EAN-8 Barcode generator
Re: EAN-8 Barcode generator
Or we should use HMG_LEN() function instead of len()
quartz565
Post by quartz565 »
Thank you for sharing Rathi,
very nice work !!
Hi Daniel, '96385074' it works fine for me.
Nikos
Best Regards,
Nikos.
os: Windows Server 2019 - 64
quartz565 wrote: '96385074' it works fine for me.
For me too; '9638507" and '9638507 " too.
Mol, already ALLTRIM'med.
   cCode := alltrim( cCode ) // line 124
This is the second version.
1. Added an option to show/hide the digits in the barcode.
2. Separated ean8 encoding code into a separate prg so that it can be added to any project and called with a function. Or we can create a library. (If Marek makes his code into a library for EAN-13 like this it will be great.)
3. Added Esgici's suggestion.
4. Made the default line width to 2 and line height to 110 for making the barcode visible and sizable.
barean8.zip
(2.57 KiB) Downloaded 368 times
Rathinagiri wrote:This is the second version.
barean8.zip
Superb !
Viva HMG :D
Rathinagiri wrote:This is the second version...]
Hi Rathi
After "Invalid Code" and "Invalid check sum", createbarcode() function open last produced barcode image (barcode.png).
To avoid this, my humble suggestion is :
When "Invalid Code" or "Invalid check sum" situations occurs, ean8_barcode() functions returns .f., ( line 56 and 74 of ean8.prg )
else return .t. (last line (115) )
and createbarcode() function will be like this :
function createbarcode
   local cImage := 'barcode.png'
   if ean8_barcode( barcode.code.value, cImage, barcode.linewidth.value, barcode.lineheight.value, barcode.showdigits.value )
      if file( cImage )
         open file cImage
   return nil
Best regards
Yes. That is right. Thank you Esgici.
barean8.zip
OK, I'll do it!
Thanks Marek.
