ComboSearchGrid
Re: ComboSearchGrid
It is and will be working for 3.0.46 but not in 3.1.2 because, we have to accommodate all string functions to unicode first. Till such time it is for 3.0.46 only. Soon I will make for 3.1.2 too.
tonton2
Re: ComboSearchGrid
Post by tonton2 »
good evening
May I know where to find the options "ComboSearchGrid"
thank you in advance
L'Algerie vous salut
Y.TABET
Re: ComboSearchGrid
Meaning the source code?
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
Why ComboSearchGrid not compile in HMG 3.3.1
Re: ComboSearchGrid
zorpavns wrote:Why ComboSearchGrid not compile in HMG 3.3.1
Modify hmg.hbc line no. 34 from
# libs=sqlite3
to
libs=sqlite3
Now compile ComboSearchGrid
or
Add libs=sqlite3 in csg.hbc and use command line as
c:\hmg\build csg csg.hbc
Agil Abdullah
Re: ComboSearchGrid
Post by Agil Abdullah »
# libs=sqlite3
to
libs=sqlite3
or
Yes... I just tried and worked very well.... Thanks to everybody in this thread.
Programmer Never Surrender
Re: ComboSearchGrid
Hola Sr. Rathinagiri,
Al querer compilar si ejemplo en HMG3.3.1 me da el siguiente error:
Tengo que intsalar algo adicional a HMG?
Alguna sugerencia?
Re: ComboSearchGrid
OK, hice la sugerencia que hizo bpd2000 y compila bien, pero no me responde bien, voy a probar y les comento.
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
Thanks!! working
zorpavns
DBs Used: DBF, SQL
Re: ComboSearchGrid
Post by zorpavns »
I have a problem with ComboSearchGrid. I do not know how to solve . So I asked for help . When you enter the value of the variable . Figure displays outside the window . And when the value is empty doing everything right
