Print Windows Form
Print Windows Form
Working Example to Print Windows Form
PrintForm.rar
(19.56 KiB) Downloaded 939 times
Re: Print Windows Form
Thanks Dave :)
Successful 8-)
Happy HMG'ing
esgici wrote:Thanks Dave :)
Successful 8-)
Happy HMG'ing
Thank you, Esgici
Attached example for Saving of Window / Form [unable to compile in HMG, it is compiled in Minigui]
Any one can do necessary correction to compile in HMG
SaveForm.rar
(506.82 KiB) Downloaded 802 times
Successful 8-)
Happy HMG'ing
Thank you, Esgici
Hi Dave.
See Capture Method of HMG.
Capture a Window As a Bitmap File And Save It
Syntax:
<WindowName>.Capture [ ( cFileName , nRow , nCol , nWidth , nHeight ) ]
Excellant
Thank you, Dr. Claudio
Modified Sample Print & Save
Print&SaveForm.rar
(26.34 KiB) Downloaded 818 times
bpd2000 wrote: Modified Sample Print & Save
Thank Dave :)
I'll inspect it ...
Nice work, thanks for sharing!
I don't know if it's good place to ask my question:
Is it the way to print bitmap created in memory without saving it to temporary file?
I need to generate labels for range of goods with barcodes.
bluebird
Post by bluebird »
Friends of HMG
The Demonstration given to me in the archive printform.rar from a few sources looks like the answer to my printscreen need. However it always fails to compile with syntax errors at lines 65 67 77 79 149 151 153 155 and 157.
Has anyone else been successful?
Thanks
mol wrote:Nice work, thanks for sharing!
These are the new functions we have:
New Functions:
OpenPrinterGetDC()             -->   hDC of the current Open Printer
OpenPrinterGetPageDC()         -->   hDC of the current Page being printed
And you can use the following BosTaurus function to draw a bitmap in memory to the PageDC as above.
BT_DrawBitmap (hDC, Row, Col, Width, Height, Mode_Stretch, hBitmap)
Draws a bitmap in the Device Context (DC) specified.
hDC: is a handle to the device context.
Row, Col, Width, Height: specifies the size of the rectangle in pixels in the DC where you will draw the bitmap. For default: Row = 0, Col = 0, Width = BT_BitmapWidth(hBitmap), Height = BT_BitmapHeight(hBitmap).
Mode_Stretch: sets the mode as the bitmap is adjusts (is stretches or compresses) in the specified rectangle in the DC, it is one of the constants: BT_SCALE, BT_STRETCH or BT_COPY (defined in BosTaurus.CH).
hBitmap: is a handle to the bitmap.
bluebird wrote:Friends of HMG
Thanks
Hi Bill
Please don't worry, here you are between friends :arrow:
Probably this is week end and orijinal author of program (our Dear Friend Dave) not have enough spear time.
Here slightly modified to working version of orijinal program:
Result:
Source:
PrintFormSource.zip
(48.45 KiB) Downloaded 661 times
Executable:
PrintFormExe.zip
(1.51 MiB) Downloaded 654 times
Please note that:
- There is more points to optimize in this program
- This program is quite old and include some obsolete methods and functions
- Now we have more practical and short facilities ( Bostaurus library: BT_* functions )
So it's possible more and more adequate and short ways to achieve print / save images.
