HMG Graph based on Bos Taurus
Re: HMG Graph based on Bas Taurus
andyglezl wrote:Hola
Será posible que la función BT_DrawText()
"reconozca" los saltos de linea del texto enviado como parametro ?
Hello
It is possible that the function BT_DrawText()
"recognize" the line breaks of the text sent as a parameter ?
cText := ""
cText += "algo de texto..." + HB_OsNewLine()
BT_DrawText (hDC, Row, Col, cText, cFontName, nFontSize, aFontColor, aBackColor, nTypeText, nAlingText, nOrientation)
Yes, it is possible as in: _hmg_hpdf_drawtext
Hola Dr. Soto
Ya revise la parte que me indica pero se me dificulta entenderle a las variables "_HMG_SYSDATA [ 150 ]"
y otras cosas, pense que con solo añadir "DT_WORDBREAK" a la funcion BT_DrawText( ) seria suficiente.
Me pudiera dar otras pistas de como hacerlo ? Gracias.
Hello Dr. Soto
And review the part that tells me but I understand the variables difficult "_HMG_SYSDATA [150]"
and other things, I thought that just add "DT_WORDBREAK" to BT_DrawText () function would be enough.
I could give other clues on how to do? Thank you.
andyglezl wrote:Hola Dr. Soto
Hello Dr. Soto
See this demo:
* PROGRAMA: Demo ON PAINT event
* LENGUAJE: HMG
* FECHA:    Setiembre 2012
* AUTOR:    Dr. CLAUDIO SOTO
* PAIS:     URUGUAY
* E-MAIL:   srvet@adinet.com.uy
* BLOG:     http://srvet.blogspot.com
FUNCTION MAIN
   DEFINE WINDOW Win1;
       AT 0,0;
       WIDTH  800;
       HEIGHT 600;
       MAIN;
       ON PAINT Proc_ON_PAINT ()
   CENTER WINDOW Win1
   ACTIVATE WINDOW Win1
RETURN Nil
PROCEDURE Proc_ON_PAINT
LOCAL nTypeText, cText
LOCAL hDC, BTstruct
  hDC = BT_CreateDC ("Win1", BT_HDC_INVALIDCLIENTAREA, @BTstruct)
   nTypeText  := /*BT_TEXT_TRANSPARENT +*/ BT_TEXT_BOLD + BT_TEXT_ITALIC + BT_TEXT_UNDERLINE
   cText := "The Power" + hb_osNewLine() + "of HMG"
   BT_DrawTextEx (hDC, 150, 150, 1000, 1000, cText, "Comic Sans MS", 42, YELLOW, BLACK, nTypeText, BT_TEXT_LEFT)
  BT_DeleteDC (BTstruct)
Function BT_DrawTextEx (hDC, Row, Col, Width, Height, cText, cFontName, nFontSize, aFontColor, aBackColor, nTypeText, nAlingText, nOrientation)
   aFontColor   := IF (ValType(aFontColor)   == "U", BLACK,                        aFontColor)
   aBackColor   := IF (ValType(aBackColor)   == "U", WHITE,                        aBackColor)
   nTypeText    := IF (ValType(nTypeText)    == "U", BT_TEXT_OPAQUE,               nTypeText)
   nAlingText   := IF (ValType(nAlingText)   == "U", (BT_TEXT_LEFT + BT_TEXT_TOP), nAlingText)
   nOrientation := IF (ValType(nOrientation) == "U", BT_TEXT_NORMAL_ORIENTATION,   nOrientation)
   BT_DRAW_HDC_DRAWTEXT (hDC, Col, Row, Width, Height, cText, cFontName, nFontSize, ArrayRGB_TO_COLORREF(aFontColor), ArrayRGB_TO_COLORREF(aBackColor), nTypeText, nAlingText, nOrientation)
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include <windows.h>
#include "hbapi.h"
//* BT_DRAW_HDC_DRAWTEXT (hDC, x, y, w, h, Text, FontName, FontSize, Text_Color, Back_color, Type, Align, Action)
// Type
#define BT_TEXT_OPAQUE      0
#define BT_TEXT_TRANSPARENT 1
#define BT_TEXT_BOLD        2
#define BT_TEXT_ITALIC      4
#define BT_TEXT_UNDERLINE   8
#define BT_TEXT_STRIKEOUT   16
// Align
#define BT_TEXT_LEFT        0
#define BT_TEXT_CENTER      6
#define BT_TEXT_RIGHT       2
#define BT_TEXT_TOP         0
#define BT_TEXT_BASELINE   24
#define BT_TEXT_BOTTOM      8
HB_FUNC (BT_DRAW_HDC_DRAWTEXT)
   HDC  hDC;
   HFONT hFont;
   TCHAR *Text, *FontName;
   INT FontSize;
   INT x, y, w, h;
   COLORREF Text_Color, Back_Color;
   INT Type, Align;
   double Orientation;
   INT Bold = FW_NORMAL;
   INT Italic = 0, Underline = 0, StrikeOut = 0;
   hDC         = (HDC)      HMG_parnl (1);
   x           = (INT)      hb_parni  (2);
   y           = (INT)      hb_parni  (3);
   w           = (INT)      hb_parni  (4);
   h           = (INT)      hb_parni  (5);
   Text        = (TCHAR *)  HMG_parc  (6);
   FontName    = (TCHAR *)  HMG_parc  (7);
   FontSize    = (INT)      hb_parni  (8);
   Text_Color  = (COLORREF) hb_parnl  (9);
   Back_Color  = (COLORREF) hb_parnl (10);
   Type        = (INT)      hb_parni (11);
   Align       = (INT)      hb_parni (12);
   Orientation = (double)   hb_parnd (13);
   if ((Orientation < (double) -360.0) || (Orientation > (double) 360.0))
       Orientation = (double) 0.0;
   Orientation = Orientation * (double) 10.0;   // Angle in tenths of degrees
   if ((Type & BT_TEXT_TRANSPARENT) == BT_TEXT_TRANSPARENT)
       SetBkMode(hDC, TRANSPARENT);
       SetBkColor(hDC, Back_Color);
   if ((Type & BT_TEXT_BOLD) == BT_TEXT_BOLD)
       Bold = FW_BOLD;
   if ((Type & BT_TEXT_ITALIC) == BT_TEXT_ITALIC)
       Italic = 1;
   if ((Type & BT_TEXT_UNDERLINE) == BT_TEXT_UNDERLINE)
       Underline = 1;
   if ((Type & BT_TEXT_STRIKEOUT) == BT_TEXT_STRIKEOUT)
       StrikeOut = 1;
   SetGraphicsMode (hDC, GM_ADVANCED);
   FontSize = FontSize * GetDeviceCaps (hDC, LOGPIXELSY) / 72;
        // CreateFont (Height, Width, Escapement, Orientation, Weight, Italic, Underline, StrikeOut,
        //             CharSet, OutputPrecision, ClipPrecision, Quality, PitchAndFamily, Face);
   hFont = CreateFont (0-FontSize, 0, (int)Orientation, (int)Orientation, Bold, Italic, Underline, StrikeOut,
           DEFAULT_CHARSET, OUT_TT_PRECIS, CLIP_DEFAULT_PRECIS, DEFAULT_QUALITY, DEFAULT_PITCH | FF_DONTCARE, FontName);
   SelectObject (hDC, hFont);
   SetTextColor (hDC, Text_Color);
   RECT rect;
   SetRect (&rect, x, y, x+w, y+h);
   DrawText (hDC, Text, -1, &rect, DT_NOCLIP | DT_WORDBREAK | /*DT_EXTERNALLEADING |*/ DT_NOPREFIX | Align);
   DeleteObject (hFont);
#pragma ENDDUMP
Gracias Dr. Claudio, le daré una vista
Bueno, despues de muchos dias de desvelo, les muestro lo que logré hacer con
HMG 3.4 y Bos Taurus.
Well, after many sleepless days, I show you what I got to do with
HMG 3.4 and Bos Taurus.
Wow! Looks so professional. The horizontal bar graph is so good! I like it a lot.
Gracias Rathinagiri
Bueno, tal vez tu puedas integrarlo al gran trabajo que has hecho con Graficas y Bos Taurus
Thanks Rathinagiri
Well, maybe you can integrate the great work you've done with Bos Taurus and Graphics
FUNCTION MAIN
   DEFINE WINDOW Win1 AT 0,0 WIDTH  600 HEIGHT 400 MAIN	ON PAINT Proc_ON_PAINT () BACKCOLOR { 47, 79, 79 }  TITLE "Gráfica de Barras Horizontal - By AndyGlezL"
   CENTER WINDOW Win1
RETURN Nil
	LOCAL hDC, BTstruct
	LOCAL i1, nRen := 0, nCol := 0
	PRIVATE	aCols    := { { 255, 204, 0 } , { 254, 133, 0 } , { 255, 39, 0 } , { 255, 111, 159 }  , {255, 0, 254 } , {82, 0, 82 }, ;
						  { 183, 0, 132 } , { 82, 1, 254 } , { 0, 133, 255 } , { 0, 0, 255 } , { 0, 133, 0 } , { 102, 102, 51 } }
	PRIVATE	aAyos    := { "2010", "2011", "2012", "2013", "2014", "2015" }
	PRIVATE	aSerVal  := { 20280, 15420, 12870, 8347, 6540, 4056 }
	hDC = BT_CreateDC( "Win1", BT_HDC_INVALIDCLIENTAREA, @BTstruct)
		*--------  GRAFICO DE BARRAS HORIZONTAL  ----------------------------------------------------------------
		nRen += 120	;	nCol := 150
		FOR i1 = 1 TO LEN( aSerVal )
			nShadow  := ClrShadow( aCols[ i1 ], 40 )
			nShadow2 := { GetRed( nShadow ), GetGreen( nShadow ), GetBlue( nShadow ) }
			BT_DrawGradientFillHorizontal( hDC, nRen, nCol, aSerVal[ i1 ] / 100, 30, nShadow2, aCols[ i1 ]  )	//  Barra con Gradiente
			BT_DrawLine( hDC, nRen+3 , nCol+1,  nRen+3, nCol+( aSerVal[ i1 ] / 100 )-1, WHITE , 2 )				//	Linea Brillo
			BT_DrawLine( hDC, nRen+28, nCol+1, nRen+28, nCol+( aSerVal[ i1 ] / 100 )-1, { 105, 105, 105 } , 1 )	//	Linea Sombra
			nTypeText  := BT_TEXT_TRANSPARENT + BT_TEXT_BOLD // + BT_TEXT_ITALIC + BT_TEXT_UNDERLINE 			//	nAlingText := BT_TEXT_CENTER + BT_TEXT_BASELINE
			BT_DrawText( hDC, nRen+4, nCol+5, aAyos[ i1 ], "Verdana", 8, BLUE, WHITE, nTypeText, BT_TEXT_LEFT  )		// Titulos
			BT_DrawText( hDC, nRen+13, nCol+( aSerVal[ i1 ] / 100 ), TRANSFORM( aSerVal[ i1 ], "99,999" )+" ",  ;		// Valores
						"Verdana", 8, BLACK, WHITE, nTypeText, BT_TEXT_RIGHT )
			*------------  BARRAS NEGATIVAS   ---------------------------------------
			nCol2 := nCol + aSerVal[ i1 ] / 100
			IF i1 > 1																														//  Primer Barra sin negativos
				BT_DrawGradientFillHorizontal( hDC, nRen, nCol2+3, ( ( aSerVal[ 1 ] - aSerVal[ i1 ] ) / 100 )-3, 30, { 250, 128, 114 }, RED  )	//  Barra con Gradiente
				BT_DrawLine( hDC, nRen+3 , nCol2+1,  nRen+3, nCol2+( ( aSerVal[ 1 ] - aSerVal[ i1 ] ) / 100 )-3, WHITE , 2 )				//	Linea Brillo
				BT_DrawLine( hDC, nRen+28, nCol2+1, nRen+28, nCol2+( ( aSerVal[ 1 ] - aSerVal[ i1 ] ) / 100 )-3, { 105, 105, 105 } , 1 )	//	Linea Sombra
				BT_DrawText( hDC, nRen+13, nCol2+( ( aSerVal[ 1 ] - aSerVal[ i1 ] ) / 100 ), TRANSFORM( aSerVal[ 1 ] - aSerVal[ i1 ], "-99,999" )+" ",  ;		// Valores
								"Verdana", 8, WHITE, WHITE, BT_TEXT_TRANSPARENT, BT_TEXT_RIGHT )
			nRen += 37
STATIC FUNCTION ClrShadow( nColor, nFactor )
   LOCAL aHSL, aRGB
   aHSL := RGB2HSL( GetRed(nColor), GetGreen(nColor), GetBlue(nColor) )
   aHSL[3] -= nFactor
   aRGB := HSL2RGB( aHSL[1], aHSL[2], aHSL[3] )
RETURN RGB( aRGB[1], aRGB[2], aRGB[3] )
STATIC FUNCTION RGB2HSL( nR, nG, nB )
   LOCAL nMax, nMin
   LOCAL nH, nS, nL
   IF nR < 0
      nR := Abs( nR )
      nG := GetGreen( nR )
      nB := GetBlue( nR )
      nR := GetRed( nR )
   nR := nR / 255
   nG := nG / 255
   nB := nB / 255
   nMax := Max( nR, Max( nG, nB ) )
   nMin := Min( nR, Min( nG, nB ) )
   nL := ( nMax + nMin ) / 2
   IF nMax = nMin
      nH := 0
      nS := 0
      IF nL < 0.5
         nS := ( nMax - nMin ) / ( nMax + nMin )
         nS := ( nMax - nMin ) / ( 2.0 - nMax - nMin )
      DO CASE
         CASE nR = nMax
            nH := ( nG - nB ) / ( nMax - nMin )
         CASE nG = nMax
            nH := 2.0 + ( nB - nR ) / ( nMax - nMin )
         CASE nB = nMax
            nH := 4.0 + ( nR - nG ) / ( nMax - nMin )
      ENDCASE
   nH := Int( (nH * 239) / 6 )
   IF nH < 0 ; nH += 240 ; ENDIF
   nS := Int( nS * 239 )
   nL := Int( nL * 239 )
RETURN { nH, nS, nL }
STATIC FUNCTION HSL2RGB( nH, nS, nL )
   LOCAL nFor
   LOCAL nR, nG, nB
   LOCAL nTmp1, nTmp2, aTmp3 := { 0, 0, 0 }
   nH /= 239
   nS /= 239
   nL /= 239
   IF nS == 0
      nR := nL
      nG := nL
      nB := nL
      IF nL < 0.5
         nTmp2 := nL * ( 1 + nS )
         nTmp2 := nL + nS - ( nL * nS )
      nTmp1 := 2 * nL - nTmp2
      aTmp3[1] := nH + 1 / 3
      aTmp3[2] := nH
      aTmp3[3] := nH - 1 / 3
      FOR nFor := 1 TO 3
         IF aTmp3[nFor] < 0
            aTmp3[nFor] += 1
         IF aTmp3[nFor] > 1
            aTmp3[nFor] -= 1
         IF 6 * aTmp3[nFor] < 1
            aTmp3[nFor] := nTmp1 + ( nTmp2 - nTmp1 ) * 6 * aTmp3[nFor]
            IF 2 * aTmp3[nFor] < 1
               aTmp3[nFor] := nTmp2
               IF 3 * aTmp3[nFor] < 2
                  aTmp3[nFor] := nTmp1 + ( nTmp2 - nTmp1 ) * ( ( 2 / 3 ) - aTmp3[nFor] ) * 6
      NEXT nFor
      nR := aTmp3[1]
      nG := aTmp3[2]
      nB := aTmp3[3]
RETURN { Int( nR * 255 ), Int( nG * 255 ), Int( nB * 255 ) }
Thanks a lot Andy. I will sure incorporate your code in the next version.
Thank you Andy!
Thank Mr. Andy for sharing nice code
