Draw border
Draw border
Hi All
Almost every control has their own border, except a few ones, like Label and image.
This is an humble work to search an easy way to draw a border around controls.
To your interest, critics and suggestions.
Screen shoot of Test Draw Border prg
Screen shoot of test DrawBorder.png (153.72 KiB) Viewed 8902 times
TestBorder.zip
Source files for Test Draw Border prg
(66.13 KiB) Downloaded 584 times
By the way, I have a problem; please look at TestBorder.prg line 54-55;
will be appreciated your advice.
Re: Draw border
Nice
Thank you Esgici
Re: Draw border
Dear Esgici,
Interesting to me
Where to find more about HB_Default()
Re: Draw border
Esgici,
Try msgbox with str(aColor [1]) + ' ' + str(aColor [2]) + ' ' + str(aColor [3]).
This should help !
Re: Draw border
Hi Esgici!
Your borders look amazing!
Tahks for sharing!
By the way, it's a pity we have no possibility to vertical align of value of label :-( It was possible in HMG4.
Maybe Rathi or Claudio can do such an improvement...
Regards, Marek
Re: Draw border
Hi Dave
bpd2000 wrote: Where to find more about HB_Default()
Thank to your interest and nice words :)
Sadly not found (at least I don't know) any documentation about HB_Default() :(
Based on my experience :
PROCEDURE Main()
   TestDefa()
RETURN // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROCEDURE TestDefa( xParam )
   MsgDebug( "Before", xParam )       // NIL
   HB_Default( @xParam, 123 )         // IF NIL, assign 123
   MsgDebug( "After", xParam )        // 123
RETURN // TestDefa()
Re: Draw border
Hi Marek
Re: Draw border
Hi Serge
serge_girard wrote: Try msgbox with str(aColor [1]) + ' ' + str(aColor [2]) + ' ' + str(aColor [3]).
This should help !
Thank to your interest and suggestion :)
I'm afraid that I couldn't tell :(
Problem isn't about Message function ( MsgDebug() is very good enhancement, thank to Dr. Soto ).
Problem is in border of image.
Please look at below image: while MsgDebug() is in screen, border seen fine,
Image border if message in it place
when Msg gone ( or replaced ) the border changes :(
Image border after message replaced
PS: don't look border of Label_4; this image is a bit older.
Draw border
Nice work Esgici, I liked !
As you said, the main problem is not based on Msg functions at all (it's my tip too). Even if you do not use msg function and minimize the main window, you will see border will be also changed. I believe it an tipic behaviour of API of OS and probably there is not solution for this... :(
But I find a way to put borders around IMAGEs:
I put an extra label with same size and position of IMAGE. This could it be not the best practice but could helps until get better solution.
#include "DrawBorder.ch"
Function Main()
* aMyColors := InitColors()
DEFINE WINDOW frmTestBorder AT 100 , 100 WIDTH 583 HEIGHT 385 ;
    TITLE "Test Border Function" ICON NIL MAIN ON INIT Draw_All() ;
    BACKCOLOR {230,230,216}
    ON KEY ESCAPE OF frmTestBorder ACTION ThisWindow.Release
    DEFINE LABEL Label_1
        ROW    20
        COL    40
        WIDTH  120
        HEIGHT 20
        VALUE "Label_1"
        FONTNAME "Verdana"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
    END LABEL
    DEFINE LABEL Label_2
        ROW    80
        COL    40
        WIDTH  120
        HEIGHT 30
        VALUE "Label_2"
        FONTNAME "Verdana"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
    END LABEL
    DEFINE LABEL Label_3
        ROW    140
        COL    40
        WIDTH  120
        HEIGHT 60
        VALUE "Label_3"
        FONTNAME "Verdana"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
    END LABEL
    DEFINE BUTTON Button_1
        ROW    280
        COL    40
        WIDTH  100
        HEIGHT 28
        ACTION Nil
        CAPTION "Button_1"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE BUTTON Button_2
        ROW    280
        COL    220
        WIDTH  100
        HEIGHT 28
        ACTION Nil
        CAPTION "Button_2"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE BUTTON Button_3
        ROW    280
        COL    420
        WIDTH  100
        HEIGHT 28
        ACTION DrawWideBorder( "frmTestBorder", "Image_1", { 164, 260, 155 } )
        CAPTION "Button_3"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE LABEL Label_4
        ROW    230
        COL    40
        WIDTH  480
        HEIGHT 20
        VALUE "Label_4"
        FONTNAME "Verdana"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
    END LABEL
	DEFINE LABEL Label_5
        ROW    41
        COL    221
        WIDTH  300
        HEIGHT 150
        VALUE ""
        FONTNAME "Verdana"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
    END LABEL
    DEFINE IMAGE Image_1
        ROW    40
        COL    220
        WIDTH  300
        HEIGHT 150
        PICTURE "HMG_Unicode.PNG"
        HELPID Nil
        VISIBLE .T.
        STRETCH .F.
        ACTION Nil
    END IMAGE
*   frmTestBorder.Center
frmTestBorder.Activate
Function Draw_All()
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Label_1"
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Label_2" PENWIDTH 3 UPCOLOR 1 DOWNCOLOR 0
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Label_3" PENWIDTH 3 UPCOLOR 0 DOWNCOLOR 1
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Label_4" PENWIDTH 3 UPCOLOR { 190, 210, 230 } DOWNCOLOR { 100, 149, 237 }
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Label_5" PENWIDTH 3 UPCOLOR 1 DOWNCOLOR 0
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Button_1"
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Button_2" PENWIDTH 3 UPCOLOR 1 DOWNCOLOR 0
DRAW BORDER WINDOW "frmTestBorder" CONTROL "Button_3" PENWIDTH 3 UPCOLOR 0 DOWNCOLOR 1
// DrawWideBorder( "frmTestBorder", "Image_1", { 164, 260, 155 } )
// DrawWideBorder( "frmTestBorder", "Label_5", { 164, 260, 155 } )
Function DrawWideBorder( cWindowName, cControlName, aColor, nSpace, nStep )
Local nWidness
HB_DEFAULT( @nSpace, 10 )
HB_DEFAULT( @nStep, 1 )
FOR nWidness := 1 TO nSpace STEP nStep
    DRAW BORDER WINDOW cWindowName CONTROL cControlName UPCOLOR aColor DOWNCOLOR aColor SPACE nWidness
    aColor[ 1 ] -= 10
    aColor[ 2 ] -= 10
    aColor[ 3 ] += 10
* Problem :
*   results of below changes on color array gone away After that msg  :(
MsgDebug( aColor )
One suggestion is to have as option of rounded border at corner if is possible. ;)
Thank you for your sharing and I also did not know about HB_DEFAULT(), thank again for sharing !
Re: Draw border
Hi Serge
esgici wrote: I'm afraid that I couldn't tell :(
Sorry for inaccurate information :(
Anyway this message was added to see ( and demonstrate ) deterioration in the border :(
