simple backup program
Hi guys!
Do you remember this time, when you lost you've changed your code, saved changes and made a copy rewriting your archive, then understood mistake???
I had it today...
But, for happiness, I had a copy on third computer :)
So, I've decided to write small application, quick to run, to archive my *.prg and *.fmg files to archive named by timestamp.
All names are in Polish, I can translate it to English when somebody will be interested of.
The code is clearly written, I hope ;)
Nice testing!
Regards, Marek
backup.zip
(2.84 KiB) Downloaded 557 times
jairpinho
Re: simple backup program
Post by jairpinho »
Very good your program if I can translate English to use it for backups
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Very useful Marek. If it can be attached to IDE, that will be more helpful.
very nice idea Rathi! It could be wonderful to automatically create backup of source files while closing IDE.
Hi Mol:
appreciate your contribution.
in my case I use the backup of Crimson Editor.
is also incremental.
also open the FMG, so when I change the FMG with the IDE takes modificacions Crimson editor and writes well in an incremental manner.
I've translated this sample to English. I've made some changes in code, too.
Write your opinions if you like/dislike it :)
Best regards, Marek
backup.zip
(3.06 KiB) Downloaded 467 times
Very nice example Mr. Marek and wonderfull idea of Mr. Rathi!
I was translating screen and I noted you have already done, that it is very good. But you please if you want consider this my last translation, please use attached file.
Thank you for your sharing !
backup.rar
(1.34 KiB) Downloaded 441 times
Thanks Marek,
Nice utility :)
fchirico
Post by fchirico »
Thanks for sharing!!!
Very usefull.
Saludos, Fernando Chirico.
Hi
A few suggestions :
For function main() :
   PRIVATE cFileKinds_FNam    := "FilKinds.lst",;   // File kinds file name
           cFileKinds         := "",;               // File kinds string
           aFileKinds         := {}                 // File kinds array
   IF FILE( cFileKinds_FNam )
      cFileKinds := MEMOREAD( cFileKinds_FNam)              // File kinds string
      IF !EMPTY( cFileKinds )
         aFileKinds := HB_ATOKENS( cFileKinds, CRLF )
   IF EMPTY( aFileKinds )
      aFileKinds := { "PRG", "FMG" }
   AEVAL( aFileKinds, { | c1, i1 | aFileKinds[ i1 ] := "*." + c1 } )
For function MakeBackup() :
	BackUp.ProgressIndicator.Visible := .t.
from clipper docs :
   ADIR() is a compatibility function and therefore not recommended.  It is
   superseded by the DIRECTORY() function which returns all file
   information in a multidimensional array.
moreover ...
   ADIR() require calling twice :(
   FOR EACH cFileKind IN aFileKinds
      aTemp := DIRECTORY( cFileKind )
      AEVAL( aTemp, { | a1 | AADD( aFilesToBackup, a1[ 1 ] ) } )
   IF EMPTY( aFilesToBackup )
      MsgStop( "No file found to backup !", " ERROR !" )
      BackUp.ProgressIndicator.RangeMax := len(aFilesToBackup)
      BackUp.ProgressIndicator.Value := 0
      COMPRESS aFilesToBackup ;
         TO cArchiveName ;
         BLOCK {|cFile,nPos|  BackUp.ProgressIndicator.Value := nPos }  ;
         OVERWRITE
      // You can save backub settings here
      //SaveBackupConfiguration()
      lBackupStatus  := .t.
      msgbox("Backup created successful!")
	BackUp.Release
return
Content of my FilKinds.lst :
ch
prg
fmg
hbp
hbc
log
lst
For all files, a single "*" is sufficient ;)
I wish you will like it :)
