Is it possible to display generated graph without saving it to a file?
I need to generate temporary image and hold it only in memory
The memory consumption is approximately the size of the image saved in BMP format. In practice it does not affect system performance.Rathinagiri wrote:I understand your concern. What we have is a Bitmap Handle in BosTaurus library. That we destroy after saving it to a file. For having that to be retained in the memory I don't know what impacts it will make in memory consumption.
Better Claudio answer this.
Yes. When you do not need more the image must be destroy the bitmap.mol wrote:I can destroy it later...
With:Rathinagiri wrote:In that case, how can we assign the bitmap handle to an Image control of a form?
