Function Main()
SET NAVIGATION EXTENDED
SET DATE TO BRITISH
SET CENTURY ON
DEFINE WINDOW Form_1 AT 0,0 ;
WIDTH 400 HEIGHT 175 NOSIZE ;
TITLE 'Simulating SET CONFIRM OFF at TextBoxes' ;
ON KEY ESCAPE ACTION ThisWindow.Release()
DEFINE STATUSBAR FONT "Courier New" SIZE 9
STATUSITEM PadC("Press <Insert> key and type again",44)
STATUSITEM " Insert" WIDTH 94 ICON if ( IsInsertActive() , "zzz_led_off" , "zzz_led_on" )
END STATUSBAR
DEFINE LABEL Label_1
ROW 20
COL 30
WIDTH 160
VALUE 'Field 1 (Length 10):'
FONTBOLD .T.
END LABEL
DEFINE TEXTBOX Text_1
ROW 20
COL 160
WIDTH 180
MAXLENGTH 10
ON CHANGE {|| SetConfOFF(10,0) }
END TEXTBOX
DEFINE LABEL Label_2
ROW 48
COL 30
WIDTH 160
VALUE 'Field 2 (Length 10):'
FONTBOLD .T.
END LABEL
DEFINE TEXTBOX Text_2
ROW 48
COL 160
WIDTH 180
MAXLENGTH 10
DATE .T.
END TEXTBOX
DEFINE LABEL Label_3
ROW 76
COL 30
WIDTH 160
VALUE 'Field 3 (Length 14):'
FONTBOLD .T.
END LABEL
DEFINE TEXTBOX Text_3
ROW 76
COL 160
WIDTH 180
INPUTMASK "999.999.999-99"
ON CHANGE {|| SetConfOFF(0,Len("999.999.999-99")) }
END TEXTBOX
_DefineTimer ( 'StatusKeyBrd' , "Form_1" , 50 , ;
{|| _SetStatusIcon ( 'StatusBar' , "Form_1" , 2 , if ( IsInsertActive() , "zzz_led_off" , "zzz_led_on" ) ) } )
CREATE EVENT PROCNAME OnkeyAllEditBox()
Form_1.Center
Form_1.Activate
Function SetConfOFF( nMaxLength, nInputMask )
Local cFrmName := ThisWindow.Name
Local cCmpName := This.FocusedControl
If nInputMask > 0
nMaxLength := nInputMask
Endif
If !Empty(cCmpName)
If nMaxLength == GetProperty(cFrmName,cCmpName,"CaretPos")
InsertTab()
Endif
Endif
Function OnkeyAllEditBox()
Local nIndex := GetControlIndexByHandle (EventHWND())
If nIndex > 0 .AND. GetControlTypeByIndex (nIndex) == "TEXT"
If EventMSG() == WM_CHAR
If .NOT. (GetKeyState (VK_INSERT) == 0) .AND. HMG_GetLastVirtualKeyDown() != VK_RETURN .AND. HMG_GetLastVirtualKeyDown() != VK_BACK
SendMessage (EventHWND(), WM_KEYDOWN, VK_DELETE, 0)
KSETINS(.T.)
Else
KSETINS(.F.)
Endif
Endif
Endif
Return NILI hope you enjoy it !
