HMG Graph based on Bos Taurus
Re: HMG Graph based on Bas Taurus
I've made a little test to find where is the problem is located.
I didn't found solution yet, but:
1. When I used Rathi's DrawGraph function in the loop, saving image to file without displaying it, after 23 regenerations images were incorrect.
	local i
	private hBitMap
	MsgInfo('Start')
	for i:=1 to 1000
		cfile :='images\im_'+strzero(i,4)+'.bmp'
		// first parameter for graph type, second image filename
		drawgraph(i%3 +1, cFile)
	next i
	msgStop('Images generated')
	quit
 return
2. When I used BosTaurus demo11.prg to generate simple bitmap:
FUNCTION Proc_Create_Logo
LOCAL hDC, BTstruct
LOCAL hBitmap, hBitmap_aux
LOCAL aRGBcolor := {153,217,234}
   // Create bitmap in memory
   hBitmap := BT_BitmapCreateNew (150, 100, aRGBcolor)
   // Create hDC to a bitmap
   hDC := BT_CreateDC (hBitmap, BT_HDC_BITMAP, @BTstruct)
     // Paint Gradient
     BT_DrawGradientFillVertical (hDC,  0,  0,  150,  100, aRGBcolor, BLACK)
     // Draw Text
     nTypeText    := BT_TEXT_TRANSPARENT + BT_TEXT_BOLD
     nAlingText   := BT_TEXT_LEFT + BT_TEXT_TOP
     nOrientation := BT_TEXT_NORMAL_ORIENTATION
     BT_DrawText (hDC, 10, 20, "HMG Casino", "Times New Roman", 14, BLACK, WHITE, nTypeText, nAlingText, nOrientation)
     // Draw Rectangle
     BT_DrawRectangle (hDC, 5, 5, 140, 90, BLUE, 2)
     // Paste image
     // hBitmap_aux := BT_BitmapLoadFile ("img.png") // load from disk
     hBitmap_aux := BT_BitmapLoadFile ("imgPNG")  // load from resource
        BT_DrawBitmapTransparent (hDC, 30, 30, 100, 100, BT_SCALE, hBitmap_aux, NIL)
     BT_BitmapRelease (hBitmap_aux)
  // Release hDC bitmap
  BT_DeleteDC (BTstruct)
Return hBitmap
and modified loop:
	for i:=1 to 1000
		 hBitmap := Proc_Create_Logo ()
		BT_BitmapSaveFile (hBitmap, cfile)
	next i
I've got all 1000 images good.
Something is wrong with code generating bars, I think
I will look into it Marek.
Instead of onchange event of the combobox if it is onlostfocus or a refresh button what happens?
There is the same problem even if I save generated graphs to file without displaying it.
I reviewed whole code of and I didn't found anything wrong :(
I have found that the same code if compiled using HMG.3.4.1, it works well!
HMG IDE is also having the same problem of hanging after sometime. It worked well in HMG.3.4.1.
So, there might be a problem in the change in the code from HMG.3.4.1 to the latest version?
I've made my code in last months with hmg343.
Can you please try in HMG3.4.2 or 3.4.1 and tell me whether the problem persists in the old version also?
HMG 342 causes problems.
Ihave not installed hmg 341, I'll try to download it and test.
I've tested with hmg 340 and hmg 341. Everything works OK.
Something was from hmg342
Thank you for the confirmation Marek. Now let us find the bug.
After few regeneration of graph, I'm getting very big file with picture - something about 1GB. Creating this file causes system hangup for minutes.
It's strange because I've declared constant width and height.
I'm still testing :)
EDIT:
I've modified my program to save bitmap immediately after creating it:
		nWidth := 610
		nHeight := 258
		hBitMap := BT_BitmapCreateNew ( nWidth, nHeight, { 196, 255, 255 } )
First few times it generates good picture, after 7-8 calls, it generated big incorrect pictures.
I can't reproduce this error in small sample :(
It's strange behaviour, because all works OK in hmg 341, source code of BosTaurus functions bt_bmp_create_24bpp, BT_BMP_CREATE and BitmapCreateNew are the same in hmg 341 and hmg 343.
Maybe something wrong with memory allocation?
