Labels and OnMouseHover
Hi guys!
I was interested if there is a method to create use interface similar to webpage, where label color is changed on mouse hover.
I want to share small sample which realize this idea.
Thanks to Andyglez for his tip
// OnMouseHover demo
// 2016.06.20 Marek Olszewski
	private aLabelColors := { => }
	aLabelColors [ "KAFEL1" ] := {100,100,100}
	aLabelColors [ "KAFEL2" ] := {100,200,0}
	aLabelColors [ "KAFEL3" ] := {0,200,200}
	// turn off case sensitive hash keys matching
	hb_HCaseMatch(aLabelColors, .F.)
	DEFINE WINDOW Form_Main ;
		WIDTH 640 HEIGHT 600 ;
		TITLE 'Main Window' ;
		@ 60,10 LABEL KAFEL1 ;
			WIDTH 200 HEIGHT 200 ;
			VALUE "OPTION 1";
			BACKCOLOR aLabelColors [ "KAFEL1" ];
			CENTERALIGN
		@ 60,220 LABEL KAFEL2 ;
			VALUE "OPTION 2";
			BACKCOLOR aLabelColors [ "KAFEL2" ];
			CENTERALIGN
		@ 270,220 LABEL KAFEL3 ;
			VALUE "OPTION 3";
			BACKCOLOR aLabelColors [ "KAFEL3" ];
			CENTERALIGN
		@ 270,10 LABEL KAFEL4 ;
			VALUE "STATIC OPTION NOT COLORIZED";
			BACKCOLOR {255,255,255};
			CENTERALIGN
	CENTER WINDOW Form_Main
	CREATE EVENT PROCNAME OnMouseHover( EventWPARAM(), "FORM_MAIN" )  HWND Form_Main.Handle
	ACTIVATE WINDOW Form_Main
function OnMouseHover
	param hWnd, cFormName
	LOCAL cControl := ""
	LOCAL cForm := ""
	static cPrevious := ""
	GetControlNameByHandle( hWnd, @cControl, @cForm )
	if empty(cControl)
		if !empty(cPrevious)
			// set oryginal color to previous control
			SetProperty(cFormName, cPrevious, "BackColor",aLabelColors [ cPrevious ])
			//to prevent flickering
			cPrevious := ""
			return
	// to avoid errors - eliminate changes for absent controls in aLabelColors array
	if HB_HPOS( aLabelColors,  cControl) == 0
		return
		// to avoid flickering
		if !(cControl == cPrevious)
	SetProperty(cForm, cControl, "BackColor",{255,255,0})
	cPrevious := cControl
return
I was proposed additional feature for LABEL control to Claudio for vertical center align.
In connection with this, It's possible to create interface similar to Windows 10 or www page.
Nice testing!
Re: Labels and OnMouseHover
Hola amigo Mol:
Felicidades por su aportación
Una pregunta en mi PC Windows 10 Home 64 bits
al compilar me salen la letras en la cabecera
del recuadro.
Como hago para bajarlas más al centro del recuadro.
saludos
Hello friend Mol:
Congratulations on your contribution
A question on my PC Windows 10 Home 64-bit
when compiling I get the letters in the head
of the box.
As I do to lower them closer to the center of the box.
Positioning in the middle of label needs modification of hmg h_label.prg and c_label.c library files.
I've duplicated _definelabel funcction to MOL_DefineLabel - sources in attachment.
label_SOURCE.ZIP
(4.66 KiB) Downloaded 313 times
OK, thanks
MOL_DefineLabel("KAFEL3","Form_Main", 220, 270, "My option nr 3", 200, 200,;
						"ARIAL",14, .t., .F., .T.,;
						.f., .f., .f., aLabelColors [ "KAFEL3" ], {64,64,64},;
						NIL,"kafel 3",NIL, .f., .f.,;
						.f., .f., .f. , .F. , .t. ,;
						.f.,.F.,.T.)
Last parameter causes center vertical alignment.
It's important - label defined with center vertical alignment does not supports word wrapping.
Thanks Marek !
Nice addition. I think we can include this in the next version.
Rathinagiri wrote:Nice addition. I think we can include this in the next version.
Gracias por compartir Mol !!!!
trmpluym
Post by trmpluym »
Would be nice !
