ComboSearchGrid
Re: ComboSearchGrid
Can I know your windows version?
Can you give a small sample?
Re: ComboSearchGrid
windows 8.1
executive windows 7 the same happens.
csgood.ZIP -THIS IS EXAMPLE WHEN DOING WELL WHEN NO INITIAL VALUES
csNOgood.ZIP -THIS IS EXAMPLE WHEN DOING WELL WHEN INITIAL VALUES
- CSGOOD.ZIP
- (1.92 MiB) Downloaded 357 times
Re: ComboSearchGrid
This is an example IF NOT DOING WELL . When entered VALUE Syntax
Re: ComboSearchGrid
Re: ComboSearchGrid
Re: ComboSearchGrid
Function p1
LOCAL proba:="A" ****DEFINE HOME VALUE
Public aItems := {}
aItems := AgendaOpen()
DEFINE WINDOW CSG AT 10, 20 ;
WIDTH 500 HEIGHT 600 ;
modal ;
nosize ;
nosysmenu ;
TITLE 'ComboSearchGrid - Sample'
DEFINE LABEL namelabel
ROW 10
COL 10
WIDTH 60
VALUE 'Name'
END LABEL
DEFINE COMBOSEARCHGRID NAME
ROW 10
COL 80
WIDTH 600
VALUE proba **** ASK VALUE COMBOSEARCHGRID
ITEMS aItems
HEADERS { 'Sifra' , 'Ime' }
WIDTHS { 300 , 170 }
JUSTIFY { 0 , 0 }
anywheresearch .t.
showheaders .t.
END COMBOSEARCHGRID
DEFINE LABEL label2
ROW 40
COL 10
WIDTH 60
VALUE 'Label 2'
END LABEL
DEFINE TEXTBOX textbox2
ROW 40
COL 80
WIDTH 200
END TEXTBOX
DEFINE BUTTON Selection
ROW 70
COL 10
WIDTH 200
CAPTION 'Click after selecting an item'
ACTION findselecteditem()
END BUTTON
CSG.CENTER
CSG.ACTIVATE
Function p1
Public aItems := {}
modal ;
nosize ;
nosysmenu ;
ROW 10
COL 10
WIDTH 60
VALUE 'Name'
END LABEL
ROW 10
COL 80
WIDTH 600
ITEMS aItems
JUSTIFY { 0 , 0 }
anywheresearch .t.
showheaders .t.
END COMBOSEARCHGRID
DEFINE LABEL label2
ROW 40
COL 10
WIDTH 60
VALUE 'Label 2'
END LABEL
ROW 40
COL 80
WIDTH 200
END TEXTBOX
ROW 70
COL 10
WIDTH 200
END BUTTON
CSG.CENTER
CSG.ACTIVATE
Re: ComboSearchGrid
Please try this...
Please try this...
#include 'hmg.ch'
#include 'hfcl_combosearchgrid.ch'
Function p1
LOCAL proba:="A"
Public aItems := {}
modal
ROW 10
COL 10
WIDTH 60
VALUE 'Name'
END LABEL
ROW 10
COL 80
WIDTH 600
ITEMS aItems
// value proba
JUSTIFY { 0 , 0 }
anywheresearch .t.
showheaders .t.
END COMBOSEARCHGRID
DEFINE LABEL label2
ROW 40
COL 10
WIDTH 60
VALUE 'Label 2'
END LABEL
ROW 40
COL 80
WIDTH 200
END TEXTBOX
ROW 70
COL 10
WIDTH 200
END BUTTON
StopControlEventProcedure( 'name', 'csg', .t. )
csg.name.value := proba
StopControlEventProcedure( 'name', 'csg', .f. )
CSG.CENTER
CSG.ACTIVATE
Function findselecteditem()
local aData := {}
local i := 0
local cMsg := ''
aData := _HMG_CSG_ItemSelected( 'CSG', 'NAME' )
if len( aData ) > 0
cMsg := '{'
for i := 1 to len( aData )
cMsg := cMsg + aData[ i ]
if i < len( aData )
cMsg := cMsg + ', '
next i
cMsg := cMsg + '}'
msginfo( 'You have selected the item - ' + cMsg )
Function AgendaOpen()
local i := 0
local aItems1 := {}
Use AGENDA Alias Agenda2 new shared
If ! File( 'Agenda2.ntx' )
Index on Nome to Agenda2
Endif
Agenda2->( DBCLearIndex() )
Agenda2->( DBSetIndex( 'Agenda2') )
Agenda2->( DbGotop() )
Agenda2->( DbSkip() )
WHILE ! Agenda2->( Eof() )
i ++
aadd( aItems1 , { ALLTRIM( Agenda2->CODIGO) , Agenda2->NOME } )
*MSGBOX(aItems1[ i ] [ 2 ])
Agenda2->( dbSkip() )
ENDDO
Return aItems1
Re: ComboSearchGrid
So doing , I need to set the initial value . I use it when selecting from the codebook . Not a problem when a new record is concerned. The problem arises when you need to correct the value of the selected item
Thank you.
Thank you.
Re: ComboSearchGrid
When you correct an item, you have to use the update feature.
Re: ComboSearchGrid
I have to show the old value to the user know what is typed . Obviously the problem in the opening window. When it enters the initial value , get information about the active window . Do not open a new window already displays a textbox based on the first window. The second window does not open . When using the MAIN window everything is working properly. But when used MODAL then dabbles
