MiniGUI DBU
Re: MiniGUI DBU
Hello everyone
I would also wonder why the feature's browse support function has disappeared
tbrowse lost completely
Regards, Georg
Regards, Georg
Re: MiniGUI DBU
Hi Edward,edk wrote: ↑Thu Nov 08, 2018 8:13 am Hi again.Small Errat.
It works fine on my home computer, at work: on some computers it's OK, and others are not. I was looking for differences, I compared the OS version, environment settings. In the end I came to the fact that the reason is the resolution of the screen.
I made the test on one computer (Win10 v.1803, 64-bit) and here are the results:
It's correct for resolutions:
1152 x 864
1280 x 600
1280 x 720
1280 x 800
1280 x 960
1280 x 1024
1440 x 1050
1440 x 900
1600 x 900
1680 x 1050
1920 x 1080
Incorrectly at resolutions:
1024 x 768
1280 x 768
1360 x 768
1366 x 768
As you can see, it is incorrect when the screen height is set to 768 pixels.
Regards, Edward.
Thanks for your investigations and feedback.
I can not reproduce this problem in my home PC (please look at attached screenshot with resolution 1280x768).
BTW I've attached also an updated version of this application for your review.
- MGDBU065.zip
- (951.58 KiB) Downloaded 332 times
- 1260x768.png (158.4 KiB) Viewed 5486 times
Re: MiniGUI DBU
Hi Grigory.
Thanks for the new version. In the attachment, I present a video showing how TsBrowse behaves on my computer at resolutions of 1280x800 and 1024x768. Can anyone confirm it on their own computer?
Regards, Edward
Regards, Edward
Re: MiniGUI DBU
Hi Edward,
Ok, thanks for your video confirmation.
Please be so kind to revise the latest attached version.
Your feedback is welcome
- MGDBU066.zip
- Latest version for testing
- (955.09 KiB) Downloaded 346 times
Re: MiniGUI DBU
Hey,
thanks for your patience.
After changing the height of the grid header is now OK for the window height 768 px.
I did some more tests. They show that the problem occurs when the window size is set to such a height that the horizontal slider obscures the line separating the rows. I do not know if you understand me well, because my English is not the best, so I will try to present it with screenshots.
At this window height the scrolling is correct. And at this height, the records are duplicated during scrolling. The difference between windows is 1 px in height.
If we still reduce the window height by another 1 px, then they are not duplicated, but the last line (the incomplete height) is not refreshed. Can you confirm it and report it to the TsBrowse authors?
By the way, I noticed one more curiosity: the size of the window that I define in HMG does not correspond to the size of the window on the screen (the size read from the capture of the screenshot)
The size of 600 x 275 px is defined in the sources:
and the screenshot is made in the size of 586 x 268 px. (difference in dpi?)
FUNCTION Main()
DEFINE WINDOW Form1 AT 0 , 0 WIDTH 600 HEIGHT 275 TITLE 'Main' MAIN
CENTER WINDOW Form1
ACTIVATE WINDOW Form1
Return NilRe: MiniGUI DBU
Hi Edward,edk wrote: ↑Fri Nov 09, 2018 10:07 pm Hey,
Thanks for your tests and explanation.
It is a known problem in the TsBrowse library but it is not critical.
The simple workaround is a placing of the TBrowse object into a window with the NOSIZE style.
BTW Your English is a perfect in the comparison with me
Re: MiniGUI DBU
Hello Grigory.
Thanks for the info, I keep my fingers crossed for the development of TsBrowse, it seems to me that it has great potential.
It's a pity that it isn't in the official HMG.
I regret that I can't help in its development and implementation in HMG due to poor knowledge of C.
P.S. You' re very kind.
Regards, Edward.
Regards, Edward.
Re: MiniGUI DBU
Hello Edward,
Did you take a look for the following very old post at
http://www.hmgforum.com/viewtopic.php?f=8&t=1492
Re: MiniGUI DBU
I've uploaded a latest version of MiniGUI DataBase Utility for your review.
- MGDBU068.zip
- mgDBU application
- (962.28 KiB) Downloaded 328 times
Re: MiniGUI DBU
hi grigory
great job but it gives me the next error.
regards.
Application: G:\Downloads\MGDBU068\MGDBU.exe
Date: 13/11/2018 Time: 12:54:26
Time from start: 0 days 0 hours 1 mins 51 secs
Error BASE/1003 Variable does not exist: NUMERO
Called from (b)FIELDWBLOCK(0)
Called from TSBROWSE:BDATAEVAL(1554) in module: h_tbrowse.prg
Called from TSBROWSE:DRAWLINE(3453) in module: h_tbrowse.prg
Called from TSBROWSE:PAINT(9739) in module: h_tbrowse.prg
Called from TCONTROL:HANDLEEVENT(878) in module: TControl.prg
Called from TSBROWSE:HANDLEEVENT(8291) in module: h_tbrowse.prg
Called from EVENTS(94) in module: h_events.prg
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(1498) in module: h_windows.prg
Called from MAIN(143) in module: MGDBU.prg
regards.
,___,
[O.o]
/)__)
KoKe
[O.o]
/)__)
KoKe
