TBrowse with dynamic filtering
Hi Friends,
I saw an interesting sample by Mr. Rao on the FiveWin forum.
This example inspired me to adapt it to MiniGUI. :idea:
I have attached a working application for your testing. 8-)
The original form with the TBROWSE control, three checkboxes and a filter status is shown below. :arrow:
Then we set a filter on MARRIED field
Add the filter condition on STATE field
and finally add the filter on AGE field
HMG Power is ready :!:
Tsb_filter_app.zip
Test application
(1.27 MiB) Downloaded 117 times
Re: TBrowse with dynamic filtering
Thanks !
ASESORMIX
Post by ASESORMIX »
Gracias por comprtir.
Puedes postear el codigo fuente.? O donde puedo conseguirlo.?
tryak96
Post by tryak96 »
Good idea
The Eart would be a good place without humans.
ASESORMIX wrote: Tue May 14, 2024 3:40 pm Gracias por comprtir.
Thanks for your interest :!:
The complete source code for this example is below. :arrow:
#include "TSBrowse.ch"
REQUEST DBFCDX
FUNCTION Main()
   LOCAL obrw
   LOCAL aFilters := { { .F., "AGE>40" }, { .F., "STATE='NY'" }, { .F., "MARRIED" } }
   LOCAL aCheck[ 3 ], n
   LOCAL nRow := 40
   LOCAL nCol := 40
   USE CUSTOMER NEW SHARED VIA "DBFCDX"
   DEFINE WINDOW win_1 ;
         AT 0, 0 ;
         WIDTH 600 HEIGHT 400 ;
         MAIN ;
         TITLE Alias() + ": Dynamic Filter Test" ;
         ICON "lupa.ico" ;
         FONT "Arial" ;
         SIZE 10 ;
         NOMAXIMIZE NOSIZE
      FOR n := 1 TO Len( aFilters )
         aCheck[ n ] := CreateChk( nRow, nCol, thiswindow.Name, aFilters, n )
         this.( aCheck[ n ] ).Cargo := n
         this.( aCheck[ n ] ).OnChange := {|| n := this.Cargo, aFilters[ n, 1 ] := ! aFilters[ n, 1 ], ;
            SetProperty( 'win_1', "Label_1", "Value", "FILTER : " + ResetFilter( obrw, aFilters ) ) }
         nCol += 150
      @ 80, 40 LABEL Label_1 VALUE "FILTER : " WIDTH 400 HEIGHT 25 CENTERALIGN
      DEFINE TBROWSE obrw AT 115, 40 ;
         CELLED SELECTOR "pointer.bmp" ;
         COLORS CLR_BLACK, CLR_WHITE, CLR_BLACK, { RGB( 231, 242, 255 ), GetSysColor( COLOR_GRADIENTINACTIVECAPTION ) } ;
         ALIAS Alias() ;
         WIDTH win_1.Width - 70 - GetBorderWidth() HEIGHT 220 ;
         ON INIT {| ob | TsbCreate( ob, .T. ) }
      END TBROWSE ON END {| ob | TsbCreate( ob, .F. ) }
   ON KEY ESCAPE OF win_1 ACTION win_1.Release()
   CENTER WINDOW win_1
   ACTIVATE WINDOW win_1
STATIC PROCEDURE TsbCreate( obrw, lInit )
   LOCAL aFields, oCol
   IF lInit
      // initial columns
      aFields := { "ID", "CITY", "STATE", "MARRIED", "AGE" }
      LoadFields( "oBrw", "win_1", .F., aFields )
      FOR EACH oCol IN oBrw:aColumns
         oCol:cHeading := oCol:cName
      WITH OBJECT oBrw
         :nHeightCell += 4
         :nHeightHead := oBrw:nHeightCell - 2
         :SetColor( { 5 }, { CLR_WHITE } )
         :SetColor( { 6 }, { RGB( 0, 0, 128 ) } )
         :SetAppendMode( .F. )
         :SetDeleteMode( .T., .F. )
         :lNoResetPos := .T.
         :lNoMoveCols := .T.
         :lNoKeyChar := .T.
         :lNoChangeOrd := .T.
         :lNoHScroll := .T.
      END OBJECT
      obrw:SetNoHoles()
      obrw:SetFocus()
STATIC FUNCTION CreateChk( nRow, nCol, oDlg, aFilters, nIndex )
   LOCAL cChk := "Check_" + hb_ntos( nIndex )
   @ nROW, nCol CheckBox ( cChk ) PARENT ( oDlg ) ;
      CAPTION aFilters[ nIndex, 2 ] VALUE aFilters[ nIndex, 1 ] ;
      WIDTH 150 HEIGHT 21
RETURN cChk
STATIC FUNCTION ResetFilter( obrw, aFilters )
   LOCAL cFilter
   LOCAL af := {}
   AEval( aFilters, {| a | If( a[ 1 ], AAdd( af, a[ 2 ] ), nil ) } )
   cFilter := LB_Array2String( af, " .AND. " )
   IF Empty( cFilter )
      oBrw:FilterData()
      oBrw:FilterData( cFilter, , .T. )
RETURN cFilter
Hope it is helpful. :idea:
ASESORMIX
Post by ASESORMIX »
Muchas Gracias Gregory.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
This is nice and useful, but limited, not used for all fields
Is it possible to somehow select a field and a criterion on it and insert it into the filter
numeric fields can be =, >, <, !=, between
date =, !=, between
character =, !=, like
between in sql is range, from - to
like with wildcards is very powerful
practically we need a function that dynamically create a set filter criterion (like in access on picture)
dragancesu wrote: Thu May 16, 2024 8:40 am This is nice and useful, but limited, not used for all fields
date =, !=, between
Hi Dragan,
Thanks for your suggestion.
There is an example of a more advanced query dialog for any grid, as shown in the image below.
And the result of the above query is:
Here is a main form definition for testing:
/* Test Grid Query */
Procedure Main
   local aGrid, nGrid
   LOCAL aMinMaxInfo := {}, i, nWidth
   local aHeaders := {"Sno","Words","Numeric","Factor","Value","Y","Date"}
   local aWidths := {50,70,70,50,70,50,80}
   local aJustify := {2,0,1,0,0,2,2}
   local cWin := "FrmMain"
   Set( _SET_DEBUG, .f. )
   Set Century ON
   Set Date British
   DEFINE FONT FontBold FONTNAME _HMG_DefaultFontName SIZE _HMG_DefaultFontSize + 1 BOLD
   aGrid := { { '001', 'One',   100, 4, 400,.t.,Date() },;
              { '002', 'Two',   100, 6, 600,.t.,Date()-10 },;
              { '003', 'Three', 100, 7, 700,.t.,Date()-365 },;
              { '004', 'Four',  100, 5, 500,.f.,Date()-100 },;
              { '005', 'Five',  100, 3, 300,.t.,Date()-50 },;
              { '006', 'Six',   100, 5, 500,.t.,Date()-90 },;
              { '007', 'Seven', 100, 7, 700,.f.,Date()-200 },;
              { '008', 'Eight', 100, 9, 900,.t.,Date()-150 },;
              { '009', 'Nine',  100, 5, 500,.t.,Date()-60 },;
              { '010', 'Ten',   100, 4, 400,.f.,Date()-80 },;
              { '011', 'Eleven',100, 6, 600,.t.,Date()-70 },;
              { '012', 'Twelve',100, 7, 700,.f.,Date()-30 } }
   nGrid := 0
   AEval(aWidths, {|e| nGrid += e})
   define window &cWin at 0,0 width 640 height 480 title "F2 - Query" main
      ON KEY ESCAPE OF &cWin Action thisWindow.Release
      ON KEY F2 of &cWin Action GridQuery(cWin,"Grid1")
      @ 10,10 Grid Grid1 of &cWin autosizewidth nGrid height 400 Headers aHeaders Widths aWidths ;
            Items aGrid Value 1 justify aJustify backcolor BROWN fontcolor YELLOW nosortheaders
   for i := 1 to getproperty(cWin,"Grid1","ColumnCount")
      // Dynamic Header
      FrmMain.Grid1.HeaderDYNAMICFONT(i) := {|| 'FontBold' }
      FrmMain.Grid1.HeaderDYNAMICBACKCOLOR(i) := {|| BROWN }
      FrmMain.Grid1.HeaderDYNAMICFORECOLOR(i) := {|| YELLOW }
      nWidth := FrmMain.Grid1.COLUMNWIDTH(i)
      AAdd( aMinMaxInfo, { nWidth, nWidth } )
   next
   FrmMain.Grid1.COLUMNWIDTHLIMITS := aMinMaxInfo
   end window
   DoMethod(cWin,"Activate")
return
Thank you for your attention. 8-)
Thanks !
