Phonebook code with MySQL database
- MigSoft
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Post code phonebook with MySQL database in http://migsoft.ml/2015/06/agenda-de-contactos-mysql
- 2015-06-06_131341.jpg (51.8 KiB) Viewed 6443 times
local adult dating platform - https://privateladyescorts.com - hookup with sexy singles
Re: Phonebook code with MySQL database
Thanks Miguel!
Thank you for sharing
- esgici
May be more useful for us ( HMG users ) pure-HMG and English version
I'm sure something like this isn't difficult for you, Miguel
Happy HMG'ing
Happy HMG'ing
Viva INTERNATIONAL HMG
Yo en particularidad, no preciso otro idioma para admirar el código fuente o la técnica empleada y si lo considero útil.
Este tu ejemplo insentiva al uso de MySQL y eso es muy bueno para abrir cabezas... (me incluyo).
Gracias Daniel por tu aporte y me gustaria verlo funcionando en HMG tambien.
Un gran abrazo
Un gran abrazo
- dragancesu
Nice, but
for an application of this type, when using only one table, the better solution is sqlite, everyone will work and only those who make the effort to raise mysql base
Rightly said about SQLite. By the way, it is easy to convert to SQLite.
Gracias por compartir Miguel...
thank you for sharing
a probably silly question :
if we need to connect to mariaDb in an another Pc connected via internet ( for example a pc far far away from ours ) which lines have to be changed ?
and / or wich driver we have to use
domenico
domenico
- dragancesu
Function Main()
Local i := 0
PUBLIC cServer := "localhost" /* this line is adress of server */
PUBLIC cUser := "root"
PUBLIC cPaswd := ""
oServer := TMySQLServer():New( cServer, cUser, cPaswd )
if oServer:NetErr()
oServer := Nil
msgstop( "Conexión no establecida","Error !!! ONE")
ENDIFBut server must enable remote connection
