HMG Graph based on Bos Taurus
Re: HMG Graph based on Bas Taurus
srvet_claudio wrote:
Rathinagiri wrote:In that case, how can we assign the bitmap handle to an Image control of a form?
With:
BT_HMGSetImage (cFormName, cControlName, hBitmap, lReleasePrevious)
Sets a specified bitmap into an Image Control of HMG (@...IMAGE) and automatically releases the handle of the bitmap previously associated to the Image Control.
cFormName: is the name (e.g. "Win1") of the parent window.
cControlName: is the name (e.g. "Image1") of the image control.
hBitmap: is a handle to the bitmap to set.
lReleasePrevious: releases of the hBitmap previous associate to Image Control. For default is .T.
Can somebody test this solution? In my project it does not work. What's going on?
My code is:
if lSaveToFile
		BT_BitmapSaveFile(hBitmap, cImageFileName )
		BT_DeleteDC( BTstruct )
		BT_BitmapRelease( hBitmap )
		BT_HMGSetImage (cFormName, cControlName, hBitmap, .T.)
Hi Marek,
1) open or create a bitmap
   hBitmap := BT_BitmapLoadFile ("hmg.bmp")
or
   hBitmap := BT_BitmapCreateNew (300, 200, aRGBcolor)
2) open a Device Context (DC) for read/write into bitmap and immediately close DC
   hDC := BT_CreateDC (hBitmap, BT_HDC_BITMAP, @BTstruct)
     BT_DrawGradientFillVertical (hDC,  50,  50,  200,  100, aRGBcolor, BLACK)
     nTypeText    := BT_TEXT_OPAQUE + BT_TEXT_BOLD
     nAlingText   := BT_TEXT_LEFT + BT_TEXT_TOP
     nOrientation := BT_TEXT_NORMAL_ORIENTATION
     BT_DrawText (hDC, 90, 80, " The Power of HMG ", "Times New Roman", 12, BLACK, WHITE, nTypeText, nAlingText, nOrientation)
  BT_DeleteDC (BTstruct)
3) save to disk or assign to a image control
   if lSaveToFile
Thanks!
I didn't use BT_DeleteDC (BTstruct) before BT_HMGSetImage (cFormName, cControlName, hBitmap, .T.)
I couldn't find this omission...
Now, it's working fine!
Claudio or Rathi,
I made a simple BAR graph and found 2 minor problems:
- using a value range of -200 to 200 the division of the values is not correct and the highest negative bars fall out of the picture.
- the leftmost SERIEYNAMES is positioned at the right; last occurence of SERIEYNAMES is correct.
Greetings,
aSer	      := ARRAY(1, 12 )
aVal			:= ARRAY(12)
aSERIE	   := ARRAY(1)
aCOL			:= ARRAY(1)
aCOL [1]		:= BLUE
aSERIE [1]  := 'a bit long seriename'
aSer	[1,  1] :=   -5
aSer	[1,  2] :=   -20
aSer	[1,  3] :=   -50
aSer	[1,  4] :=   -200
aSer	[1,  5] :=   -210
aSer	[1,  6] :=   -175
aSer	[1,  7] :=   -150
aSer	[1,  8] :=    100
aSer	[1,  9] :=   -188
aSer	[1, 10] :=   55
aSer	[1, 11] :=   -170
aSer	[1, 12] :=   5
aVal	[1] :=   'Jan'
aVal	[2] :=   'Feb'
aVal	[3] :=   'Mrt'
aVal	[4] :=   'Apr'
aVal	[5] :=   'May'
aVal	[6] :=   'Jun'
aVal	[7] :=   'Jul'
aVal	[8] :=   'Aug'
aVal	[9] :=   'Sep'
aVal	[10] :=   'Oct'
aVal	[11] :=   'Nov'
aVal	[12] :=   'Dec'
GRAPH BITMAP   BARS ;          // Form_1.GraphType.VALUE ;  // constants: BARS = 1, LINES = 2, POINTS = 3 are defined in i_graph.ch
   SIZE        1200, 900 ;
   SERIEVALUES aSer ;
   SERIENAMES  aSERIE ;
   SERIECOLORS aCOL ;
   SERIEYNAMES aVal ;
   PICTURE     "99,999.99" ;
   TITLE       'TITLE of a long seriename' ;
   TITLECOLOR  BLACK ;
   HVALUES     5 ;
   BARDEPTH    15 ;
   BARWIDTH    15 ;
   SEPARATION  0 ;
   LEGENDWIDTH 150 ;
   3DVIEW      .T. ;
   SHOWGRID    .T. ;
   SHOWXGRID   .T. ;
   SHOWYGRID   .T. ;
   SHOWVALUES  .T. ;
   SHOWXVALUES .T. ;
   SHOWYVALUES .T. ;
   SHOWLEGENDS .T. ;
   NOBORDER    .F. ;
   STOREIN     hBitmap
Form_DIAGRAM.Image_1.HBITMAP := hBitmap   // Assign hBitmap to the IMAGE control
I will see to it Serge.
Thanks you so much Rathi !
Rathinagiri wrote:Andy, I have modified the code to place the Values on the bar. But I don't know whether this will look good for all the other values/series.
   define window graph at 0, 0 width 1000 height 700 main
      define label selecttype
         row 10
         col 10
         width 150
         value 'Select Graph Type'
      end label
      define combobox graphtype
         row 10
         col 160
         width 100
         items { 'Bar', 'Lines', 'Points', 'Pie' }
         onchange drawgraph()
      end combobox
      define checkbox enable3d
         row 10
         col 280
         width 100
         caption 'Enable 3D'
      end checkbox
      define image grapharea
         row 50
         col 50
         width 600
         height 600
      end image
   end window
   graph.graphtype.value := 1
   graph.center
   graph.activate
function drawgraph
   local cImage := 'graph.bmp'
   local nImageWidth := 600
   local nImageHeight := 600
   local cTitle := 'Sample Graph'
   local aYValues := {"Jan","Feb","Mar","Apr","May"}
   local aData := { {14280,20420,12870,25347, 7640},;
           { 8350,10315,15870, 5347,12340},;
           {12345, -8945,10560,15600,17610} }
   local nBarDepth := 15
   local nBarWidth := 15
   local nHValues := 5
   local l3D := graph.enable3D.value
   local lGrid := .t.
   local lXGrid := .t.
   local lYGrid := .t.
   local lXVal := .t.
   local lYVal := .t.
   local nGraphType := graph.graphtype.value
   local lViewVal := .t.
   local lLegends := .t.
   local cPicture := '99,999.99'
   local aSeries := {"Serie 1","Serie 2","Serie 3"}
   local aColors := { {128,128,255}, {255,102, 10}, {55,201, 48} }
   local lNoBorder := .f.
   local nLegendWidth := 50
   if graph.graphtype.value == 0
      return nil
   if graph.graphtype.value == 4 // pie
      drawpiegraphinBitMap( cImage, nImageWidth, nImageHeight, {1500,1800,200,500,800}, {"Product 1","Product 2","Product 3","Product 4","Product 5"}, {{255,0,0},{0,0,255},{255,255,0},{0,255,0},{255,128,64},{128,0,128}}, "Sales", 25, l3D, lxval, lLegends, lnoborder )
      graphsave( cImage, nImageWidth, nImageHeight, aData,  cTitle, aYValues, nBarDepth, nBarWidth, nil, nHValues, l3d, lGrid, lXGrid, lYGrid, ;
               lXVal, lYVal, lLegends, aSeries, aColors, nGraphType, lViewVal, cPicture, nLegendWidth ,lNoBorder )
   graph.grapharea.picture := 'graph.bmp'
   return nil
function graphsave( cImageFileName, nWidth, nHeight, aData, cTitle, aYVals, nBarD, nWideB, nSep, nXRanges, ;
	              l3D, lGrid, lxGrid, lyGrid, lxVal, lyVal, lLegends, aSeries, aColors, nType, lViewVal, cPicture , nLegendWindth , lNoborder )
   LOCAL nI, nJ, nPos, nMax, nMin, nMaxBar, nDeep
   LOCAL nRange, nResH, nResV,  nWide, aPoint, cName
   LOCAL nXMax, nXMin, nHigh, nRel, nZero, nRPos, nRNeg
   local hBitMap, hDC, BTStruct
   local nTop := 0
   local nLeft := 0
   local nBottom := nHeight
   local nRight := nWidth
	DEFAULT cTitle   := ""
	DEFAULT nSep     := 0
	DEFAULT cPicture := "999,999.99"
	DEFAULT nLegendWindth := 50
   private nPenWidth := 1
	If ( HMG_LEN (aSeries) != HMG_LEN ( aData ) ) .or. ;
		( HMG_LEN ( aSeries ) != HMG_LEN ( aColors ) )
		MsgHMGError("DRAW GRAPH: 'Series' / 'SerieNames' / 'Colors' arrays size mismatch. Program terminated", "HMG Error" )
	EndIf
   hBitMap := BT_BitmapCreateNew ( nWidth, nHeight, { 255, 255, 255 } )
   hDC := BT_CreateDC( hBitMap, BT_HDC_BITMAP, @BTStruct )
   IF lGrid
      lxGrid := lyGrid := .T.
   IF nBottom <> NIL .AND. nRight <> NIL
      nHeight := nBottom - nTop / 2
      nWidth  := nRight - nLeft / 2
      nBottom -= IF( lyVal, 42, 32)
      nRight  -= IF( lLegends, 32 + nLegendWindth , 32 )
   nTop    += 1 + IF( Empty( cTitle ), 30, 44 )             // Top gap
   nLeft   += 1 + IF( lxVal, 80 + nBarD, 30 + nBarD )     // LEFT
   DEFAULT nBottom := nHeight - 2 - IF( lyVal, 40, 30 )    // Bottom
   DEFAULT nRight  := nWidth - 2 - IF( lLegends, 30 + nLegendWindth , 30 ) // RIGHT
   l3D     := IF( nType == POINTS, .F., l3D )
   nDeep   := IF( l3D, nBarD, 1 )
   nMaxBar := nBottom - nTop - nDeep - 5
   nResH   := nResV := 1
   nWide   := ( nRight - nLeft )* nResH / ( nMax( aData ) + 1 ) * nResH
   // Graph area
   IF ! lNoborder
	   DrawWindowBoxInBitMap( hDC, Max( 1, nTop - 44 ), Max( 1, nLeft - 80 - nBarD ), nHeight - 1, nWidth - 1 )
   // Back area
   IF l3D
      drawrectinbitmap( hDC, nTop+1, nLeft, nBottom - nDeep, nRight, { 255, 255, 255 } )
      drawrectinbitmap( hDC, nTop-5, nLeft, nBottom, nRight, { 255, 255, 255 } )
   IF l3D
      // Bottom area
      FOR nI := 1 TO nDeep+1
          DrawLineinbitmap( hDC, nBottom-nI, nLeft-nDeep+nI, nBottom-nI, nRight-nDeep+nI, { 255, 255, 255 } )
      NEXT nI
      // Lateral
          DrawLineinbitmap( hDC, nTop+nI, nLeft-nI, nBottom-nDeep+nI, nLeft-nI, {192, 192, 192} )
      NEXT nI
      // Graph borders
          DrawLineinbitmap( hDC, nBottom-nI     ,nLeft-nDeep+nI-1 ,nBottom-nI     ,nLeft-nDeep+nI  ,GRAY )
          DrawLineinbitmap( hDC, nBottom-nI     ,nRight-nDeep+nI-1,nBottom-nI     ,nRight-nDeep+nI ,BLACK )
          DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-1 ,nTop+nDeep-nI+1,nLeft-nDeep+nI  ,BLACK )
          DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-3 ,nTop+nDeep-nI+1,nLeft-nDeep+nI-2,BLACK )
      NEXT nI
      FOR nI=1 TO nDeep+2
          DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-3,nTop+nDeep-nI+1,nLeft-nDeep+nI-2 ,BLACK )
          DrawLineinbitmap( hDC, nBottom+ 2-nI+1,nRight-nDeep+nI ,nBottom+ 2-nI+1,nRight-nDeep+nI-2,BLACK )
      NEXT nI
      DrawLineinbitmap( hDC, nTop         ,nLeft        ,nTop           ,nRight       ,BLACK )
      DrawLineinbitmap( hDC, nTop- 2      ,nLeft        ,nTop- 2        ,nRight+ 2    ,BLACK )
      DrawLineinbitmap( hDC, nTop         ,nLeft        ,nBottom-nDeep  ,nLeft        ,GRAY  )
      DrawLineinbitmap( hDC, nTop+nDeep   ,nLeft-nDeep  ,nBottom        ,nLeft-nDeep  ,BLACK )
      DrawLineinbitmap( hDC, nTop+nDeep   ,nLeft-nDeep-2,nBottom+ 2     ,nLeft-nDeep-2,BLACK )
      DrawLineinbitmap( hDC, nTop         ,nRight       ,nBottom-nDeep  ,nRight       ,BLACK )
      DrawLineinbitmap( hDC, nTop- 2      ,nRight+ 2    ,nBottom-nDeep+2,nRight+ 2    ,BLACK )
      DrawLineinbitmap( hDC, nBottom-nDeep,nLeft        ,nBottom-nDeep  ,nRight       ,GRAY  )
      DrawLineinbitmap( hDC, nBottom      ,nLeft-nDeep  ,nBottom        ,nRight-nDeep ,BLACK )
      DrawLineinbitmap( hDC, nBottom+ 2   ,nLeft-nDeep-2,nBottom+ 2     ,nRight-nDeep ,BLACK )
   // Graph info
   IF !Empty(cTitle)
      DrawTextInBitmap( hDC, nTop - 30 * nResV, nLeft, cTitle, 'Arial', 12, RED, 2 )
   // Legends
   IF lLegends
      nPos := nTop
      FOR nI := 1 TO HMG_LEN( aSeries )
         DrawBarinbitmap( hDC, nRight+(8*nResH), nPos+(9*nResV), 8*nResH, 7*nResV, l3D, 1, aColors[nI] )
         DrawTextInBitmap( hDC, nPos, nRight+(20*nResH), aSeries[nI], 'Arial', 8, BLACK, 0 )
         nPos += 18*nResV
      NEXT nI
   // Max, Min values
   nMax := 0
   FOR nJ := 1 TO HMG_LEN(aSeries)
      FOR nI :=1 TO HMG_LEN(aData[nJ])
         nMax := Max( aData[nJ][nI], nMax )
      NEXT nI
   NEXT nJ
   nMin := 0
         nMin := Min( aData[nJ][nI], nMin )
      NEXT nI
   NEXT nJ
   nXMax := IF( nMax > 0, DetMaxVal( nMax ), 0 )
   nXMin := IF( nMin < 0, DetMaxVal( nMin ), 0 )
   nHigh := nXMax + nXMin
   nMax  := Max( nXMax, nXMin )
   nRel  := ( nMaxBar / nHigh )
   nMaxBar := nMax * nRel
   nZero := nTop + (nMax*nRel) + nDeep + 5    // Zero pos
   IF l3D
          DrawLineinbitmap( hDC, nZero-nI+1, nLeft-nDeep+nI   , nZero-nI+1, nRight-nDeep+nI, {192, 192, 192} )
      NEXT nI
          DrawLineinbitmap( hDC, nZero-nI+1, nLeft-nDeep+nI-1 , nZero-nI+1, nLeft -nDeep+nI, GRAY )
          DrawLineinbitmap( hDC, nZero-nI+1, nRight-nDeep+nI-1, nZero-nI+1, nRight-nDeep+nI, BLACK )
      NEXT nI
      DrawLineinbitmap( hDC, nZero-nDeep, nLeft, nZero-nDeep, nRight, GRAY )
   aPoint := Array( HMG_LEN( aSeries ), HMG_LEN( aData[1] ), 2 )
   nRange := nMax / nXRanges
   // xLabels
   nRPos := nRNeg := nZero - nDeep
   FOR nI := 0 TO nXRanges
      IF lxVal
         IF nRange*nI <= nXMax
            DrawTextInBitmap( hDC, nRPos, nLeft-nDeep-70, Transform(nRange*nI, cPicture), 'Arial', 8, BLUE )
         IF nRange*(-nI) >= nXMin*(-1)
            DrawTextInBitmap( hDC, nRNeg, nLeft-nDeep-70, Transform(nRange*-nI, cPicture), 'Arial', 8, BLUE )
      IF lxGrid
            IF l3D
               FOR nJ := 0 TO nDeep + 1
                  DrawLineinbitmap( hDC, nRPos + nJ, nLeft - nJ - 1, nRPos + nJ, nLeft - nJ, BLACK )
               NEXT nJ
            DrawLineinbitmap( hDC, nRPos, nLeft, nRPos, nRight, BLACK )
         IF nRange*-nI >= nXMin*-1
            IF l3D
                  DrawLineinbitmap( hDC, nRNeg + nJ, nLeft - nJ - 1, nRNeg + nJ, nLeft - nJ, BLACK )
               NEXT nJ
            DrawLineinbitmap( hDC, nRNeg, nLeft, nRNeg, nRight, BLACK )
      nRPos -= ( nMaxBar / nXRanges )
      nRNeg += ( nMaxBar / nXRanges )
   NEXT nI
   IF lYGrid
      nPos:=IF(l3D, nTop, nTop-5 )
      nI  := nLeft + nWide
      FOR nJ := 1 TO nMax(aData)
         DrawlineinBitmap( hDC, nBottom-nDeep, nI, nPos, nI, {100,100,100} )
         DrawlineinBitmap( hDC, nBottom, nI-nDeep, nBottom-nDeep, nI, {100,100,100} )
         nI += nWide
   DO WHILE .T.    // Bar adjust
      nPos = nLeft + ( nWide / 2 )
      nPos += ( nWide + nSep ) * ( HMG_LEN(aSeries) + 1 ) * HMG_LEN(aData[1])
      IF nPos > nRight
         nWide--
         EXIT
   ENDDO
   nMin := nMax / nMaxBar
   nPos := nLeft + ( ( nWide + nSep ) / 2 )            // first point graph
   nRange := ( ( nWide + nSep ) * HMG_LEN(aSeries) ) / 2
   IF lyVal .AND. HMG_LEN( aYVals ) > 0                // Show yLabels
      nWideB  := ( nRight - nLeft ) / ( nMax(aData) + 1 )
      nI := nLeft + nWideB
         cName := "yVal_Name_"+LTRIM(STR(nJ))
         DrawTextInBitmap( hDC, nBottom + 8, nI - nDeep - IF(l3D, 0, 8), aYVals[nJ], 'Arial', 8, BLUE )
         nI += nWideB
   // Bars
	IF nType == BARS
		if nMin <> 0
			FOR nI=1 TO HMG_LEN(aData[1])
				FOR nJ=1 TO HMG_LEN(aSeries)
					DrawBarinbitmap( hDC, nPos, nZero, aData[nJ,nI] / nMin + nDeep, nWide, l3D, nDeep, aColors[nJ] )
					nPos += nWide+nSep
				NEXT nJ
				nPos += nWide+nSep
			NEXT nI
   // Lines
   IF nType == LINES
      if nMin <> 0
         nPos := nLeft + nWideB
         FOR nI := 1 TO HMG_LEN(aData[1])
               IF !l3D
                  DrawPointinBitmap( hDC, nType, nPos, nZero, aData[nJ,nI] / nMin + nDeep, aColors[nJ] )
               aPoint[nJ,nI,2] := nPos
               aPoint[nJ,nI,1] := nZero - ( aData[nJ,nI] / nMin + nDeep )
            NEXT nJ
            nPos += nWideB
         NEXT nI
         FOR nI := 1 TO HMG_LEN(aData[1])-1
               IF l3D
                  drawpolygoninbitmap(hDC,{{aPoint[nJ,nI,1],aPoint[nJ,nI,2]},{aPoint[nJ,nI+1,1],aPoint[nJ,nI+1,2]}, ;
                              {aPoint[nJ,nI+1,1]-nDeep,aPoint[nJ,nI+1,2]+nDeep},{aPoint[nJ,nI,1]-nDeep,aPoint[nJ,nI,2]+nDeep}, ;
                              {aPoint[nJ,nI,1],aPoint[nJ,nI,2]}},,,aColors[nJ])
                  DrawLineinbitmap( hDC, aPoint[ nJ, nI, 1 ], aPoint[ nJ, nI, 2 ], aPoint[ nJ, nI+1, 1 ], aPoint[ nJ, nI + 1, 2 ], aColors[ nJ ] )
            NEXT nJ
         NEXT nI
   // Points
   IF nType == POINTS
		if nMin <> 0
               aPoint[nJ,nI,1] := nZero - aData[nJ,nI] / nMin
            NEXT nJ
            nPos += nWideB
         NEXT nI
   IF lViewVal
      IF nType == BARS
         nPos := nLeft + nWide + ( ( nWide+nSep ) * ( HMG_LEN(aSeries) / 2 ) )
      FOR nI := 1 TO HMG_LEN( aData[ 1 ] )
         FOR nJ := 1 TO HMG_LEN( aSeries )
            DrawTextInBitmap( hDC, nZero - ( aData[nJ,nI] / nMin + nDeep + 18 ), IF(nType == BARS, nPos - IF(l3D, 44, 46), nPos + 10), Transform( aData[ nJ, nI ], cPicture ), 'Arial', 8 )
            nPos+= IF( nType == BARS, nWide + nSep, 0 )
         NEXT nJ
         IF nType == BARS
            nPos += nWide + nSep
            nPos += nWideB
      NEXT nI
   IF l3D
      DrawLineinbitmap( hDC, nZero, nLeft-nDeep, nZero, nRight-nDeep, BLACK )
      IF nXMax<>0 .AND. nXMin<>0
         DrawLineinbitmap( hDC, nZero-1, nLeft-2, nZero-1, nRight, RED )
function DrawWindowBoxInBitMap( hDC, row, col, rowr, colr )
   BT_DrawRectangle ( hDC, Row, Col, Colr - col, rowr - row, { 0, 0, 0 }, nPenWidth )
return nil
function drawrectinbitmap( hDC, row, col, row1, col1, aColor )
   BT_DrawFillRectangle (hDC, Row, Col, col1 - col, row1 - row, aColor, aColor, nPenWidth )
return nil
function DrawLineinbitmap( hDC, Row1, Col1, Row2, Col2, aColor )
   BT_DrawLine ( hDC, Row1, Col1, Row2, Col2, aColor, nPenWidth )
return nil
function DrawTextInBitmap( hDC, Row, Col, cText, cFontName, nFontSize, aColor, nAlign )
   default nAlign := 0
   do case
   case nAlign == 0
      BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, )
   case nAlign == 1
      BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, , BT_TEXT_RIGHT )
   case nAlign == 2
      BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, , BT_TEXT_CENTER )
   endcase
return nil
function DrawBarinbitmap( hDC, nY, nX, nHigh, nWidth, l3D, nDeep, aColor )
   LOCAL nI, nColTop, nShadow, nH := nHigh
   nColTop := ClrShadow( RGB(aColor[1],aColor[2],aColor[3]), 15 )
   nShadow := ClrShadow( nColTop, 15 )
   nColTop := {GetRed(nColTop),GetGreen(nColTop),GetBlue(nColTop)}
   nShadow := {GetRed(nShadow),GetGreen(nShadow),GetBlue(nShadow)}
   FOR nI=1 TO nWidth
      DrawLineinbitmap( hDC, nX, nY+nI, nX+nDeep-nHigh, nY+nI, aColor )  // front
   NEXT nI
   IF l3D
      // Lateral
      drawpolygoninBitmap( hDC,{{nX-1,nY+nWidth+1},{nX+nDeep-nHigh,nY+nWidth+1},;
                   {nX-nHigh+1,nY+nWidth+nDeep},{nX-nDeep,nY+nWidth+nDeep},;
                   {nX-1,nY+nWidth+1}},nShadow,,nShadow )
      // Superior
      nHigh   := Max( nHigh, nDeep )
      drawpolygoninBitmap( hDC,{{nX-nHigh+nDeep,nY+1},{nX-nHigh+nDeep,nY+nWidth+1},;
                   {nX-nHigh+1,nY+nWidth+nDeep},{nX-nHigh+1,nY+nDeep},;
                   {nX-nHigh+nDeep,nY+1}},nColTop,,nColTop )
      // Border
      DrawBoxinBitmap( hDC, nY, nX, nH, nWidth, l3D, nDeep )
STATIC FUNCTION ClrShadow( nColor, nFactor )
   LOCAL aHSL, aRGB
   aHSL := RGB2HSL( GetRed(nColor), GetGreen(nColor), GetBlue(nColor) )
   aHSL[3] -= nFactor
   aRGB := HSL2RGB( aHSL[1], aHSL[2], aHSL[3] )
RETURN RGB( aRGB[1], aRGB[2], aRGB[3] )
STATIC FUNCTION nMax(aData)
   LOCAL nI, nMax := 0
   FOR nI :=1 TO HMG_LEN( aData )
      nMax := Max( HMG_LEN(aData[nI]), nMax )
   NEXT nI
RETURN( nMax )
STATIC FUNCTION DetMaxVal(nNum)
   LOCAL nE, nMax, nMan, nVal, nOffset
   nE:=9
   nVal:=0
   nNum:=Abs(nNum)
   DO WHILE .T.
      nMax := 10**nE
      IF Int(nNum/nMax)>0
         nMan:=(nNum/nMax)-Int(nNum/nMax)
         nOffset:=1
         nOffset:=IF(nMan<=.75,.75,nOffset)
         nOffset:=IF(nMan<=.50,.50,nOffset)
         nOffset:=IF(nMan<=.25,.25,nOffset)
         nOffset:=IF(nMan<=.00,.00,nOffset)
         nVal := (Int(nNum/nMax)+nOffset)*nMax
         EXIT
      nE--
   ENDDO
RETURN (nVal)
function DrawPointinBitmap( hDC, nType, nY, nX, nHigh, aColor )
   IF nType == POINTS
         DrawCircleinBitmap( hDC, nX - nHigh - 3, nY - 3, 8, aColor )
   ELSEIF nType == LINES
      DrawCircleinBitmap( hDC, nX - nHigh - 2, nY - 2, 6, aColor )
function DrawCircleinBitmap( hDC, nCol, nRow, nWidth, aColor )
   BT_DrawFillEllipse( hDC, nCol, nRow, nWidth, nWidth, aColor, aColor, nPenWidth)
function drawpiegraphinBitMap( cImageFileName, nWidth, nHeight, series, aname, colors, ctitle, depth, l3d, lxval, lsleg, lnoborder )
   local fromrow := 0
   local fromcol := 0
   local torow := nHeight
   local tocol := nWidth
   local topleftrow := fromrow
   local topleftcol := fromcol
   local toprightrow := fromrow
   local toprightcol := tocol
   local bottomrightrow := torow
   local bottomrightcol := tocol
   local bottomleftrow := torow
   local bottomleftcol := fromcol
   local middletoprow := fromrow
   local middletopcol := fromcol + int(tocol - fromcol) / 2
   local middleleftrow := fromrow + int(torow - fromrow) / 2
   local middleleftcol := fromcol
   local middlebottomrow := torow
   local middlebottomcol := fromcol + int(tocol - fromcol) / 2
   local middlerightrow := fromrow + int(torow - fromrow) / 2
   local middlerightcol := tocol
   local fromradialrow := 0
   local fromradialcol := 0
   local toradialrow := 0
   local toradialcol := 0
   local degrees := {}
   local cumulative := {}
   local j,i,sum := 0
   local cname := ""
   local shadowcolor := {}
   local previos_cumulative
   local hDC, hBitMap, BTStruct
   if ! lnoborder
      DrawLineinbitmap( hDC, torow  ,fromcol  ,torow  ,tocol  ,WHITE)
      DrawLineinbitmap( hDC, torow-1,fromcol+1,torow-1,tocol-1,GRAY )
      DrawLineinbitmap( hDC, torow-1,fromcol  ,fromrow  ,fromcol  ,GRAY )
      DrawLineinbitmap( hDC, torow-2,fromcol+1,fromrow+1,fromcol+1,GRAY )
      DrawLineinbitmap( hDC, fromrow  ,fromcol  ,fromrow  ,tocol-1,GRAY )
      DrawLineinbitmap( hDC, fromrow+1,fromcol+1,fromrow+1,tocol-2,GRAY )
      DrawLineinbitmap( hDC, fromrow  ,tocol  ,torow  ,tocol  ,WHITE)
      DrawLineinbitmap( hDC, fromrow  ,tocol-1,torow-1,tocol-1,GRAY )
   if HMG_LEN(ALLTRIM(ctitle)) > 0
      DrawTextInBitmap( hDC, fromrow + 10, iif(HMG_LEN(ALLTRIM(ctitle)) * 12 > (tocol - fromcol),fromcol,int(((tocol - fromcol) - (HMG_LEN(ALLTRIM(ctitle)) * 12))/2) + fromcol), ALLTRIM(ctitle), 'Arial', 12, {0,0,255} )
      fromrow := fromrow + 40
   if lsleg
      if HMG_LEN(aname) * 20 > (torow - fromrow)
         msginfo("No space for showing legends")
         torow := torow - (HMG_LEN(aname) * 20)
   drawrectinbitmap( hDC, fromrow + 10, fromcol + 10, torow - 10, tocol - 10, { 255, 255, 255 } )
   if l3d
      torow := torow - depth
   fromcol := fromcol + 25
   tocol := tocol - 25
   torow := torow - 25
   fromrow := fromrow + 25
   torow := torow + 1
   tocol := tocol + 1
   for i := 1 to HMG_LEN(series)
      sum := sum + series[i]
   next i
      aadd(degrees,round(series[i]/sum * 360,0))
   next i
   sum := 0
   for i := 1 to HMG_LEN(degrees)
      sum := sum + degrees[i]
   next i
   if sum <> 360
      degrees[HMG_LEN(degrees)] := degrees[HMG_LEN(degrees)] + (360 - sum)
   sum := 0
      aadd(cumulative,sum)
   next i
   previos_cumulative := -1
   fromradialrow := middlerightrow
   fromradialcol := middlerightcol
   for i := 1 to HMG_LEN(cumulative)
      if cumulative[i] == previos_cumulative
         loop
      previos_cumulative := cumulative[i]
      shadowcolor := {iif(colors[i,1] > 50,colors[i,1] - 50,0),iif(colors[i,2] > 50,colors[i,2] - 50,0),iif(colors[i,3] > 50,colors[i,3] - 50,0)}
      do case
         case cumulative[i] <= 45
            toradialcol := middlerightcol
            toradialrow := middlerightrow - round(cumulative[i] / 45 * (middlerightrow - toprightrow),0)
            drawpieinbitmap(hDC,fromrow,fromcol,torow,tocol,fromradialrow,fromradialcol,toradialrow,toradialcol,,,colors[i])
            fromradialrow := toradialrow
            fromradialcol := toradialcol
         case cumulative[i] <= 90 .and. cumulative[i] > 45
            toradialrow := toprightrow
            toradialcol := toprightcol - round((cumulative[i] - 45) / 45 * (toprightcol - middletopcol),0)
         case cumulative[i] <= 135 .and. cumulative[i] > 90
            toradialrow := topleftrow
            toradialcol := middletopcol - round((cumulative[i] - 90) / 45 * (middletopcol - topleftcol),0)
         case cumulative[i] <= 180 .and. cumulative[i] > 135
            toradialcol := topleftcol
            toradialrow := topleftrow + round((cumulative[i] - 135) / 45 * (middleleftrow - topleftrow),0)
         case cumulative[i] <= 225 .and. cumulative[i] > 180
            toradialrow := middleleftrow + round((cumulative[i] - 180) / 45 * (bottomleftrow - middleleftrow),0)
            if l3d
               for j := 1 to depth
                  drawarcinBitMap(hDC,fromrow + j,fromcol,torow+j,tocol,fromradialrow+j,fromradialcol,toradialrow+j,toradialcol,shadowcolor)
               next j
         case cumulative[i] <= 270 .and. cumulative[i] > 225
            toradialrow := bottomleftrow
            toradialcol := bottomleftcol + round((cumulative[i] - 225) / 45 * (middlebottomcol - bottomleftcol),0)
            if l3d
               for j := 1 to depth
                  drawarcinbitmap(hDC,fromrow + j,fromcol,torow+j,tocol,fromradialrow+j,fromradialcol,toradialrow+j,toradialcol,shadowcolor)
               next j
         case cumulative[i] <= 315 .and. cumulative[i] > 270
            toradialcol := middlebottomcol + round((cumulative[i] - 270) / 45 * (bottomrightcol - middlebottomcol),0)
            if l3d
               for j := 1 to depth
               next j
         case cumulative[i] <= 360 .and. cumulative[i] > 315
            toradialcol := bottomrightcol
            toradialrow := bottomrightrow - round((cumulative[i] - 315) / 45 * (bottomrightrow - middlerightrow),0)
            if l3d
               for j := 1 to depth
               next j
         endcase
      if l3d
         drawlineinbitmap(hDC, middleleftrow, middleleftcol, middleleftrow+depth, middleleftcol, { 0, 0, 0 } )
         drawlineinbitmap(hDC, middlerightrow, middlerightcol, middlerightrow+depth, middlerightcol, { 0, 0, 0 } )
         drawarcinBitMap(hDC,fromrow + depth,fromcol,torow + depth,tocol,middleleftrow+depth,middleleftcol,middlerightrow+depth,middlerightcol )
   next i
   if lsleg
      fromrow := torow + 20 + iif(l3d,depth,0)
      for i := 1 to HMG_LEN(aname)
         drawrectinbitmap(hDC, fromrow, fromcol, fromrow + 15, fromcol + 15, colors[ i ] )
         drawtextinbitmap( hDC, fromrow, fromcol + 20, aname[i]+iif(lxval," - "+ALLTRIM(STR(series[i],19,2))+" ("+ALLTRIM(STR(degrees[i] / 360 * 100,6,2))+" %)",""), 'Arial', 8, colors[i] )
         fromrow := fromrow + 20
      next i
return nil
function drawarcinBitMap(hDC,row,col,row1,col1,rowr,colr,rowr1,colr1,penrgb,penwidth)
   if valtype(penrgb) == "U"
      penrgb = {0,0,0}
   if valtype(penwidth) == "U"
      penwidth = 1
   arcdrawbitmap( hDC ,row,col,row1,col1,rowr,colr,rowr1,colr1,penrgb,penwidth)
return nil
function drawpieinbitmap(hDC,row,col,row1,col1,rowr,colr,rowr1,colr1,penrgb,penwidth,fillrgb)
      penrgb = {0,0,0}
      penwidth = 1
   if valtype(fillrgb) == "U"
      fillrgb := {255,255,255}
      fill := .f.
      fill := .t.
   piedrawbitmap( hDC,row,col,row1,col1,rowr,colr,rowr1,colr1,penrgb,penwidth,fillrgb,fill)
return nil
function drawpolygoninbitmap( hDC, apoints, penrgb, penwidth, fillrgb )
   local xarr := {}
   local yarr := {}
   local x := 0
      penrgb = {0,0,0}
      penwidth = 1
      fill := .f.
      fill := .t.
   for x := 1 to HMG_LEN(apoints)
       aadd(xarr,apoints[x,2])
       aadd(yarr,apoints[x,1])
   next x
   polygondrawbitmap( hDC, xarr, yarr, penrgb, penwidth, fillrgb, fill )
return nil
STATIC FUNCTION RGB2HSL( nR, nG, nB )
   LOCAL nMax, nMin
   LOCAL nH, nS, nL
   IF nR < 0
      nR := Abs( nR )
      nG := GetGreen( nR )
      nB := GetBlue( nR )
      nR := GetRed( nR )
   nR := nR / 255
   nG := nG / 255
   nB := nB / 255
   nMax := Max( nR, Max( nG, nB ) )
   nMin := Min( nR, Min( nG, nB ) )
   nL := ( nMax + nMin ) / 2
   IF nMax = nMin
      nH := 0
      nS := 0
      IF nL < 0.5
         nS := ( nMax - nMin ) / ( nMax + nMin )
         nS := ( nMax - nMin ) / ( 2.0 - nMax - nMin )
      DO CASE
         CASE nR = nMax
            nH := ( nG - nB ) / ( nMax - nMin )
         CASE nG = nMax
            nH := 2.0 + ( nB - nR ) / ( nMax - nMin )
         CASE nB = nMax
            nH := 4.0 + ( nR - nG ) / ( nMax - nMin )
      ENDCASE
   nH := Int( (nH * 239) / 6 )
   IF nH < 0 ; nH += 240 ; ENDIF
   nS := Int( nS * 239 )
   nL := Int( nL * 239 )
RETURN { nH, nS, nL }
STATIC FUNCTION HSL2RGB( nH, nS, nL )
   LOCAL nFor
   LOCAL nR, nG, nB
   LOCAL nTmp1, nTmp2, aTmp3 := { 0, 0, 0 }
   nH /= 239
   nS /= 239
   nL /= 239
   IF nS == 0
      nR := nL
      nG := nL
      nB := nL
      IF nL < 0.5
         nTmp2 := nL * ( 1 + nS )
         nTmp2 := nL + nS - ( nL * nS )
      nTmp1 := 2 * nL - nTmp2
      aTmp3[1] := nH + 1 / 3
      aTmp3[2] := nH
      aTmp3[3] := nH - 1 / 3
      FOR nFor := 1 TO 3
         IF aTmp3[nFor] < 0
            aTmp3[nFor] += 1
         IF aTmp3[nFor] > 1
            aTmp3[nFor] -= 1
         IF 6 * aTmp3[nFor] < 1
            aTmp3[nFor] := nTmp1 + ( nTmp2 - nTmp1 ) * 6 * aTmp3[nFor]
            IF 2 * aTmp3[nFor] < 1
               aTmp3[nFor] := nTmp2
               IF 3 * aTmp3[nFor] < 2
                  aTmp3[nFor] := nTmp1 + ( nTmp2 - nTmp1 ) * ( ( 2 / 3 ) - aTmp3[nFor] ) * 6
      NEXT nFor
      nR := aTmp3[1]
      nG := aTmp3[2]
      nB := aTmp3[3]
RETURN { Int( nR * 255 ), Int( nG * 255 ), Int( nB * 255 ) }
STATIC PROC DrawBoxinBitmap( hDC, nY, nX, nHigh, nWidth, l3D, nDeep )
   // Set Border
   DrawLineinbitmap( hDC, nX, nY        , nX-nHigh+nDeep    , nY       , BLACK )  // LEFT
   DrawLineinbitmap( hDC, nX, nY+nWidth , nX-nHigh+nDeep    , nY+nWidth, BLACK )  // RIGHT
   DrawLineinbitmap( hDC, nX-nHigh+nDeep, nY, nX-nHigh+nDeep, nY+nWidth, BLACK )  // Top
   DrawLineinbitmap( hDC, nX, nY, nX, nY+nWidth, BLACK )                          // Bottom
   IF l3D
      // Set shadow
      DrawLineinbitmap( hDC, nX-nHigh+nDeep, nY+nWidth, nX-nHigh, nY+nDeep+nWidth, BLACK )
      DrawLineinbitmap( hDC, nX, nY+nWidth, nX-nDeep, nY+nWidth+nDeep, BLACK )
      IF nHigh > 0
         DrawLineinbitmap( hDC, nX-nDeep, nY+nWidth+nDeep, nX-nHigh, nY+nWidth+nDeep, BLACK )
         DrawLineinbitmap( hDC, nX-nHigh, nY+nDeep, nX-nHigh , nY+nWidth+nDeep, BLACK )
         DrawLineinbitmap( hDC, nX-nHigh+nDeep, nY, nX-nHigh, nY+nDeep, BLACK )
         DrawLineinbitmap( hDC, nX-nDeep, nY+nWidth+nDeep, nX-nHigh+1, nY+nWidth+nDeep, BLACK )
         DrawLineinbitmap( hDC, nX, nY, nX-nDeep, nY+nDeep, BLACK )
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include <windows.h>
#include <commctrl.h>
#include "hbapi.h"
#include <wingdi.h>
#include <winuser.h>
HB_FUNC ( PIEDRAWBITMAP )
   HDC hdc1;
   HGDIOBJ hgdiobj1,hgdiobj2;
   HPEN hpen;
   HBRUSH hbrush;
   hdc1 = (HDC) HMG_parnl (1);
   hpen = CreatePen( (int) PS_SOLID, (int) hb_parni(11), (COLORREF) RGB( (int) hb_parvni(10,1), (int) hb_parvni(10,2), (int) hb_parvni(10,3) ) );
   hgdiobj1 = SelectObject((HDC) hdc1, hpen);
   if (hb_parl(13))
      hbrush = CreateSolidBrush((COLORREF) RGB((int) hb_parvni(12,1),(int) hb_parvni(12,2),(int) hb_parvni(12,3)));
      hgdiobj2 = SelectObject((HDC) hdc1, hbrush);
      hbrush = GetSysColorBrush((int) COLOR_WINDOW);
   Pie((HDC) hdc1,(int) hb_parni(3),(int) hb_parni(2),(int) hb_parni(5),(int) hb_parni(4),(int) hb_parni(7),(int) hb_parni(6),(int) hb_parni(9),(int) hb_parni(8));
   SelectObject((HDC) hdc1,(HGDIOBJ) hgdiobj1);
   SelectObject((HDC) hdc1,(HGDIOBJ) hgdiobj2);
   DeleteObject( hpen );
   DeleteObject( hbrush );
HB_FUNC( POLYGONDRAWBITMAP )
   HDC hdc1;
   HPEN hpen;
   HBRUSH hbrush;
   POINT apoints[1024];
   int number=hb_parinfa(2,0);
   int i;
   hpen = CreatePen( (int) PS_SOLID, (int) hb_parni(5), (COLORREF) RGB( (int) hb_parvni(4,1), (int) hb_parvni(4,2), (int) hb_parvni(4,3) ) );
   if (hb_parl(7))
      hbrush = CreateSolidBrush((COLORREF) RGB((int) hb_parvni(6,1),(int) hb_parvni(6,2),(int) hb_parvni(6,3)));
   for(i = 0; i <= number-1; i++)
   apoints[i].x=hb_parvni(2,i+1);
   apoints[i].y=hb_parvni(3,i+1);
   Polygon((HDC) hdc1,apoints,number);
HB_FUNC ( ARCDRAWBITMAP )
   HDC hdc1;
   HGDIOBJ hgdiobj1;
   HPEN hpen;
   hpen = CreatePen( PS_SOLID, (int) hb_parni(11), (COLORREF) RGB( (int) hb_parvni(10,1), (int) hb_parvni(10,2), (int) hb_parvni(10,3) ) );
   hgdiobj1 = SelectObject( hdc1, hpen );
   Arc( hdc1,(int) hb_parni(3),(int) hb_parni(2),(int) hb_parni(5),(int) hb_parni(4),(int) hb_parni(7),(int) hb_parni(6),(int) hb_parni(9),(int) hb_parni(8));
   SelectObject( hdc1, hgdiobj1);
HB_FUNC( POLYBEZIERDRAWBITMAP )
   HDC hdc1;
   HGDIOBJ hgdiobj1;
   HPEN hpen;
   DWORD number=(DWORD) hb_parinfa(2,0);
   DWORD i;
   PolyBezier((HDC) hdc1,apoints,number);
#pragma ENDDUMP
I'm quoting this post from over the year ago.
I'm using Rathi's graph solution for generating bar graphs. After few regenerating graph, My app does strange screen effects. I've modified a little original code, so, I thought this is my error.
But, I'm testing original code, and after few changes, this sample works bad, too.
Try to compile this sample ang change only bar type until your graph dissappear.
Where is the error? Can sb. test it?
In my opinion, i tcan be Bos Taurus library problem...
Does it happen every time or when some one changes the graph type in a fast manner?
Everytime.
I've embedded this graph procedures in my app, and after 7-8 regenerations screen crashes (mayb because of memory usage it happens quicker).
In your sample it happens after dozen of times (after 120 hanges of graph type).
