Phonebook code with MySQL database
MigSoft
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Post by MigSoft »
Post code phonebook with MySQL database in http://migsoft.ml/2015/06/agenda-de-contactos-mysql
Re: Phonebook code with MySQL database
Thanks Miguel!
Thank you for sharing
May be more useful for us ( HMG users ) pure-HMG and English version :?
I'm sure something like this isn't difficult for you, Miguel :)
Yo en particularidad, no preciso otro idioma para admirar el código fuente o la técnica empleada y si lo considero útil. :)
Este tu ejemplo insentiva al uso de MySQL y eso es muy bueno para abrir cabezas... (me incluyo).
Gracias Daniel por tu aporte y me gustaria verlo funcionando en HMG tambien.
Un gran abrazo
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Nice, but
for an application of this type, when using only one table, the better solution is sqlite, everyone will work and only those who make the effort to raise mysql base
Rightly said about SQLite. By the way, it is easy to convert to SQLite.
Gracias por compartir Miguel...
nikko1960
Post by nikko1960 »
thank you for sharing
a probably silly question :
if we need to connect to mariaDb in an another Pc connected via internet ( for example a pc far far away from ours ) which lines have to be changed ?
and / or wich driver we have to use
domenico
dragancesu
Function Main()
    Local i := 0
    PUBLIC cServer := "localhost" /* this line is adress of server */
    PUBLIC cUser   := "root"
    PUBLIC cPaswd  := ""
    oServer := TMySQLServer():New( cServer, cUser, cPaswd )
    if oServer:NetErr()
        oServer := Nil
        msgstop( "Conexión no establecida","Error !!! ONE")
Adress can be symbolic like localhost, server1 or ip adress like 10.0.1.100, 192.168.1.155 or same
But server must enable remote connection
