Digital Image Processing
Hola
Aquí saliendo de la depresión de ya no tener trabajo fijo...
Tomando como base: \HMG\3.4.4\SAMPLES\BosTaurus\Demo10.prg
del Dr. Claudio Soto.
Hi
Here coming out of the depression of no longer having a steady job ...
Based on: \HMG\3.4.4\SAMPLES\BosTaurus\Demo10.prg
by Dr. Claudio Soto.
QDIP_AGL.zip
(1.47 MiB) Downloaded 184 times
Re: Digital Image Processing
+10 Fabuloso !
Saludos Andrés
Hola
* Ahora se puede cargar, procesar y salvar una imagen... ( JPG / PNG )
Hi
* Now you can load, process and save an image ... ( JPG / PNG )
* Manejar Brillantes y Contraste...
* Handle Bright and Contrast...
QDIP_AGL.zip
(1.47 MiB) Downloaded 159 times
Thanks Andrés and a happy birthday !!
jairpinho
Post by jairpinho »
congratulations great job
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Bueno, parece que me tope con el primer problema...
BT_BitmapGammaCorrect( hBitmap, RedGamma, GreenGamma, BlueGamma )
"RedGamma: is the Gamma Red color level to change (normally range between 0.2 and 5.0, none = 1.0)"
La función BT_BitmapGammaCorrect() maneja valores con decimales y al parecer esto no puede hacerse con los incrementos del control:
@ <nRow> ,<nCol> SPINNER <ControlName> . . . INCREMENT <nIncrement>
Alguna idea de como manejarlo ?
Well, I seem to run into the first problem ...
BT_BitmapGammaCorrect (hBitmap, RedGamma, GreenGamma, BlueGamma)
The BT_BitmapGammaCorrect () function handles values with decimals and apparently this cannot be done with the increments of the control:
@ <nRow>, <nCol> SPINNER <ControlName>. . . INCREMENT <nIncrement>
Any idea how to handle it?
edk
Post by edk »
andyglezl wrote: Tue Nov 10, 2020 7:32 pm Bueno, parece que me tope con el primer problema...
It's simple: for a spinner control, multiply the allowed value by 10 (min: 2, max: 50, default: 10, increment: 1), and for setting a value for the BT_BitmapGammaCorrect () function, divide it by 10.
e.g. SpinnerRed = 2, SpinnerGreen = 10, SpinnerBlue = 50
BT_BitmapGammaCorrect (hBitmap , SpinnerRed / 10 , SpinnerGreen / 10 , SpinnerBlue / 10) => BT_BitmapGammaCorrect (hBitmap , 0.2 , 1.0 , 5.0)
Perfecto, gracias por tu tiempo y tu respuesta edk
Perfect, thanks for your time and your answer edk
Ahora se puede modificar la Gamma y aplicar varios Efectos...
Now you can modify the Gamma and apply various Effects ...
QDIP_AGL.zip
(1.41 MiB) Downloaded 157 times
Andrés,
Great ! Is it possible to add effect such as 'cartoonize' ?
And ... undo?
