Special folders
Special folders
Hi
A little work to obtain paths of special folders of windows.
Thanks to inspiration by friend Dave :)
Screen shoot<br />  of Special Folders test prg
Screen shoot
SpFldTst.zip
Source files (.hbp, .prg) of Special Folders test prg
(2.95 KiB) Downloaded 534 times
Re: Special folders
Hi Esgici.
Very good !!!
Claudio.
Re: Special folders
Very nice amigo Esgici ! Thank for your sharing !
Re: Special folders
Very useful Esgici.
I am very particular about the fonts folder for HMG_HPDF. Thanks.
Re: Special folders
Nice & thank you for sharing
Re: Special folders
Hi
Found a more sophisticated and useful sample :
http://www.hexcentral.com/articles/foxpro-folders.htm
This is a foxpro function and seems could be adapt to Harbour.
But require a bit low-level expertness; because include something like shell32, ole32 :(
I hope that my amigo Pablo Cesar could achieve this task.
TIA
Re: Special folders
Hi Esgici.
I hope you find it useful.
GET_FOLDER_LINK (id_SHGFP_TYPE, id_CSIDL) ---> Return cFolder
Claudio.
// (c) Dr. Claudio Soto, 6 Mayo 2010
// see CSIDL_XXX description in ---> http://msdn.microsoft.com/en-us/library/windows/desktop/bb762494(v=vs.85).aspx
// define CSIDL_XXX in file     ---> shlobj.h
//  id_CSIDL
#define CSIDL_DESKTOP	0
#define CSIDL_INTERNET  1
#define CSIDL_PROGRAMS	2
#define CSIDL_CONTROLS	3
#define CSIDL_PRINTERS	4
#define CSIDL_PERSONAL	5
#define CSIDL_FAVORITES	6
#define CSIDL_STARTUP	7
#define CSIDL_RECENT	8
#define CSIDL_SENDTO	9
#define CSIDL_BITBUCKET	10
#define CSIDL_STARTMENU	11
#define CSIDL_MYMUSIC	13
#define CSIDL_MYVIDEO	14
#define CSIDL_DESKTOPDIRECTORY	16
#define CSIDL_DRIVES	17
#define CSIDL_NETWORK	18
#define CSIDL_NETHOOD	19
#define CSIDL_FONTS	20
#define CSIDL_TEMPLATES	21
#define CSIDL_COMMON_STARTMENU	22
#define CSIDL_COMMON_PROGRAMS	23
#define CSIDL_COMMON_STARTUP	24
#define CSIDL_COMMON_DESKTOPDIRECTORY	25
#define CSIDL_APPDATA   26
#define CSIDL_PRINTHOOD 27
#define CSIDL_LOCAL_APPDATA 28
#define CSIDL_ALTSTARTUP    29
#define CSIDL_COMMON_ALTSTARTUP	30
#define CSIDL_COMMON_FAVORITES	31
#define CSIDL_INTERNET_CACHE   32
#define CSIDL_COOKIES	33
#define CSIDL_HISTORY	34
#define CSIDL_COMMON_APPDATA	35
#define CSIDL_WINDOWS	36
#define CSIDL_SYSTEM	37
#define CSIDL_PROGRAM_FILES	38
#define CSIDL_MYPICTURES	39
#define CSIDL_PROFILE	40
#define CSIDL_SYSTEMX86	41
#define CSIDL_PROGRAM_FILESX86	42
#define CSIDL_PROGRAM_FILES_COMMON	43
#define CSIDL_PROGRAM_FILES_COMMONX86	44
#define CSIDL_COMMON_TEMPLATES	45
#define CSIDL_COMMON_DOCUMENTS	46
#define CSIDL_COMMON_ADMINTOOLS	47
#define CSIDL_ADMINTOOLS	48
#define CSIDL_CONNECTIONS	49
#define CSIDL_COMMON_MUSIC	53
#define CSIDL_COMMON_PICTURES	54
#define CSIDL_COMMON_VIDEO	55
#define CSIDL_RESOURCES	56
#define CSIDL_RESOURCES_LOCALIZED	57
#define CSIDL_COMMON_OEM_LINKS	58
#define CSIDL_CDBURN_AREA	59
#define CSIDL_COMPUTERSNEARME	61
#define CSIDL_FLAG_DONT_VERIFY	16384 // 0x4000
#define CSIDL_FLAG_CREATE	32768 // 0x8000
#define CSIDL_FLAG_MASK	65280 // 0xFF00
//  id_SHGFP_TYPE
#define SHGFP_TYPE_CURRENT  0   // Retrieve the folder's current path.
#define SHGFP_TYPE_DEFAULT  1   // Retrieve the folder's default path.
// If the folder has not been redirected, then SHGFP_TYPE_DEFAULT and SHGFP_TYPE_CURRENT retrieve the same path.
   MsgInfo (GET_FOLDER_LINK (SHGFP_TYPE_CURRENT, CSIDL_FAVORITES))
#pragma begindump
#include <windows.h>
#include <shlobj.h>
#include "hbapi.h"
// GET_FOLDER_LINK (id_SHGFP_TYPE, id_CSIDL) ---> Return cFolder
HB_FUNC (GET_FOLDER_LINK)
    TCHAR pszPath [MAX_PATH];
    DWORD id_SHGFP_TYPE = (DWORD) hb_parnl (1);
    INT   id_CSIDL      = (INT)   hb_parnl (2);
    if(SUCCEEDED (SHGetFolderPath (NULL, id_CSIDL, NULL, id_SHGFP_TYPE, pszPath)))
        hb_retc (pszPath);
        hb_retc ("ERROR: The folder does not exist");
#pragma enddump
Re: Special folders
Hi Esgici.
See application of the GET_FOLDER_LINK function in viewtopic.php?p=10535#p10535
Search recent open projects of the HMG.
Claudio.
Re: Special folders
Hola Dr.
You are a real treasure :arrow:
Are you sure that you are programming only as hobby ;)
Saludos and gracias cordiales :arrow:
Re: Special folders
Hi Brother Esgici.
esgici wrote:You are a real treasure
Thank you very much, you are very kind.
esgici wrote:Are you sure that you are programming only as hobby
Yes, I'm only programming by hobby and fun (*)
(*) I did my first virus (memory-resident Trojan in C) when he was 16 years old, all I did was clear the screen every 5 seconds and display the message: "This computer is with diarrhea", was very fun to see the cries of my friends... "teacher, teacher, teacher, the computer is with diarrhea?" and the professor responded: "computer with diarrhea? you all are crazy !!!"
Claudio.
