Text Mode Menu Converter
HGAutomator
Post by HGAutomator »
The following has zero practical use, as far as I can tell. But it was a tangent exploration thas was fun to play with.
Takes Menu Items specified in a form
{ { "First Menu item", "First Message" }, { "Second Menu item", "Second Message" }, { "Third Menu Item", "Third Message" }, etc. }
, and calculates rows and columns to generate Horizontal, Vertical, or Random menus.
Compile:
call ..\..\batch\compile.bat MultMenu /C /LE c:\minigui\Harbour\lib\hbnf /C /LE c:\minigui\Harbour\lib\SUPER %2 %3 %4 %5 %6 %7 %8 %9
#Include "MiniGui.ch"
#Include "hbinkey.ch"
#Include "inkey.ch"
Function MultMenu
Local MainMenu_a := { ;
                      {'Add', "Add Something", },;
                      {'Open', "Open Something" },;
                      {'Edit', "Change Something" },;
                      {'Delete', "Delete Something"},;
                      {'Reset', "Reset Everything"},;
                      {'Quit', "Get the heck out" }}
Local CompleteMenu_a := { ;
                      {1,1 ,  "Add",          2, 1, "Add something"},;
                      {1,5 ,  "Open",         2, 1, "Open something"},;
                      {1,10 , "Delete",       2, 1, "Delete something"},;
                      {1,17 , "Change Date",  2, 1, "Change the current Date"},;
                      {1,29 , "List",         2, 1, "Display List"},;
                      {1,34 , "Purge",        2, 1, "Purge something"},;
                      {1,40 , "Purge 2",      2, 1, "Purge something else"},;
                      {1,48 , "Purge 3",      2, 1, "Purge something one more time"},;
                      {1,57 , 'Quit',         2, 1, 'Get da heck out'}}
SETCOLOR( "W+/B,B/W,,W+/B")
cls(23, chr(177))
ComputedArray_a := Fill_in_Coordinates_for_Menu_Array( MainMenu_a, "HORIZONTALBAR" )
nSelected := Execute_MenuArray(ComputedArray_a,1,.t.)
cls()
ComputedArray_a := Fill_in_Coordinates_for_Menu_Array( MainMenu_a, "VERTICALBAR" )
cls()
ComputedArray_a := Fill_in_Coordinates_for_Menu_Array( MainMenu_a, "RANDOMMENU" )
cls()
nSelected := Execute_MenuArray(CompleteMenu_a,1,.t.)
cls()
// From Super.lib
FUNCTION cls(ncColorAtt,Fill_Character_s)
local Color_s
Color_s   := iif(valtype(ncColorAtt)=="N",at2char(ncColorAtt),ncColorAtt)
Fill_Character_s := repl( iif(Fill_Character_s#nil,Fill_Character_s," "),9 )
dispbox(0,0,maxrow(),maxcol(),Fill_Character_s,Color_s)
RETURN ''
Function At2char(nColor)
local ForeGround_a   := {"N","B","G","BG","R","RB","GR","W",;
                  "N+","B+","G+","BG+","R+","RB+","GR+","W+"}
local BackGround_a   := {"N","B","G","BG","R","RB","GR","W",;
                  "N*","B*","G*","BG*","R*","RB*","GR*","W*"}
local nFore         := nColor%16
local nBack         := INT(nColor/16)
local cForeground   := ForeGround_a[nFore+1]
local cBackGround   := BackGround_a[nBack+1]
return ( cForeground+'/'+cBackGround )
// Originally Rat_Menu2() From SuperLib
FUNCTION Execute_MenuArray(Menus_a,nStart,Menu_First_Letter_Executes_b)
  Menus_a should be a nested array of menu arrays Menu_a.
  Each menu array should be of the form
  { MenuRow, MenuColumn, MenuItem, MessageRow, MessageColumn, Message }
  nStart - The Nth Prompt to start with.  Defaults to the first prompt
	Menu_First_Letter_Executes_b -
		If Menu_First_Letter_Executes_b is True, then a single first letter and ENTER will return.
		If Menu_First_Letter_Executes_b is False, then two first letters are required.
Local Normal_Color_s := ""
Local Enhanced_Color_s := ""
local NthOption_n := 0
Local NthOption_a := {}
Local Message_Row_n := 0
local Selected_Item_n := 0
local Previous_Selected_Item_n := 0
local LastKeyPressed_n
Local nFound
Local nMrow
Local nMcol
Local nMouseFound
local FirstLettersOfMenus_s := ""
local LastKeyPressed_c
Local Key_cb					 // SETKEY Code Block
local Cursor_n := setcursor(0)
Normal_Color_s   				:= Token(Setcolor(),",",1)
Enhanced_Color_s    			:= Token(Setcolor(),",",2)
NthOption_n := 0
NthOption_a := {}
// Return the current selected item, the starting item or the last item, whichever is less.
Selected_Item_n := min( iif(nStart#nil,max(nStart,1),1), len(Menus_a) )
Previous_Selected_Item_n := Selected_Item_n
Menu_First_Letter_Executes_b := iif(Menu_First_Letter_Executes_b#nil,Menu_First_Letter_Executes_b,.t.)
// Initial Display of all the menu items
AEVal( Menus_a, { | NthOption_a, NthOption_n   | DisplayCurrentMenuItem( NthOption_a, NthOption_n, Normal_Color_s, Enhanced_Color_s ) } )
// Concatenate all first letters of the menus into a single string
FirstLettersOfMenus_s := ConcatenateAllFirstLetters_of_Menus("ConcatenateFirstLetters",Menus_a,"")
while .t.
	hb_DispOutAtBox( Menus_a[Previous_Selected_Item_n,1], Menus_a[Previous_Selected_Item_n,2], Menus_a[Previous_Selected_Item_n,3], Normal_Color_s )
	hb_DispOutAtBox( Menus_a[Previous_Selected_Item_n,1], Menus_a[Previous_Selected_Item_n,2], Menus_a[Previous_Selected_Item_n,3], Enhanced_Color_s )
	// TODO: Customize background of message depending on type of menu
	// 		 Specifically, change the background fill characters for the left of the message.
	// Clear Message
	hb_DispOutAtBox( Menus_a[Previous_Selected_Item_n,4], Menus_a[Previous_Selected_Item_n,5], Repl( chr(177), MaxCol() ), Normal_Color_s )
	// Display Message
	hb_DispOutAtBox( Menus_a[Previous_Selected_Item_n,4], Menus_a[Previous_Selected_Item_n,5], Menus_a[Previous_Selected_Item_n,6], Normal_Color_s )
   LastKeyPressed_n := rat_event(0)
   LastKeyPressed_c := upper(chr(LastKeyPressed_n))
   do case
   case LastKeyPressed_n == K_LEFT .or. LastKeyPressed_n==K_UP
      Selected_Item_n := IIF(Selected_Item_n=1,len(Menus_a),Selected_Item_n-1)
   case LastKeyPressed_n == K_RIGHT .or. LastKeyPressed_n == K_DOWN
      Selected_Item_n := IIF(Selected_Item_n=len(Menus_a),1,Selected_Item_n+1)
	Case IsThisCharacterContainedInThatString( LastKeyPressed_c, FirstLettersOfMenus_s )
      if (nFound := AT(LastKeyPressed_c,subst(FirstLettersOfMenus_s,Selected_Item_n)) ) > 0
        Selected_Item_n := nFound+Selected_Item_n-1
        Selected_Item_n := at(LastKeyPressed_c,FirstLettersOfMenus_s)
      if Menu_First_Letter_Executes_b .or. Selected_Item_n==Previous_Selected_Item_n
        keyboard chr(13)
   case LastKeyPressed_n = K_ENTER .or. LastKeyPressed_n==K_PGUP .or. LastKeyPressed_n== K_PGDN
      exit
   case LastKeyPressed_n = K_ESC
      exit
    case ( (Key_cb := SetKey(LastKeyPressed_n)) <> NIL )
      Eval(Key_cb,"",0,"")
   endcase
end
setcursor(Cursor_n)
return Selected_Item_n
Procedure DisplayCurrentMenuItem( NthOption_a, NthOption_n, Normal_Color_s, Enhanced_Color_s	)
hb_DispOutAtBox( NthOption_a[1], NthOption_a[2], NthOption_a[3], Normal_Color_s )
Function ConcatenateFirstLetters(FirstLettersOfMenus_s,NthOption_a)
	FirstLettersOfMenus_s += upper(left(NthOption_a[3],1 ))
Return FirstLettersOfMenus_s
	Map functions were written by a generous fellow Harbour traveler in one of the google groups.
	For an explanation of each Map function, see
	 https://www.freecodecamp.org/news/javascript-map-reduce-and-filter-explained-with-examples/
// Returns an array, whose elements are the value of xFunc applied to each element in aArg1
//  aArg2, aArg3, aArg4, ... aArgnN have not been tested yet.
// AMap( <xFunc, [,aArg1] [, aArgN])
function AMap(...)
   local aOut := {}
   local aTemp
   local aArgs := hb_aParams()
   local nArgCount := len(aArgs) // func is the first arg so skip it.
   local xFunc := iif(len(aArgs)>0,aArgs[1],nil)
   local nArgInd
   local lObject := hb_isObject(xFunc)
   local nArgStart := iif(lObject,3,2)
   local nResCount := iif(nArgCount>1,len(aArgs[2]),0)
   local nResInd
   local oObj := iif(lObject,xFunc,nil)
   if lObject
      xFunc := aArgs[2]
   for nResInd:=1 to nResCount
      aTemp := {}
      for nArgInd:=nArgStart to nArgCount
         aAdd(aTemp,aArgs[nArgInd][nResInd])
      next
      if lObject
         aAdd(aOut, HB_ExecFromArray(oObj,xFunc,aTemp))
         aAdd(aOut, HB_ExecFromArray(xFunc,aTemp))
   next
return aOut
	Applies function Reduction_Function_x to FirstValueToBeApplied_x and first element of Parameters_a,
	then applies Reduction_Function_x to the result of the first application and the second element of Parameters_a,
	then applies Reduction_Function_x to the result of the previous application and the third element of Parameters_a, etc,
	until it arrives at a single result which is the accumulation of the functiona applied to all consecutive elements of the array.
	AReduce( "Add", { 1, 2, 3 } )
		=> 6 ( 0 + 1 + 2 + 3 = 6 )
	AReduce( "ConcatenateAllFirstLetters_of_Menus", { "What", "the", "heck" } )
		=> "Wth" ( Concatenate "" with "W" with "t" with "h"   )
	Returns same type as FirstValueToBeApplied_x accumulated from each element
function AReduce(Reduction_Function_x,Parameters_a,FirstValueToBeApplied_x)
   local StartingElement_n := 1
   local nLength := len(Parameters_a)
   local nInd
   if hb_isNil(FirstValueToBeApplied_x) .and. nLength>0
      StartingElement_n := 2
      FirstValueToBeApplied_x := Parameters_a[1]
	hb_ForNext( StartingElement_n, nLength, { |nInd| FirstValueToBeApplied_x := HB_ExecFromArray( Reduction_Function_x, {FirstValueToBeApplied_x,Parameters_a[nInd]}) } )
return FirstValueToBeApplied_x
  Applies constraint function xFunc to each parameter of Parameters_a,
  , returning an array with elements that satisfy the constraint.
  See
	https://www.phptutorial.net/php-tutorial/php-array-filter/
		and
	https://en.wikipedia.org/wiki/Filter_(higher-order_function)
	for illustrative examples and explanations
Function aFilter(xFunc,Parameters_a)
   local aOut := {}
   local nInd
   for nInd := 1 to nLength
      if HB_ExecFromArray(xFunc,{Parameters_a[nInd]})
         aAdd(aOut,Parameters_a[nInd])
   next
return aOut
Function IsThisCharacterContainedInThatString( ThisCharacter_s, ThatString_s )
Local ThisCharacterContainedInThatString_b := .F.
ThisCharacterContainedInThatString_b := ThisCharacter_s $ ThatString_s
Return ThisCharacterContainedInThatString_b
Function Fill_in_Coordinates_for_Menu_Array( MenuArray_a, Menu_Type_s )
  Convert a menu array without coordinates like
  	{ MenuItem, Message }
  to a menu array with Row and Column coordinates like
Local CompleteMenuArray_a := {}
Do Case
Case Menu_Type_s == "HORIZONTALBAR"
	CompleteMenuArray_a := AMap( "ConvertMenu_to_HorizontalBar", MenuArray_a )
Case Menu_Type_s == "VERTICALBAR"
	CompleteMenuArray_a := AMap( "ConvertMenu_to_VerticalBar", MenuArray_a )
Case Menu_Type_s == "RANDOMMENU"
	CompleteMenuArray_a := AMap( "ConvertMenu_to_RandomMenu", MenuArray_a )
End Case
Return CompleteMenuArray_a
Function ConvertMenu_to_HorizontalBar( MenuItem_a )
  MenuItem_a has the structure
Local HorizontalMenuItem_a := {}
Local Row_n := 1
Local MenuItem_s := ""
Local Message_s := ""
STATIC Column_n := 0
MenuItem_s := Trim( MenuItem_a[ 1 ] )
Message_s := Trim( MenuItem_a[ 2 ] )
// Menu item
AADD( HorizontalMenuItem_a, Row_n )
AADD( HorizontalMenuItem_a, Column_n )
AADD( HorizontalMenuItem_a, MenuItem_s )
// Messages associated with each Menu item
AADD( HorizontalMenuItem_a, Row_n + 1 )
AADD( HorizontalMenuItem_a, 0 )
AADD( HorizontalMenuItem_a, Message_s )
// Calculate Next Column, which will be the previous column plus the length of the current menu item plus the length of one space.
Column_n := Column_n + Len( Trim( MenuItem_s ) ) + 1
Return HorizontalMenuItem_a
Function ConvertMenu_to_VerticalBar( MenuItem_a )
Local VerticalMenuItem_a := {}
Local Column_n := 1
STATIC Row_n := 0
// Menu item
AADD( VerticalMenuItem_a, Row_n )
AADD( VerticalMenuItem_a, Column_n )
AADD( VerticalMenuItem_a, MenuItem_s )
AADD( VerticalMenuItem_a, Column_n + Len( MenuItem_s ) + 2 )
AADD( VerticalMenuItem_a, Message_s )
// Calculate Next Row, which will be the previous Row plus 1.
Row_n := Row_n + 1
Return VerticalMenuItem_a
	Please do not ask me, why I built something as insane and useless
	 as a menu picklist located at random points on the screen.
	It just sounded like it would be fun to see.
Function ConvertMenu_to_RandomMenu( MenuItem_a )
#DEFINE TEMPORARYRANDOMROWLIMIT 15				// Maximum number of row coordinates
#DEFINE TEMPORARYRANDOMCOLUMNLIMIT 72			// Maximum number of column coordinates
/*	TODO - The maximum number of rows and columns used to extract the random rows and columns,
	 should be a factor of the total number of menu items.
Local RandomMenuItem_a := {}
Local RandomRow_n := 0
Local RandomColumn_n := 0
Local Column_n := 1
RandomRow_n := hb_RandomInt( TEMPORARYRANDOMROWLIMIT )
RandomColumn_n := hb_RandomInt( TEMPORARYRANDOMCOLUMNLIMIT )
// Menu item
AADD( RandomMenuItem_a, RandomRow_n )
AADD( RandomMenuItem_a, RandomColumn_n )
AADD( RandomMenuItem_a, MenuItem_s )
AADD( RandomMenuItem_a, RandomColumn_n + Len( MenuItem_s ) + 2 )
AADD( RandomMenuItem_a, Message_s )
Return RandomMenuItem_a
Function ConcatenateAllFirstLetters_of_Menus( ConcatenateFirstLetters_s, Menus_a, FirstValue_s )
Local FirstLettersOfMenus_s := ""
FirstLettersOfMenus_s := AReduce("ConcatenateFirstLetters",Menus_a, FirstValue_s )
[attachment=0]MultiMenu.jpg[/attachment]
Re: Text Mode Menu Converter
Pure nostalgia?!
HGAutomator
Yes, and the feeling of Flow when using the Text Mode and Keyboard, as opposed to draaaaaggging the mouse to get things done.
serge_girard wrote: Tue Dec 21, 2021 11:09 am Pure nostalgia?!
