AutoFill in Text Box
Hi all,
I'm experimenting AutoFill feature in text box.
Some friends told about it and some commercial products support it with some high promotions.
After seeing Rathinagiri's wonderful work Combined Search box, the AutoFill concept seems not very complicated, at least it will be easier than CSBox, I thought.
So, first implementation is attached.
It is very primitive stage and needs some fine tunes. fe the two sub functions has repetitive lines and may be shortened.
Also navigation by UP and DOWN keys may be optimized.
Please test and give your comments.
AutoFill.zip
AutoFill in Text Box experimenting
(2.18 KiB) Downloaded 885 times
Re: AutoFill in Text Box
Just another nice utility Esgici.
I am very much interested to use it immediately in my applications.
Some suggestions:
1. When we use backspace, the selection doesn't change. For example, if we press i, Iceland comes. When we press backspace, it becomes 'celand'
2. As you have rightly said, up/down keys should be optimized. We can use Esc key also to cancel.
Eagerly waiting for the next version.
I had modified a little, to call only with the array parameter. ie., on change autofill(acountries)
  AutoFill in Text Box try
#include "minigui.ch"
PROC Main()
   aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ),   CRLF )
   ASORT( aCountries )                    // This Array MUST be sorted
   DEFINE WINDOW frmAFTest ;
      WIDTH 550 ;
      HEIGHT 300 ;
      TITLE 'AutoFill in Text Box try' ;
      ON KEY UP     ACTION AFNavigate( 1, "frmAFTest", "txbCountry", aCountries )
      ON KEY DOWN   ACTION AFNavigate( 2, "frmAFTest", "txbCountry", aCountries )
      ON KEY ESCAPE ACTION frmAFTest.Release
      DEFINE LABEL lblCountry
         ROW        50
         COL        50
         VALUE      "Country :"
         RIGHTALIGN .T.
         AUTOSIZE   .T.
      END LABEL // lblCountry
      DEFINE TEXTBOX txbCountry
         ROW      48
         COL      110
         ONCHANGE AutoFill(aCountries )
      END TEXTBOX // txbCountry
   END WINDOW // frmAFTest
   frmAFTest.Center
   frmAFTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC AutoFill( ;                       // Setting CSBox values
                aList )      // Items list
   LOCAL cCurval  := '' ,;
         n1Result := 0,;
         cFrmName := thiswindow.name,;
         cTxBName := this.name,;
         nCarePos := this.caretpos
   cCurval := LEFT( GetProperty( cFrmName, cTxBName, "Value" ), nCarePos )
   IF !EMPTY( cCurval )
      n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, LEN( cCurval ) ) ) == UPPER( cCurval )} )
      IF n1Result > 0
         cCurval := aList[ n1Result ]
      ENDIF n1Result > 0
      SetProperty( cFrmName, cTxBName, "Value", cCurval  )
      SetProperty( cFrmName, cTxBName, "CaretPos", nCarePos  )
   ENDIF !EMPTY( cCurval )
RETU // SetCSBoxVal()
PROC AFNavigate( ;                        // Navigation by UP/DOWN keys in AutoFill Text Box
                 nDirect ,;  // 1 : Up, 2: Down
                 cFrmName,;
                 cTxBName,;
   LOCAL nCarePos := GetProperty( cFrmName, cTxBName, "CaretPos"  ),;
         n1Result := 0
   LOCAL cCurval  := LEFT( GetProperty( cFrmName, cTxBName, "Value" ), nCarePos )
      IF n1Result > 0
         IF nDirect < 2
            n1Result -= IF( n1Result > 1, 1, 0 )
            n1Result += IF( n1Result < LEN( aList ), 1, 0 )
      ENDIF n1Result > 0
RETU // AFNavigate()
Hi Esgici,
Kindly test this code.
I had altered for up/down key problems with other controls and also the backspace problem.
    PROC Main()
          WIDTH 550 ;
          HEIGHT 300 ;
             ROW        50
             COL        50
             VALUE      "Country :"
             RIGHTALIGN .T.
             AUTOSIZE   .T.
             ROW      48
             COL      110
             ongotfocus autofill_init(acountries)
             onlostfocus autofill_close()
          define listbox list1
             row 80
             col 110
             width 200
             items {"Item 1","Item 2","Item 3","Item 4","Item 5","Item 6"}
             value 1
          end listbox
       frmAFTest.Center
       frmAFTest.Activate
    RETU // Main()
             n1Result := 0,;
          IF n1Result > 0
          ENDIF n1Result > 0
       if ncarepos == 0 .and. len(alltrim(GetProperty( cFrmName, cTxBName, "Value" ))) > 0
          if ascan(alist,{ | c1 | UPPER( c1 ) == UPPER( GetProperty( cFrmName, cTxBName, "Value" ) )}) == 0
             SetProperty( cFrmName, cTxBName, "Value", ''  )
                     cFrmName,;
                     cTxBName,;
             n1Result := 0
          IF n1Result > 0
             IF nDirect < 2
          ENDIF n1Result > 0
function autofill_init(aitems)
local formname := thiswindow.name
local controlname := this.name
ON KEY UP    of &formname ACTION AFNavigate( 1, formname, controlname, aitems )
ON KEY DOWN  of &formname ACTION AFNavigate( 2, formname, controlname, aitems )
return nil
function autofill_close
release key UP of &formname
release key DOWN of &formname
return nil
sudip
Post by sudip »
Hi Esgici & Rathi,
Thanks a lot. Excellent utility!!! :)
Only one suggestion:
When typing in the textbox if right side of the cursor position is automatically selected, then it will be better for user (I did the same thing in one of my VFP utilities, as suggested by one of my clients)
With best regards.
Yes Sudip. It can be done by adding the following line after "SetProperty( cFrmName, cTxBName, "CaretPos", nCarePos )"
SendMessage ( GetControlHandle(cTxBname,cFrmName) , 177 , ncarepos , len(cCurval) )
Don't worry about calling of this internal low level function. :)
It has some disadvantage also. I think we can not use caret position and selection simultaneously. Tell me about your opinion
sudip
Post by sudip »
Hi Rathi,
I inserted the line in 2 places.
It works for "selection". :)
rathinagiri wrote: Don't worry about calling of this internal low level function. :)
But there is a problem. I can't use BACK SPACE to delete text, left side of the caret. :( So, you are right. Yes, we can't use caret position and selection simultaneously. ;)
And regarding "worried" about low level function... ha, ha, ha :lol: (Thanks to Roberto, yesterday he patiently explained GetTextWidth() function to this "novice" learner :) )
With best regards.
Hi Sudip,
I think I had solved this backspace problem too.
Have a try about this.
        PROC Main()
              WIDTH 550 ;
              HEIGHT 300 ;
                 ROW        50
                 COL        50
                 VALUE      "Country :"
                 RIGHTALIGN .T.
                 AUTOSIZE   .T.
                 ROW      48
                 COL      110
                 row 80
                 col 110
                 width 200
                 value 1
              end listbox
           frmAFTest.Center
           frmAFTest.Activate
        RETU // Main()
                        aList) //Items list
                 n1Result := 0,;
              IF n1Result > 0
              ENDIF n1Result > 0
//              SetProperty( cFrmName, cTxBName, "CaretPos", nCarePos  )
              SendMessage ( GetControlHandle(cTxBname,cFrmName) , 177 , len(cCurval),ncarepos   )
                         cFrmName,;
                         cTxBName,;
                 n1Result := 0
              IF n1Result > 0
                 IF nDirect < 2
              ENDIF n1Result > 0
    ON KEY BACK of &formname ACTION autofilldobackspace(formname,controlname,aitems)
    return nil
    return nil
    function autofilldobackspace(formname,controlname,alist)
    local nstart := LoWord ( SendMessage( GetControlHandle(controlname,formname) , 176 , 0 , 0 ) )
    local nend := HiWord ( SendMessage( GetControlHandle(controlname,formname) , 176 , 0 , 0 ) )
    local ccurvalue := getproperty(formname,controlname,"VALUE")
    local n1Result := 0
    if nstart > 0
              n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, nstart-1 ) ) == UPPER( substr(cCurvalue,1,nstart-1 ))} )
              IF n1Result > 0
                 ccurvalue := aList[ n1Result ]
              ENDIF n1Result > 0
              setproperty(formname,controlname,"VALUE",ccurvalue)
              SendMessage ( GetControlHandle(controlname,formname) , 177 , len(ccurvalue),nstart-1   )
    return nil
sudip
Post by sudip »
Hi Rathi,
Thanks a lot! It works! You are a genius :D
Again, I saw an "abnormal" behavior. When pressing back space, it selects left character in stead of deleting it.
Is this behavior Ok or we need some changes?
With best regards.
That you have to tell. :)
Now, just try Indo for Indonesia and then press backspace.
sudip
Post by sudip »
rathinagiri wrote:That you have to tell. :)
Yes, I tried it. It is not very easy to tell .... :? Most probably you are correct, this should be the ideal behavior of CSBox control. :D
Now, I want to explain what I mean with the help from my old app ... :)
This is HMG forum, but I want to share some of my old codes written in another software tool to mean what I want to say.
InteractiveChange EVENT FOR txtCustnm CONTROL
local mCustnm
ch = lastkey()
* Ignore if Del, Back Space or Space key pressed
if ch = 7 or ch = 127 or ch = 32
	return
mCustnm = left(this.value, this.selstart)
if empty(mCustnm)
	return
select cust
set order to custnm
locate for upper(custnm) = upper(mCustnm)
if found()
	this.value = Custnm
	this.selstart = len(mCustnm)
	this.sellength = len(custnm) - len(mCustnm)
Valid EVENT FOR txtCustnm CONTROL
local mCustnm
select ord
if eof() or bof()
	return
select cust
set order to custnm
set exact on
seek upper(alltrim(this.value))
set exact off
if found()
	select ord
	replace custid with cust.custid
	return
	select ord
	replace custid with ""
select Custnm, upper(Custnm) ;
	from Cust ;
	where upper(Custnm) = upper(alltrim(this.value));
	order by 2 ;
	into cursor curTemp
do form frmFind with "curTemp", 1, 1 to mCustnm
if !empty(mCustnm)
	this.value = mCustnm
use in curTemp
select cust
set order to custnm
set exact on
set exact off
if found()
	select ord
	select ord
frmFind is a form with listbox for searching records.
Above code is not generic and I never used that code later. :(
Thank you again for sharing this code. I am very happy with this team work :)
With best regards.
