Simulates "Set Confirm Off" and Overwrite in TextBoxes
This improved example was extracted from this post of Toledo forum which I believe could it be usefull and we wish to share with you.
Function Main()
SET NAVIGATION EXTENDED
SET DATE TO BRITISH
SET CENTURY ON
DEFINE WINDOW Form_1 AT 0,0 ;
    WIDTH 400 HEIGHT 175 NOSIZE ;
    TITLE 'Simulating SET CONFIRM OFF at TextBoxes' ;
    ON KEY ESCAPE ACTION ThisWindow.Release()
    DEFINE STATUSBAR FONT "Courier New" SIZE 9
        STATUSITEM PadC("Press <Insert> key and type again",44)
        STATUSITEM " Insert" WIDTH 94 ICON if ( IsInsertActive() , "zzz_led_off" , "zzz_led_on" )
    END STATUSBAR
    DEFINE LABEL Label_1
        ROW   20
        COL   30
        WIDTH 160
        VALUE 'Field 1 (Length 10):'
        FONTBOLD .T.
    END LABEL
    DEFINE TEXTBOX Text_1
        ROW       20
        COL       160
        WIDTH     180
        MAXLENGTH 10
        ON CHANGE {|| SetConfOFF(10,0) }
    END TEXTBOX
    DEFINE LABEL Label_2
        ROW    48
        COL    30
        WIDTH  160
        VALUE 'Field 2 (Length 10):'
        FONTBOLD .T.
    END LABEL
    DEFINE TEXTBOX Text_2
        ROW   48
        COL   160
        WIDTH   180
        MAXLENGTH 10
        DATE .T.
    END TEXTBOX
    DEFINE LABEL Label_3
        ROW   76
        COL   30
        WIDTH 160
        VALUE 'Field 3 (Length 14):'
        FONTBOLD .T.
    END LABEL
    DEFINE TEXTBOX Text_3
        ROW     76
        COL     160
        WIDTH   180
        INPUTMASK "999.999.999-99"
        ON CHANGE {|| SetConfOFF(0,Len("999.999.999-99")) }
    END TEXTBOX
    _DefineTimer ( 'StatusKeyBrd' , "Form_1" , 50 , ;
        {|| _SetStatusIcon ( 'StatusBar' , "Form_1" , 2 , if ( IsInsertActive() , "zzz_led_off" , "zzz_led_on" ) ) } )
CREATE EVENT PROCNAME OnkeyAllEditBox()
Form_1.Center
Form_1.Activate
Function SetConfOFF( nMaxLength, nInputMask )
Local cFrmName   := ThisWindow.Name
Local cCmpName   := This.FocusedControl
If nInputMask > 0
   nMaxLength := nInputMask
Endif
If !Empty(cCmpName)
   If nMaxLength == GetProperty(cFrmName,cCmpName,"CaretPos")
      InsertTab()
   Endif
Endif
Function OnkeyAllEditBox()
Local nIndex := GetControlIndexByHandle (EventHWND())
If nIndex > 0 .AND. GetControlTypeByIndex (nIndex) == "TEXT"
   If EventMSG() == WM_CHAR
      If .NOT. (GetKeyState (VK_INSERT) == 0) .AND. HMG_GetLastVirtualKeyDown() != VK_RETURN .AND. HMG_GetLastVirtualKeyDown() != VK_BACK
         SendMessage (EventHWND(), WM_KEYDOWN, VK_DELETE, 0)
         KSETINS(.T.)
      Else
         KSETINS(.F.)
      Endif
   Endif
Endif
Return NIL
This demo when editing and fill TextBox will change focus to next field. Also can be use overwrite editing but works only when is TEXT and with no mask in it.
I hope you enjoy it !
Re: Simulates "Set Confirm Off" and Overwrite in TextBoxes
Hola Pablo César,
Muy bonito ejemplo! Felicidades!
Gracias, Javier. Como siempre, muy atento ! :)
Hola amigo Pablo César
Encontre un sample del amigo LuchoMiranda "El Salmes"
sobre desglose de Cambio en la Moneda, estaba adaptando el
su ejemplo, cuando he visto tu magnifica rutina, me he permitido
adaptarla a mi codigo simplificando un poco, espero que les guste
Para que haga el salto automatico en TEXTBOX hay que poner
tambien los decimales ejemplo 234,00 € para que haga el salto
hay que poner los 2 ceros
*-------------------------------- Google ----------------------------------------------*
Hello friend Pablo César
I found a sample LuchoMiranda Friend "The Salmes"
on breakdown of Currency Substitution, was adapting the
his example, when I saw your magnificent routine, I have allowed
adapt it to my code simplifying a bit, hope you like it
To make the automatic jump TEXTBOX must put
also decimal example 234.00 €to do the jump
must add 2 zeros
Mustafa :idea:
Money_Exchange.zip
(20.04 KiB) Downloaded 342 times
Thanks, Pablo and Mustafa :)
Both samples are useful and educative :arrow:
Viva HMG :D
Gracias Mustafa por tu contribuicion y me alegra que te haya sido útil.
Thank you Esgici for your usual interest.
Hola amigos:
Les presento una ampliación del Sample anterior
he incorporado opción tarjeta de Crédito, salvar
ventas en un fichero y opción a Listado Reporter
espero que les guste.
*--------------- Google -----------------------*
Hello friends:
I present an extension of the previous Sample
I have incorporated credit card option, save
sales in a file and option Reporter Listing
hope you like.
Mustafa :idea:
Money_Exchange_New.zip
(130.52 KiB) Downloaded 357 times
Gracias Mustafa por compartir! :D
Muy bueno Mustafá.....
Hola amigos:
Nueva ampliación del Sample
He incorporado Password y Usuario
que se graba en Base de Datos de Ventas
asi como Hora de la operación ver listado
Lean Fichero 'readme_key.pdf' donde hay
unos permisos autorizados.
Espero les guste
*----------------- Google -------------------*
Hello friends:
Further enlargement of the Sample
I incorporated Password and User
which is recorded in Sales Database
also see Operation Time List
Read file 'readme_key.pdf' where
some permits authorized.
Hope you like
Mustafa :idea:
(1.34 MiB) Downloaded 343 times
