ComboSearchGrid
Re: ComboSearchGrid
Can I know your windows version?
Can you give a small sample?
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
windows 8.1
executive windows 7 the same happens.
csgood.ZIP -THIS IS EXAMPLE WHEN DOING WELL WHEN NO INITIAL VALUES
csNOgood.ZIP -THIS IS EXAMPLE WHEN DOING WELL WHEN INITIAL VALUES
CSGOOD.ZIP
(1.92 MiB) Downloaded 358 times
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
This is an example IF NOT DOING WELL . When entered VALUE Syntax
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
Function p1
LOCAL proba:="A" ****DEFINE HOME VALUE
Public aItems := {}
aItems := AgendaOpen()
DEFINE WINDOW CSG AT 10, 20 ;
WIDTH 500 HEIGHT 600 ;
modal ;
nosize ;
nosysmenu ;
TITLE 'ComboSearchGrid - Sample'
DEFINE LABEL namelabel
ROW 10
COL 10
WIDTH 60
VALUE 'Name'
END LABEL
DEFINE COMBOSEARCHGRID NAME
ROW 10
COL 80
WIDTH 600
VALUE proba **** ASK VALUE COMBOSEARCHGRID
ITEMS aItems
HEADERS { 'Sifra' , 'Ime' }
WIDTHS { 300 , 170 }
JUSTIFY { 0 , 0 }
anywheresearch .t.
showheaders .t.
END COMBOSEARCHGRID
DEFINE LABEL label2
ROW 40
COL 10
WIDTH 60
VALUE 'Label 2'
END LABEL
DEFINE TEXTBOX textbox2
ROW 40
COL 80
WIDTH 200
END TEXTBOX
DEFINE BUTTON Selection
ROW 70
COL 10
WIDTH 200
CAPTION 'Click after selecting an item'
ACTION findselecteditem()
END BUTTON
CSG.CENTER
CSG.ACTIVATE
Re: ComboSearchGrid
Please try this...
#include 'hmg.ch'
#include 'hfcl_combosearchgrid.ch'
Function p1
LOCAL proba:="A"
Public aItems := {}
                          modal
             ROW    10
             COL    10
             WIDTH  60
             VALUE  'Name'
      END LABEL
         ROW      10
         COL      80
         WIDTH   600
         ITEMS   aItems
//         value proba
         JUSTIFY {     0  ,     0  }
         anywheresearch .t.
         showheaders .t.
      END COMBOSEARCHGRID
      DEFINE LABEL label2
         ROW   40
         COL   10
         WIDTH 60
         VALUE 'Label 2'
      END LABEL
         ROW    40
         COL    80
         WIDTH 200
      END TEXTBOX
         ROW      70
         COL      10
         WIDTH   200
      END BUTTON
   StopControlEventProcedure( 'name', 'csg', .t. )
   csg.name.value := proba
   StopControlEventProcedure( 'name', 'csg', .f. )
   CSG.CENTER
   CSG.ACTIVATE
Function findselecteditem()
   local aData := {}
   local i     := 0
   local cMsg  := ''
   aData       := _HMG_CSG_ItemSelected( 'CSG', 'NAME' )
   if len( aData ) > 0
      cMsg := '{'
      for i := 1 to len( aData )
         cMsg := cMsg + aData[ i ]
         if i < len( aData )
            cMsg := cMsg + ', '
      next i
      cMsg := cMsg + '}'
      msginfo( 'You have selected the item - ' + cMsg )
Function AgendaOpen()
    local i := 0
    local aItems1 := {}
	Use AGENDA Alias Agenda2 new shared
	If ! File( 'Agenda2.ntx' )
	       Index on Nome  to Agenda2
	Endif
	Agenda2->( DBCLearIndex()         )
	Agenda2->( DBSetIndex( 'Agenda2') )
	Agenda2->( DbGotop()              )
	Agenda2->( DbSkip()               )
	WHILE ! Agenda2->( Eof() )
	  i ++
      aadd( aItems1 , { ALLTRIM( Agenda2->CODIGO) , Agenda2->NOME } )
      *MSGBOX(aItems1[ i ] [ 2 ])
      Agenda2->( dbSkip() )
   ENDDO
Return  aItems1
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
So doing , I need to set the initial value . I use it when selecting from the codebook . Not a problem when a new record is concerned. The problem arises when you need to correct the value of the selected item
Thank you.
Re: ComboSearchGrid
When you correct an item, you have to use the update feature.
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
I have to show the old value to the user know what is typed . Obviously the problem in the opening window. When it enters the initial value , get information about the active window . Do not open a new window already displays a textbox based on the first window. The second window does not open . When using the MAIN window everything is working properly. But when used MODAL then dabbles
