EAN-8 Barcode generator
This is a EAN-8 barcode generator without any ttf fonts. I want to thank Marek for creating such an utility for EAN-13.
Generated barcode is saved as a png image file and can be used for printing or showing in a window afterwards.
This utility requires HMG 3.1.4 and uses HFCL BosTaurus graphics library for image creation.
Hope it is useful.
barean8.zip
(2.57 KiB) Downloaded 666 times
Re: EAN-8 Barcode generator
Thanks for sharing Rathi, many people will serve as an example for the development of your application, and there is not much literature about barcodes in our language (Harbour / HMG).
Gracias por compartir Rathi, a mucha gente servira como ejemplo para el desarollo de su aplicacion; ya que no hay mucha bibliografia acerca de codigos de barra en nuestro lenguaje (Harbour / HMG ).
Excellant Rathi
Thank you for sharing
Hi Rathi
Rathinagiri wrote:This is a EAN-8 barcode generator without any ttf fonts...
Very nice work :)
  • Font independence
    possibility for define size of result,
    nice check sum algorithm,
    good example for notify power of BT and HMG...
    everything is wonderful :)
Thanks :!:
Viva HMG :D
Rathinagiri wrote:This is a EAN-8 barcode generator ...
Hi Rathi
Does something like this will be useful ? :
         TOOLTIP "Enter 8 digit code ( 7 digit for automatic checksum producing )"
as an addition to barcode.code.
Yes. I too have thought that. Thanks Esgici.
Hi Rathi :
Code 96385074 Fail.
Windows 7 Home Premiun, HMG.3.1.4
compiled with Mibuil.bat
barean8.rar
(3.01 KiB) Downloaded 2062 times
Webpage check code
Wikipedia number example
That is very odd. The message 'Invalid Code!' is given for codes having length < 7 or > 8. Therefore, please verify the length of the code (is there any space?).
It works fine for me.
