTable[ nListValue, 4 ]
cListPATEN := _HMG_CSG_aTable[ nListValue, 5 ]
cListProGra := _HMG_CSG_aTable[ nListValue, 6 ]
//MSGINFO(cListProGra , Valtype (cListProGra))
next i
if .not. lOk
return nil
SetProperty( cParentName, cTxBName, "VALUE", cListItem )
SetProperty( cParentName, "tCuenta", "VALUE", cListPATCU )
SetProperty( cParentName, "tDiario", "VALUE", cListPATDI )
SetProperty( cParentName, "tElntace", "VALUE", cListPATEN )
SetProperty( cParentName, "rProgram", "VALUE", VAL(cListProGra ))
mostrar_bancos ()
LEN( cListItem ) )
if pcount() == 3
if lTab
_Pushkey(VK_TAB)
EndCase
// ( GetProperty( ThisWindow.Name, "_cstext", "VALUE" ) )
SetProperty( cParentName, cTxBName, "VALUE", GetProperty( ThisWindow.Name, "_cstext", "VALUE" ) )
// SetProperty( cParentName, tEnlace, "VALUE", GetProperty( ThisWindow.Name, "_cstext", "VALUE" ) )
if pcount() == 3
if lTab
_Pushkey(VK_TAB)
RETURN // _CSGItemSelected()
- 2019-02-07_9-23-29.jpg (101.46 KiB) Viewed 3755 times
Skydone Solutions
www.skydone.com
www.skydone.com
- dragancesu
Re: ComboSearchGrid
If I understood correctly
You have data (DBF or MySQL) and you want to quickly load on it
I do not understand what the content of the field is from the program, but for the field character can be TEXTBOX and ON ENTER, when the contents change the filter is made and it works
Can you show/upload little data, it's hard to see something from the blank screen
Re: ComboSearchGrid
A ver si con este video se ve mas claro el problema.
y este es el error, porque coge la anterior array
Let's see if the problem is clearer with this video.
and this is the error, because it takes the previous array
Date:07-02-2019 Time: 17:29:41
Error BASE/1132 Bound error: array access
Called from _CSGITEMSELECTED(417)
Called from (b)CREATECSGRID(295)
Called from EVENTS(828)
Called from DOMESSAGELOOP(0)
Called from CREATECSGRID(333)
Called from (b)_DEFINECOMBOSEARCHGRID(187)
Called from EVENTS(1861)
Called from SETWINDOWTEXT(0)
Called from _SETVALUE(536)
Called from SETPROPERTY(7931)
Called from _CSGITEMSELECTED(444)
Called from (b)CREATECSGRID(319)
Called from EVENTS(3244)
Called from DOMETHOD(9003)
Called from GESTION_BANCOS(196)
Called from (b)MAIN(154)
Called from EVENTS(1756)
Called from MAIN(300)
- 2019-02-07_17-47-50.gif (389.01 KiB) Viewed 3721 times
Skydone Solutions
www.skydone.com
www.skydone.com
Re: ComboSearchGrid
No entendí, en el combo "BANCO" estás buscando la "Empresa" ???
y después de seleccionarla, te pasas al otro combo para seleccionarla de nuevo ???
Una pregunta:
Cuantos registros de Bancos y de Empresas tienes como para no utilizar
un ComboBox normal. (Que pienso yo, sería más rápido)
I did not understand, in the "BANK" combo are you looking for the "Company" ???
and after selecting it, you go to the other combo to select it again ???
A question:
How many records of Banks and Companies do you have so as not to use
a normal ComboBox (What I think, it would be faster)
Una pregunta:
A question:
Re: ComboSearchGrid
Bonjour,
voici un exemple de cherche client,j’espère que cela va vous aider
L'Algerie vous salut
Y.TABET
Y.TABET
Re: ComboSearchGrid
Voir aussi dans http://hmgforum.com/viewtopic.php?f=14& ... ice#p43919
Y.TABET
Y.TABET
Re: ComboSearchGrid
a ver andyglezl , si se preve que cuando se trabaje con el , tenga mas de 100 empresa y a una media de 4 o 5 bancos por empresa.
Lo que estoy intentando es que cuando den de alta una cuenta de banco, puedan seleccionar a que empresa corresponde, peo si existe, que me la muestre. Por eso estoy intentando gastar 2 ComboSearchGrid. Cuando el primero detecta que existe el banco, muestra entre otros datos que empresa esta asignada, con intención de poder modificar el resto de datos.
tonton2, gracias, pero ya lo estuve viendo, pero me ese ejemplo no me vale, pues solo gasta un ComboSearchGrid.
to see andyglezl, if it is expected that when you work with it, you have more than 100 companies and an average of 4 or 5 banks per company.
What I am trying to do is that when you register a bank account, you can select which company it corresponds to, if it exists, show it to me. That's why I'm trying to spend 2 ComboSearchGrid. When the first detects that the bank exists, it shows, among other data, which company is assigned, with the intention of being able to modify the rest of the data.
tonton2, thanks, but I've already seen it, but that example is not worth it, because it only spends a ComboSearchGrid.
Skydone Solutions
www.skydone.com
www.skydone.com
Re: ComboSearchGrid
Es solo una forma (claro que hay muchas) de como yo hago un busqueda...
Tengo 2 TextBox y 2 ComboBox
Si encuentro el código, despliego la informacion, pero a la
vez lleno los 2 Combobox, uno con los registros que contengan
lo que teclee en el código ( "1254" ), y el otro con los registros
que contengan los nombres iguales ( "OBADIA" ) al registro encontrado.
Y a la vez, en el segundo TextBox puedo hacer cualquier busqueda en el NOMBRE.
(Esta busqueda la hago en un DBF con 20,000 registros.)
It's just one way (of course there are many) of how I do a search ...
I have 2 TextBox and 2 ComboBox
If I find the code, I display the information, but to the
once filled the 2 Combobox, one with the records that contain
what you type in the code ("1254"), and the other with the records
that contain the same names ("OBADIA") to the found record.
And at the same time, in the second TextBox I can do any search in the NAME.
(This search is done in a DBF with 20,000 records.)
- dragancesu
Re: ComboSearchGrid
Nice, what program do you use to make this video?
