Fullscreen - AutoAdjust
emzampi
Post by emzampi »
hello to everyone
I have to submit a problem with the resolution Fullscreen (my 1360 x 768) on which I built the program
using all available pixels.
I realized that using a resolution of 800x600 Fullscreen type part of the program was not
visible, and I have searched the forum for a solution that I found with partially AutoAdjust.prg 'nice program'
that does not solve my problem that I solved with this code, you can integrate it in AutoAdjust.prg
thus automating the use of H1 = ggh / nMainh W1 = ggw / nMainW
Private nMainW:=1360, nMainH:=768
ggw=GetDesktopWidth()
ggh=GetDesktopHeight()
W1=ggw/nMainW
H1=ggh/nMainh
DEFINE WINDOW condo ;
AT 0 , 0 WIDTH nMainW*w1 HEIGHT nMainH*h1 ;
TITLE 'CONDOMINIO' ;
MAIN ;
BACKCOLOR {213,235,244 } ;
CURSOR "bmp/salamandra.ani";
ON INIT AutoAdjust( ThisWindow.Name );
ON MAXIMIZE AutoAdjust( ThisWindow.Name );
ON SIZE AutoAdjust( ThisWindow.Name );
FONT "Tahoma" SIZE 9
DEFINE IMAGE Image_2
ROW 10 *h1
COL 1290*w1
WIDTH 22
HEIGHT 22
PICTURE 'bmp/quit.bmp'
HELPID Nil
VISIBLE .T.
STRETCH .F.
ACTION {||CloseTables1()} //(CIG1_Change()),,(condo2.Release)
END IMAGE
Re: Fullscreen - AutoAdjust
Thanks for sharing !
emzampi
Post by emzampi »
hello to everyone
I tried and tried to profane retouching program AutoAdjust to expose data also changing desktop settings were able to achieve a small result which you can test yourself and surely as the genes which I hope you are able to develop optimally
Thank you for existing
P.S. sorry but I have not found another way to insert the source file !!???
* HMG - Harbour Win32 GUI library
* Copyright 2002-2008 Roberto Lopez <mail.box.hmg@gmail.com>
* Revision: October 31, 2014
* Revised by: Danny Del Pilar
* HMG Sample: Managing Dynamic Windows Sample
Function Main()
*ALTD()
*ggw - ggh cordinate del destop di costruzione
ggw= 1200
ggh= 600
PRIVATE hWndName := ""
DEFINE WINDOW Form_1 ;
WIDTH ggw;
HEIGHT ggh ;
MAIN;
TITLE 'Button Test'
DEFINE MAIN MENU
POPUP 'Test'
ITEM 'Disable button' ACTION Form_1.Button_1.Enabled := .f.
ITEM 'Enable button' ACTION Form_1.Button_1.Enabled := .t.
SEPARATOR
* ITEM "Window 1" ACTION WIND( "window1" )
* ITEM "Window 2" ACTION WIND( "window2" )
* ITEM "Window 3" ACTION WIND( "window3" )
END POPUP
END MENU
@ 70,70 BUTTON Button_1 PICTURE "button.bmp" WIDTH 50 HEIGHT 50
@ 40,400 LABEL M1 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 200 HEIGHT 20
@ 80,400 LABEL m2 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 250 HEIGHT 20
@ 120,400 LABEL m3 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 300 HEIGHT 20
@ 140,960 LABEL m4 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 180 HEIGHT 20
@ 180,970 LABEL m5 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 180 HEIGHT 20
@ 220,980 LABEL m6 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 180 HEIGHT 20
@ 250,990 LABEL m7 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 180 HEIGHT 20
@ 280,1000 LABEL m8 VALUE 'aaaaaaaaaa' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 180 HEIGHT 20
@ 310,400 LABEL settore VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {56,240,32 } FONTCOLOR RED WIDTH 400 HEIGHT 50
@ 300,580 LABEL m9 VALUE 'turoituioer' font '.vntime' size 10 bold BACKCOLOR {156,2,132 } FONTCOLOR RED WIDTH 400 HEIGHT 20
Form_1.Maximize
ACTIVATE WINDOW Form_1
Function AutoAdjust( cForm )
Local hWnd := GetFormHandle( cForm )
Local i,; // From no
k,; // Control no
ParentForm,;
ControlCount,;
ControlName,;
ControlType,;
nWidth,;
nHeight,;
lvisible := .T.,;
nDivw,;
nDivh
Private nMainW:=GetWindowWidth ( hWnd ), nMainH:=GetWindowHeight ( hWnd)
aa=ggw/GetWindowWidth ( hWnd )
bb=ggh/GetWindowHeight ( hWnd )
IF GetDesktopWidth() > GetWindowWidth ( hWnd )
nWidth :=GetDesktopWidth()
nWidth=(nWidth/nMainW)
nWidth := GetWindowWidth ( hWnd )
IF GetDesktopHeight() > GetWindowHeight ( hWnd )
nHeight := GetDesktopHeight()
nHeight=( nHeight/nMainH)
IF IsWindowVisible( hWnd ) .AND. ! IsAppXPThemed()
HideWindow ( hWnd )
lvisible := .F.
i := aScan ( _HMG_SYSDATA[67], hWnd )
ParentForm := _HMG_SYSDATA[66]
IF _HMG_SYSDATA[ 92, i ] > 0 .AND. _HMG_SYSDATA[ 91, i ] >0
nDivw := nWidth / _HMG_SYSDATA[ 92, i]
nDivh := nHeight/ _HMG_SYSDATA[ 91, i]
nDivw := aa //
nDivh := bb //
form_1.m1.value:=str(nMainW)
form_1.m2.value:=str(nMainH)
form_1.m3.value:=str(nWidth)
form_1.m4.value:=str(nHeight)
form_1.m5.value:=str(nDivw)+'ndivw'
form_1.m6.value:=str(nDivh)+'ndivh'
form_1.m7.value:=str(_HMG_SYSDATA[ 92, i ])
form_1.m8.value:=str(_HMG_SYSDATA[ 91, i ])
*form_1.settore.value:=str(nMainW)+str(nMainH)+str(nWidth)+str(nHeight)
ControlCount := LEN ( _HMG_SYSDATA[ 3 ] )
FOR k := 1 To ControlCount
ControlName := _HMG_SYSDATA[ 2, k ]
IF _IsControlDefined ( ControlName, ParentForm )
ControlType := _HMG_SYSDATA[ 1, k ]
IF !EMPTY( ControlName ) .AND. !( ControlType $ "MENU,HOTKEY,TOOLBAR,MESSAGEBAR,ITEMMESSAGE,TIMER" )
DO CASE
CASE ControlType == "LABEL"
_SetControlSizePos( ControlName, ParentForm,;
_GetControlRow( ControlName, ParentForm ) / nDivh, ; // row
_GetControlCol ( ControlName, ParentForm ) / nDivw ,; // column
_GetControlWidth( ControlName, ParentForm ) / nDivw ,; // with
_GetControlHeight ( ControlName, ParentForm)/ nDivh ) // height
form_1.settore.value:=str(_GetControlRow( ControlName, ParentForm ) )+str(ndivh)
CASE ControlType $ "RADIOGROUP,TEXT,BUTTON"
_GetControlWidth( ControlName, ParentForm ) / nDivw,; // with
_GetControlHeight ( ControlName, ParentForm ) / nDivh) // height
CASE ControlType == "SLIDER"
_SetControlSizePos ( ControlName, ParentForm,;
_GetControlRow ( ControlName, ParentForm ) * nDivh, _GetControlCol ( ControlName, ParentForm ) * nDivw,;
_GetControlWidth ( ControlName, ParentForm ) * nDivw, _GetControlHeight ( ControlName, ParentForm ) * nDivh )
CASE ControlType == "STATUSBAR"
// do nothing
CASE !ControlType $ "TOOLBUTTON"
_GetControlWidth ( ControlName, ParentForm )* nDivw, _GetControlHeight ( ControlName, ParentForm ) * nDivh )
OTHERWISE
IF EMPTY( _HMG_SYSDATA[ 28, k ] )
_SetFontSize ( ControlName, ParentForm , 8 * nDivh )
_SetFontSize ( ControlName, ParentForm , _HMG_SYSDATA[28] [k] * nDivh )
ENDCASE
NEXT k
_HMG_SYSDATA[92] :=nWidth
_HMG_SYSDATA[91] :=nHeight
IF lvisible
ShowWindow ( hWnd )
FUNCTION ISAPPXPTHEMED()
RETURN ( OS_ISWINXP_OR_LATER() ; // <= hrb\contrib/hbwin/legacycv.c
.AND. IsAppThemed() ) // <= HMG\h_window.prg
emzampi wrote: ...
Embed your code lines between "code" and "/code" tags. "Tags" should be enclosed by brackets.
You can use "Code" button of post editor:
There isn't a "file insert" option; you need copy and past. You can use "attachment" option for long files.
emzampi
Post by emzampi »
thanks esgici
 * http://www.hmgforum.com//
Function Main()
*ALTD()
ggw= 1360
ggh= 600
      WIDTH ggw;
      HEIGHT ggh ;
      MAIN;
      TITLE 'Button Test'
      DEFINE MAIN MENU
              POPUP 'Test'
                SEPARATOR
              END POPUP
      END MENU
      @ 70,1200 BUTTON Button_1 PICTURE "button.bmp" WIDTH 50 HEIGHT 50
  Form_1.Maximize
      k,;                    // Control no
      ParentForm,;
      ControlCount,;
      ControlName,;
      ControlType,;
      nWidth,;
      nHeight,;
      lvisible := .T.,;
      nDivw,;
      nDivh
   HideWindow ( hWnd )
   lvisible := .F.
ParentForm := _HMG_SYSDATA[66] [i]
    nDivw := aa //
   nDivh :=  bb //
          DO CASE
                  _GetControlHeight ( ControlName, ParentForm)/ nDivh   ,;      // height
		             _SetFontSize ( ControlName, ParentForm , 10 * nDivh ))
                  // do nothing
          OTHERWISE
          ENDCASE
NEXT k
_HMG_SYSDATA[92] [i] :=nWidth
_HMG_SYSDATA[91] [i] :=nHeight
IF lvisible
   ShowWindow ( hWnd )
emzampi
Post by emzampi »
sorry but you do not think it will be useful this change 'course improved' which would make visible objects on a desktop other than the one with which he had planned layaut (examples of 1360 * 768 ==> 800 * 600) just by changing a few lines the program ??
ggw= 1200
ggh= 600
WIDTH ggw;
HEIGHT ggh ;
MAIN;
I think it could be usefull, but I can't test it now while I have no time now.
emzampi
Post by emzampi »
thanks Serge
for having expressed your thoughts, because I began to wonder if this is not a problem other problem users of HMG
