MiniGUI DBU
gfilatov
MiniGUI DBU
Post by gfilatov »
Hi Friends,
I've found a nice utility EMAG Software DBU by Enrico Giordano on Inet.
It was built with FiveWin library and xHarbour compiler.
This DBF Manager works very well but it have an Italian interface only.
The author didn't promise the other localization on the FiveWin forum.
Is it a problem :?:
But we have already the power MiniGUI tool :!:
My humble effort is below. There are the dummy tool buttons and menu actions now.
But it is have a basic TBROWSE features IMHO.
 * Copyright 2018 Grigory Filatov <gfilatov@inbox.ru>
 * Inspired by EMAG Software DBU https://www.emagsoftware.it
REQUEST DBFCDX
#include "minigui.ch"
#include "tsbrowse.ch"
#include "dbinfo.ch"
#command INSERT [<b4: BEFORE>] => dbInsert( <.b4.> )
#xtranslate IsMaximized ( <hWnd> ) => IsZoomed ( <hWnd> )
#define PRG_TITLE 'MiniGUI DBU Template'
Static BRW_1
Static cIni
SET PROCEDURE TO dbInsert
Procedure Main( cDBFName )
  Local lMaximized, nTop, nLeft, nWidth, nHeight
  Local cFile, nW, nH
  SET CENTURY ON
  SET DATE BRITISH
  SET EXCLUSIVE ON
  SET AUTOSCROLL OFF
  SET FONT TO "Tahoma", 9
  SET DEFAULT ICON TO "ICONA"
  DEFAULT cDBFName := "test"
  IF EMPTY( File( cFileNoExt( cDBFName ) + ".fpt" ) )
    rddSetDefault( "DBFNTX" )
    rddSetDefault( "DBFCDX" )
  USE ( GetStartupFolder() + "\" + cDBFName )
  cFile := dbInfo( DBI_FULLPATH )
  cIni := ChangeFileExt( Application.ExeName, '.ini' )
  BEGIN INI FILENAME (cIni)
	GET lMaximized SECTION "Parameters" ENTRY "Maximized" DEFAULT .T.
	GET nTop SECTION "Parameters" ENTRY "Top" DEFAULT 0
	GET nLeft SECTION "Parameters" ENTRY "Left" DEFAULT 0
	GET nWidth SECTION "Parameters" ENTRY "Width" DEFAULT 0
	GET nHeight SECTION "Parameters" ENTRY "Height" DEFAULT 0
  END INI
  DEFINE WINDOW MainWin ;
         MAIN ;
         TITLE PRG_TITLE ;
         ON MAXIMIZE Browse_OnSize() ;
         ON SIZE Browse_OnSize() ;
         ON RELEASE SaveMRUFileList()
         IF !lMaximized
           IF nTop >= 0
             MainWin.Row := nTop
           IF nLeft >= 0
             MainWin.Col := nLeft
           IF nWidth > 0
             MainWin.Width := nWidth
           IF nHeight > 0
             MainWin.Height := nHeight
         CreateMainMenu()
         CreateToolBar()
         DEFINE STATUSBAR KEYBOARD
         END STATUSBAR
         IF lMaximized
           nW := GetDesktopWidth()
           nH := MainWin.ClientHeight - GetToolBarHeight() - GetTitleHeight() + iif( IsThemed(), GetBorderHeight() + 2, 2 * GetBorderHeight() )
           nW := MainWin.ClientWidth + GetBorderWidth()
           nH := MainWin.ClientHeight - GetToolBarHeight() - GetTitleHeight() - GetBorderHeight() / 2 - 2
         CreateBrowse( GetToolBarHeight() + GetBorderHeight() / 2, 0, nW, nH )
         SetHotKeys()
  AddMRUItem( cFile, Nil )
  MainWin.Title := PRG_TITLE + " - " + cFile
  IF lMaximized
    MAXIMIZE WINDOW MainWin
  ACTIVATE WINDOW MainWin
****** End of Main ******
Static Procedure SetHotKeys()
  // <INSERT> key processing
  ON KEY INSERT ACTION { || AddRecord() }
  ON KEY F2 ACTION _dummy()
  ON KEY F3 ACTION _dummy()
  ON KEY F4 ACTION _dummy()
  ON KEY F5 ACTION { || Browse_Refresh() }
  ON KEY F6 ACTION _dummy()
  ON KEY F7 ACTION _dummy()
  ON KEY F8 ACTION _dummy()
  ON KEY F9 ACTION _dummy()
  ON KEY F11 ACTION Browse_GotoFirstCol()
  ON KEY F12 ACTION Browse_GotoLastCol()
  ON KEY CONTROL+D ACTION DuplicateRec()
  ON KEY CONTROL+I ACTION _dummy()
  ON KEY CONTROL+R ACTION _dummy()
  ON KEY CONTROL+T ACTION _dummy()
  ON KEY CONTROL+X ACTION { || QuickExit() }
Your feedback is welcome :idea:
mgDbu.zip
(926.41 KiB) Downloaded 489 times
Re: MiniGUI DBU
Thanks Grigory!
Re: MiniGUI DBU
Great stuff! Can't wait to see dummy function working!
Steed
Re: MiniGUI DBU
Post by Steed »
Thanks
edk
Re: MiniGUI DBU
Post by edk »
Hello Grigory.
I noticed the strange behavior of TSBROWSE.
If I press and hold down the "cursor down" key and scroll the records, then after reaching the last visible record, the next displayed rows take its value, not the values of physical records.
Bez tytułu.png (122.29 KiB) Viewed 6285 times
gfilatov
Re: MiniGUI DBU
Post by gfilatov »
edk wrote: Wed Nov 07, 2018 3:13 pm Hello Grigory.
Hello Edward,
Thanks for yor feedback!
I know that TSBROWSE is not perfect. But it is a best browser for the Minigui now.
Please be so kind to review the updated attached application with the last improvements.
BTW I can not reproduce above wrong behavior in this version 0.64 ;)
MGDBU064.zip
Last beta of mgDBU
(943.12 KiB) Downloaded 371 times
edk
Re: MiniGUI DBU
Post by edk »
Hi again Grigory.
gfilatov wrote: Wed Nov 07, 2018 7:36 pm Please be so kind to review the updated attached application with the last improvements.
It's looks pretty good. Like old, good Clipper TBrowse class. I like it.
Я думаю, що мені доведеться ближче подивитися на MiniGUI EE, але мені все ще бракує часу.
Edward.
Re: MiniGUI DBU
Is it the way to adapt TSBrowse to use with official HMG?
edk
Re: MiniGUI DBU
Post by edk »
Hi again.
Small Errat.
It works fine on my home computer, at work: on some computers it's OK, and others are not. I was looking for differences, I compared the OS version, environment settings. In the end I came to the fact that the reason is the resolution of the screen.
I made the test on one computer (Win10 v.1803, 64-bit) and here are the results:
It's correct for resolutions:
1152 x 864
1280 x 600
1280 x 720
1280 x 800
1280 x 960
1280 x 1024
1440 x 1050
1440 x 900
1600 x 900
1680 x 1050
1920 x 1080
Incorrectly at resolutions:
1024 x 768
1280 x 768
1360 x 768
1366 x 768
As you can see, it is incorrect when the screen height is set to 768 pixels.
Regards, Edward.
