MiniGUI DBU
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
Thanks for your bug report!
Which operation with a table you did?
It is an expected behavior if you did modify of a structure of table due to the some limitations for above operation. :o
koke
DBs Used: DBF, mySql, mariaDB
Re: MiniGUI DBU
Post by koke »
I open a table with 34 fields and then selected modifications->modifying of the table but i did not modify anything and when i close the window and it shows the error
,___,
[O.o]
/)__)
KoKe
edk
Re: MiniGUI DBU
Post by edk »
Hi Grigory.
Thx for new version.
Another issue:
Try to:
1. Copy a table test.dbf (without condition)
2. Import a record from the file you copied (without condition)
3. Press END key
Bez tytułu.png (117.03 KiB) Viewed 7033 times
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
edk wrote: Wed Nov 14, 2018 2:00 pm Hi Grigory.
Another issue:
Try to:
3. Press END key
Hi Edward,
Thanks for your bug report :!:
It was my mistake at an import of the records :(
This bug was fixed already and I've attached the updated application for your further testing.
BTW The sources of this utility will be included at a next Minigui build.
I'm considering it as a template of DBU and example of using of TBrowse control for a database and array access.
MGDBU069.zip
(958.1 KiB) Downloaded 402 times
Re: MiniGUI DBU
Thanks Grigory !
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
Hi Friends,
I've attached the updated MgDBU v.0.70 application for your testing.
Thanks for your attention :!:
MGDBU070.zip
(929.68 KiB) Downloaded 357 times
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
Hi Friends,
I've attached the latest MgDBU v.0.71 application with a recent impovement.
Whatsnew:
- you can launch the mgDBU without an opened test base and then open your database with pressing F2 hotkey. 8-)
MGDBU071.zip
MgDBU v.0.71
(930.2 KiB) Downloaded 361 times
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
Hi Friends,
I've attached the latest MgDBU v.0.72 application with a recent impovement.
Whatsnew:
- an optimized resizing of a main window.
MGDBU072.zip
Updated application
(931.51 KiB) Downloaded 470 times
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: MiniGUI DBU
Post by dragancesu »
Nice, but how create and open index? Is possible?
This is error when open index
Harbour MiniGUI Errorlog File
Application: C:\test\MGDBU.exe
Date: 13/12/2018 Time: 13:43:20
Time from start: 0 days 0 hours 0 mins 19 secs
Error BASE/1075 Argument error: >
Called from SETNEWINDEX(1065) in module: MGDBU.prg
Called from OPENINDEX(1139) in module: MGDBU.prg
Called from (b)CREATETOOLBAR(329) in module: MGDBU.prg
Called from _DOCONTROLEVENTPROCEDURE(1863) in module: h_windows.prg
Called from EVENTS(1745) in module: h_events.prg
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(1497) in module: h_windows.prg
Called from MAIN(148) in module: MGDBU.prg
----------------------------- System Information ------------------------------
Workstation name...: NOVI-PC
Active user name...: Rade
Available memory...: 5467 MB
Current disk.......: C
Current directory..: test
Free disk space....: 43773 MB
Operating system...: Windows 10 10.0
MiniGUI version....: Harbour MiniGUI Extended Edition 18.11 (32-bit)
Harbour version....: Harbour 3.2.0dev (r1811161533)
Harbour built on...: Nov 17 2018 18:36:58
C/C++ compiler.....: Borland C++ 5.5.1 (32-bit)
Multi Threading....: NO
Current Work Area..: 1
-------------------------- Environmental Information --------------------------
SET ALTERNATE......: OFF
SET ALTFILE........:
SET AUTOPEN........: ON
SET AUTORDER.......: 0
SET AUTOSHARE......: 0
SET CENTURY........: ON
SET COUNT..........: 0
SET DATE FORMAT....: dd/mm/yyyy
SET DBFLOCKSCHEME..: 0
SET DEBUG..........: OFF
SET DECIMALS.......: 2
SET DEFAULT........:
SET DEFEXTENSIONS..: ON
SET DELETED........: OFF
SET DELIMCHARS.....: ::
SET DELIMETERS.....: OFF
SET DIRCASE........: 0
SET DIRSEPARATOR...: \
SET EOL............: 13
SET EPOCH..........: 1900
SET ERRORLOG.......: C:\test\ErrorLog.htm
SET EXACT..........: OFF
SET EXCLUSIVE......: ON
SET EXTRA..........: OFF
SET EXTRAFILE......:
SET FILECASE.......: 0
SET FIXED..........: OFF
SET FORCEOPT.......: OFF
SET HARDCOMMIT.....: ON
SET IDLEREPEAT.....: ON
SET LANGUAGE.......: en
SET MARGIN.........: 0
SET MBLOCKSIZE.....: 64
SET MFILEEXT.......:
SET OPTIMIZE.......: ON
SET PATH...........:
SET PRINTER........: OFF
SET PRINTFILE......: LPT1
SET SOFTSEEK.......: OFF
SET TRIMFILENAME...: .F.
SET UNIQUE.........: OFF
-------------------------- Detailed Work Area Items ---------------------------
Work Area No ......: 1
Alias .............: LAGER
Current Recno .....: 1
Current Filter ....:
Index Order .......: 1
Active Key ........: SIFRA
--------------------- Internal Error Handling Information ---------------------
Subsystem Call ....: BASE
System Code .......: 1075
Default Status ....: .F.
Description .......: Argument error
Operation .........: >
Involved File .....:
Dos Error Code ....: 0
+++++++++++++++++++++++++ Available Memory Variables ++++++++++++++++++++++++++
CFILTER TYPE C []
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
dragancesu wrote: Thu Dec 13, 2018 12:38 pm Nice, but how create and open index? Is possible?
Hi Dragan,
Thanks for your bug report.
I've uploaded an updated application with a correct index creation.
Your feedback is welcome :!:
