Detect Pendrives connected
RPC
Re: Detect Pendrives connected
Post by RPC »
mustafa wrote: Thu Mar 05, 2020 6:40 pm Hello here I put the summary code
only detect if this USB flash drive
and cancel
This last option in Win-10 disconnects
but the unit stays on
Hi Mustafa
You are right, this works on pen drive.
It does not work on external HDD
Decrypt_tools doesn't work wit bat file also. No executable file is produced.
Hola amigo RPC
Te mando un pequeño esquema como yo he compilado la aplicación
No he probado la de 32 bits ya que yo estoy trabajando con 64 bits
Build.3.4.4_64.Bat si tienes instalado HMG en otra dirección
tienes que modificar el Fichero Bat
que nada mas de des 2 cliks con el mouse se empezara a ver.
PD. hoy he probado una tarjeta de Memoria SD y el sample asumido
como PendDrive en mi ordenador -> F: y he podido hacer Back_up
Regards/Saludos
*-------------------------------------- Google ---------------------------------*
Hello Friend RPC
I send you a small scheme as I have compiled the application
I have not tried the 32-bit since I am working with 64 bits
Build.3.4.4_64.Bat if you have HMG installed in another address
you have to modify the Bat File
that nothing more than des 2 clicks with the mouse will begin to see.
P.S. Today I tried an SD Memory Card and the assumed sample
as PendDrive in my computer --> F: and I have been able to do Back_up
Regards / Saludos
mustafa wrote: Fri Mar 06, 2020 10:28 am I don't know how to interpret your writing code
I could put a small complete sample just
concerning the detection of USB PenDrive drives
With this code it only detects if this PenDrive
Inside USB Drive
 For i := 1 To 32
   If IsBit ( nBitMask , i )                 // <------ função IsBit da biblioteca LIBCT.LIB
   MsgInfo(   Aadd( aDrives, Chr(64+i)+":\" ) )
   EndIf
 Next i
here is a Function that did same
FUNCTION GetDrive( nMask )
Local cBin := NToC ( nMask, 2 )
Local nBit:= Len ( cBin ) - hb_At( '1', cBin )
RETURN Chr( nBit + 65 ) + ":"
but i call this Function when get WM_DEVICECHANGE Event
FUNCTION USB_Detect()
LOCAL nHWnd    := EventHWND()
LOCAL nMsg     := EventMSG()
LOCAL nWParam  := EventWPARAM()
LOCAL nLParam  := EventLPARAM()
LOCAL nMask, cDevice := ""
Local xRet
Local lThreatRet := hb_mutexSubscribe( s_mtxReturn, 0.00000001, @xRet )
DO CASE
   CASE lThreatRet .AND. hb_isArray ( xRet )
   	 //return message from Wait4Action thread
   	 Msginfo( xRet[1], STR( xRet[2] ) )
   CASE nMsg == WM_DEVICECHANGE
      DO CASE
         CASE nWParam == DBT_DEVICEARRIVAL
            nMask    := DeviceChangeInfo( nWParam, nLParam )
            if !Empty( nMask ) .and. nMask > 0
               cDevice := GetDrive( nMask )
            //send job
            hb_mutexNotify( s_mtxUSB, { "INSERT", cDevice, nMask, nHWnd } )
         CASE nWParam == DBT_DEVICEREMOVECOMPLETE
            //send job
            hb_mutexNotify( s_mtxUSB, { "REMOVE", cDevice, nMask, nHWnd } )
      End CASE
End Case
RETURN cDevice
so try modify Sample from edk who have told me to use MUTEX
Hi jimmy
Thanks for your interest
Regards/Saludos
RPC
Post by RPC »
Hi Mustafa
Your program uses "hmg_GFilatov.ch" I don't seem to have this header file in my C:\hmg.3.4.4\INCLUDE folder.
Could that be the reason for not compiling/linking ?
Thanks
Hi RPC
the file "hmg_GFilatov.ch" is included
in my Sample zip package, if you look
in the screenshot that I sent you in the previous Post
"hmg_GFilatov.ch" is the third after the 2 files
build.3.4.4. bat, if you look at the screenshot you only have
what to use to compile if you have HMG installed as
I have it ? or you have to modify the bat file, look
that you have to compile as represented in the screenshot
the file ---> Decrypt_Tools.hbp, see if your HMG is installed
as the Bat is say C: \ hmg.3.4.4 \ build.bat
PD: The Library of GFilatov ---> "hmg_GFilatov.ch" makes the ornament
from the box that you have to the right of the screenshot, can it be deleted?
 DEFINE WINDOW Form_003                      ;
        At 0,0 Width 650 Height 592          ;
        Title 'Decrypt_Tools Files Zip 2020' ;
        ICON "Logo"                          ;
        MAIN NOSIZE NOMAXIMIZE
        ON KEY ESCAPE ACTION Form_003.Release
        DrawWindowBoxRaised( "Form_003" , 10, 10, 500, 633 )      //<------------------ Lib "hmg_GFilatov.ch"
View Demo ---> viewtopic.php?f=8&t=5864&p=57940&hilit= ... ile#p57940
HB_ZIP_Demo_v01_New.zip
There is luck.
Hola amigos
Aqui teneis una nueva muestra de detección
USB-Pendrive , en mi Ordenador me están saliendo
las unidades que en esta muestra os presento
Me esta detectando la Tarjeta de Memoria como Letra F:
igual que la Unidad Usb y puedo mandar ficheros Zip Back-up
A través de mi sample "USB-PenDrive.exe" sin ningún
problema.
*---------------------------- Google ---------------------------*
Hello friends
Here you have a new detection sample
USB-Pendrive, on my Computer they are coming out
the units that in this sample I present to you
The Memory Card is being detected as Letter F:
same as Usb PenDrive and I can send Zip Back-up files
Through my sample "USB-PenDrive.exe" without any
problem.
USB-Detect2.zip
(131.51 KiB) Downloaded 177 times
RPC
Post by RPC »
Hi Mustafa
USB_Detect2 works.
It shows both the pen drive and also external HDD when connected.
Many thanks
Hello friend RPC
In my sample how it is marking the attached screenshot
I am marking the Hard Disk C: and D: DVD E: and the
USB-Pendrive as F: and Memory Card also as
letter F:
In your case, which Unit letters do you get? the
External Hard Drive also as letter F:?
Greetings
RPC
Post by RPC »
Hi Mustafa
I have partitioned my HDD as C:,D: and E: so I get follo SS when I attach external HDD or pendrive
