Yes. In your previous code, what was the behavior? Left character gets deleted and nothing is selected in the right?When pressing back space, it selects left character in stead of deleting it.
AutoFill in Text Box
Re: AutoFill in Text Box
- esgici
Hi All
In appearance this isn't easy task as far as seen at first sight.
Please look and test this version.
I'm waiting your comments.
PS: Please attention: Sometimes seems nothing changed by seeing text box value not changed. This occurs especially after pressing backspace or delete keys. This is because the result off filling process become identical with previous one.
AutoFill in Text Box try
Started by Esgici
Enhanced by Roberto Lopez and Rathinagiri
2009.05.09
#include "minigui.ch"
PROC Main()
aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ), CRLF )
ASORT( aCountries ) // This Array MUST be sorted
DEFINE WINDOW frmAFTest ;
WIDTH 550 ;
HEIGHT 300 ;
TITLE 'AutoFill in Text Box try' ;
ON KEY UP ACTION AutoFill( ThisWindow.Name, "txbCountry", aCountries, 1 )
ON KEY DOWN ACTION AutoFill( ThisWindow.Name, "txbCountry", aCountries, 2 )
ON KEY ESCAPE ACTION frmAFTest.Release
DEFINE LABEL lblCountry
ROW 50
COL 50
VALUE "Country :"
RIGHTALIGN .T.
AUTOSIZE .T.
END LABEL // lblCountry
DEFINE TEXTBOX txbCountry
ROW 48
COL 110
ONCHANGE AutoFill( ThisWindow.Name, This.Name, aCountries )
END TEXTBOX // txbCountry
END WINDOW // frmAFTest
frmAFTest.Center
frmAFTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC AutoFill( ; // Auto filling text box
cFrmName ,; // Form / Windows name
cTxBName ,; // Text Box Name
aList,; // Items list
nCaller ) // NIL : OnChange, 1: UP, 2: Down
STATIC cLastVal := '',;
n1Result := 0
LOCAL cTxBValue := GetProperty( cFrmName, cTxBName, "Value" ),; // Text Box Value
nCarePos := GetProperty( cFrmName, cTxBName, "CaretPos" ),; // Text Box CaretPos
cCurval := ''
IF HB_ISNIL( nCaller )
IF !( cLastVal == cTxBValue )
cCurval := LEFT( cTxBValue, nCarePos )
IF !EMPTY( cCurval )
n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, LEN( cCurval ) ) ) == UPPER( cCurval )} )
IF n1Result > 0
cCurval := aList[ n1Result ]
ENDIF n1Result > 0
ENDIF !EMPTY( cCurval )
cLastVal := cCurval
AF_Apply( cFrmName, cTxBName, cCurval, nCarePos )
ENDIF cLastVal # cCurval
IF n1Result > 0
IF nCaller < 2
n1Result -= IF( n1Result > 1, 1, 0 )
n1Result += IF( n1Result < LEN( aList ), 1, 0 )
cLastVal := cCurval
ENDIF n1Result > 0
ENDIF HB_ISNIL( nCaller )
RETU // AutoFill()
PROC AF_Apply( cFrmName, cTxBName, cValue, nPosit )
SetProperty( cFrmName, cTxBName, "Value", cValue )
SetProperty( cFrmName, cTxBName, "CaretPos", nPosit )
* I don't like this low-level trick ! :(
SendMessage( GetControlHandle( cTxBname, cFrmName), 177, LEN( cValue ), nPosit )
RETU // AF_Apply()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.PS: Please attention: Sometimes seems nothing changed by seeing text box value not changed. This occurs especially after pressing backspace or delete keys. This is because the result off filling process become identical with previous one.
Viva INTERNATIONAL HMG
Hi Esgici,
Had u tested my last version here?
IMHO, we can't have a generic UP/DOWN key definitions because, if you define another listbox in this window, you can't scroll that listbox with the UP/DOWN key.
- esgici
Hi Rathi
Yes, tested.
IMHO at this stage adequate working of auto filling process is more important than scope of up-down keys. For localizing instead of global on-key definition will be easy by your method, I thought.
Thanks and regards.
Yes, tested.
Thanks and regards.
As you had rightly said, working of the process is more important.
Had you gone through the back space handling too?
- esgici
Didn't you tried ?rathinagiri wrote: Had you gone through the back space handling too?
Any problem ?
- esgici
Hi
IMHO that love-level trick
is causing some serious problems.
Please extract ( or simply comment ) it in my last code.
It's very last line :
SendMessage( GetControlHandle( ...Please extract ( or simply comment ) it in my last code.
SendMessage( GetControlHandle( cTxBname, cFrmName), 177, LEN( cValue ), nPosit )--
Yes. Now it is working perfect. Thanks a lot Esgici.
Hi Rathi and Esgici,
Thank you very much. Now, everything is fine
I tested it
Yesterday I was busy with formatting my laptop. It's registry was corrupted. And at that time I couldn't understand low level functions. Still now I am very novice in HMG.
Rathi, sorry my friend. I was wrong regarding user interface. I have to learn many things from you
With best regards.
With best regards.
Yes, my friend, it was not currectrathinagiri wrote:Yes. In your previous code, what was the behavior? Left character gets deleted and nothing is selected in the right?When pressing back space, it selects left character in stead of deleting it.
Regards.
