CSBox Reviewed
CSBox Reviewed
Hi to all
Combined search box reviewed and rewritten for some bug reported such as : confusions occurs when multiple CSBox defined and another type of confusion when CSBox defined into a tab control. So, added "M" prefix with meaning of "multiple" to this version.
The bad news is : I couldn't sure that everything is OK. So please test fully and please report everything negative.
And unfortunately this isn't "libbed" ( in HFCL ) version. If no problem found, I hope that Rathi will made necessary steps for rebuild HFCL.
Thanks in advance.
MSCBox.zip
Multiple CSBOx test
(7.78 KiB) Downloaded 448 times
Re: CSBox Reviewed
Thanks Esgici. I shall test it.
Re: CSBox Reviewed
Hi Esgici,
I shall also test this.
(My net was down for 3 days!!! :o )
Regards.
Re: CSBox Reviewed
Hi Esgici,
Tested OK :)
Thanks a lot.
Regards.
Re: CSBox Reviewed
sudip wrote: Tested OK :)
Thanks a lot my brother :D
Re: CSBox Reviewed
Fantastic Esgici. :)
That too, without any public variable. Great contribution.
Tonight I shall create the hfcl library new version.
Re: CSBox Reviewed
rathinagiri wrote: I shall create the hfcl library new version.
Thanks a lot Rathi, I'll wait :D
Re: CSBox Reviewed
Hello Esgici,
Please be so kind to revise the following change for Ecsape key handling:
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._
STATIC PROC _CSDoEscKey( cParentName, cCSBoxName )
   SetProperty( cParentName, cCSBoxName, "VALUE", '' )
   DoMethod( ThisWindow.Name, "Release" )
RETURN // _CSDoEscKey()
Re: CSBox Reviewed
Hi Grigory,
I thought you were on vacation for 2 weeks (as I read)!!!
Please take care of your health.
Thanks a lot for the code, but after compilation when I run the app and press Esc, got following Error:
Date:08/18/09 Time: 11:17:20
Error BASE/1081 Argument error: +
Called from _ISCONTROLDEFINED(1053)
Called from SETPROPERTY(6337)
Called from _CSDOESCKEY(278)
Called from (b)CREATECSBOX(133)
Called from _DOCONTROLEVENTPROCEDURE(4735)
Called from EVENTS(553)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4399)
Called from CREATECSBOX(167)
Called from (b)_DEFINECOMBOSEARCHBOX(67)
Called from EVENTS(1409)
Called from _ACTIVATEWINDOW(4377)
Called from DOMETHOD(7224)
Called from MAIN(99)
Regards.
Re: CSBox Reviewed
Hello Esgici,
I was using CSB for my new project :)
How can I change Items of Combosearchbox on the fly?
And I found that I have to press Esc key when I want to select another control without selecting any item of CSB. Can this behavior be changed?
