Draw border
Re: Draw border
Esgici,
esgici wrote: Sorry for inaccurate information
No problemo !
I thought the was the message....
No I see the problem!
Re: Draw border
now..
Carlos Britos
Re: Draw border
Post by Carlos Britos »
esgici wrote:Hi Dave
bpd2000 wrote: Where to find more about HB_Default()
Thank to your interest and nice words :)
Sadly not found (at least I don't know) any documentation about HB_Default() :(
Hi hb_Default() convert any to value to the value type of the second parameter
Sample
FUNCTION myfun( xqwe )
hb_Default( @xqwe, .T. )
xqwe will be .T. if the param is a different type.
if param = 123 -> xqwe = .T.
if param = "string" -> xqwe = .T.
if param = NIL -> xqwe = .T.
if param = .F. -> xqwe = .F.
#xcommand DEFAULT <xVar1> TO <xVal1> [, <xVarN> TO <xValN> ] => ;
hb_default( @<xVar1>, <xVal1> ) [; hb_default( @<xVarN>, <xValN> ) ]
#xcommand DEFAULT <xVar1> := <xVal1> [, <xVarN> := <xValN> ] => ;
Re: Draw border
Hi Carlos
Carlos Britos wrote:hb_Default() convert any to value to the value type of the second parameter ...
Thank to additional information.
This will be useful to me too :)
Viva HMG :D
Re: Draw border
esgici wrote:Problem is in border of image.
Attempted using BosTaurus to draw line, and
Unrecoverable error 9003: Too many recursive error handler calls
Any idea :(
TIA :D
Re: Draw border
Thank you Carlos Britos for HB_Default help
Re: Draw border
Hi All
Another implementation of "Wide Border":
Screen shoot of Wide Border - 1
TestBorder2.prg.zip
Modified prg for wide order
(794 Bytes) Downloaded 373 times
Re: Draw border
esgici wrote:By the way, I have a problem; please look at TestBorder.prg line 54-55;
will be appreciated your advice.
Hi Friend,
The DrawLine command runs a codeblock and the problem is when passing the array parameter to the codeblock.
See this fixed code:
PROCEDURE DrawWideBorder( ;
                     cWindowName,;
					 cControlName,;
					 aColor,;
					 nSpace,;
					 nStep )
	LOCAL nWidness, cColor
	HB_DEFAULT( @nSpace, 10 )
	HB_DEFAULT( @nStep, 1 )
	FOR nWidness := 1 TO nSpace STEP nStep
      cColor := "{"+hb_ntos(aColor[ 1 ])+","+hb_ntos(aColor[ 2 ])+","+hb_ntos(aColor[ 3 ])+"}"
      DRAW BORDER WINDOW cWindowName CONTROL cControlName UPCOLOR &cColor DOWNCOLOR &cColor SPACE nWidness
	   aColor[ 1 ]  -= 10
	   aColor[ 2 ]  -= 10
	   aColor[ 3 ]  += 10
    NEXT nWidness
RETURN  // DrawWideBorder()
Re: Draw border
srvet_claudio wrote: The DrawLine command runs a codeblock and the problem is when passing the array parameter to the codeblock.
Thank you very much Hidalgo :)
I'll try
Best regards :D
Re: Draw border
esgici wrote: I'll try
Hats to the air :shock:
Extremely appreciated dr. :arrow:
You are a true life-saving hidalgo 8-)
Best regards :D
