Grid error while editing data
Source code related resources
I have a strange error while editing data in Virtual Grid.
I declrare 6 columns, key Alt+A can be used to add empty row. Then, clicking in first column you can edit 5 columns, but next ENTER key doesn't move focus to column 6.
When I click by the mouse on the column 6, I can ener value, but it causes an error in VALID block which saves data to an array.
Can somebody try to compile my sample?
#define COL_RECNO	7
FUNCTION Main()
	public aStru
	PUBLIC aData := {}
	private abValid := array(6)
	private bValid := {|| UpdateData()}
	SET LANGUAGE TO POLISH
	HB_LANGSELECT('PL')
	HB_SETCODEPAGE("PL852")
	SET DELETED ON
	SET CENTURY ON
	SET DATE TO GERMAN
	// tablica bloków walidacyjnych
	aFill(abValid, bValid)
	aStru := {;
		{ "NAZWA",     "C", 30, 0 },;
		{ "UZYTKOWNIK","C", 30, 0 },;
		{ "HASLO",     "C", 30, 0 },;
		{ "SCIEZKA",   "C", 80, 0 },;
		{ "FIRMA",     "C", 50, 0 },;
		{ "Link_d",    "C",254, 0 } }
	scr := ""
	if .not.file(scr+"linki.dbf")
		DBCREATE( scr+"LINKI.DBF", aStru )
   USE (scr+"LINKI.DBF") SHARED alias linki
   GO TOP
	// Insert data to an array
	aData:={}
	i=0
	DO WHILE !EOF()
		AADD(aData, { linki->nazwa, linki->uzytkownik, linki->haslo, linki->sciezka,linki->firma,linki->link_d, linki->(recNo()) })
		SKIP
		i+=1
	ENDDO
   DEFINE WINDOW Form_1 ;
      WIDTH 1500 HEIGHT 800 MAIN ;
      TITLE 'Link view/edit - Alt+A adds empty row to grid, try to edit it'
	@ 10,10 GRID Grid_1 ;
		WIDTH 1400 ;
		HEIGHT 700 ;
		HEADERS { "NAZWA", "UZYTKOWNIK", "HASLO", "SCIEZKA", "FIRMA","Link długi" } ;
		WIDTHS { 200, 200, 200, 300, 200 ,400} ;
		ITEMS NIL ;
		EDIT ;
		VIRTUAL ;
		ON QUERYDATA Grid_1_OnQueryData();
		JUSTIFY { GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_LEFT};
		COLUMNVALID abValid
	@ 720, 10 BUTTON BT_Save ;
		CAPTION 'Zapisz zmiany' ;
		WIDTH 120 HEIGHT 28 ;
		ACTION SaveDBF()
	ON KEY ALT+Q OF FORM_1 ACTION FORM_1.RELEASE
	ON KEY ALT+A OF FORM_1 ACTION AddEmptyRowtoArray()
	Form_1.Grid_1.ItemCount := len(aData)
	Form_1.CENTER
   Form_1.ACTIVATE
function Grid_1_OnQueryData
	local nRow, nCol
	nRow := This.QueryRowIndex
	nCol := This.QueryColIndex
	if nRow>0 .and. nCol >0
		This.QueryData := aData[nRow, nCol]
return
function AddEmptyRowtoArray
	local i
	local aEmptyRow := {}
	for i:=1 to len(aStru)
		if aStru[i, 2] == "C"
			aAdd(aEmptyRow, "")
		elseif aStru[i, 2] == "N"
			aAdd(aEmptyRow, 0)
		elseif aStru[i, 2] == "L"
			aAdd(aEmptyRow, .f.)
		elseif aStru[i, 2] == "D"
			aAdd(aEmptyRow, 0d0)
	next i
	// and one another clumn for #recno
	aAdd(aEmptyRow, 0)
	aAdd(aData, aEmptyRow)
	Form_1.Grid_1.Value := { len(aData), 1 }
return
FUNCTION UpdateData
	local nRow, nCol, xValue
	nRow := this.CellRowIndex
	nCol := this.CellColIndex
	xValue := this.CellValue
	MsGDebug("Writing to aData[" + hb_ntos(nRow) + ","+ hb_ntos(nCol)+"]", xValue)
	aData[nRow, nCol] := xValue
RETURN .t.
FUNCTION SaveDBF
	MsgStop("function in progress...")
Error below:
Date:08.09.2025 Time: 17:31:26
Error BASE/1132 Błąd zakresu tablicy: Nieprawidłowa liczba argumentów
Called from UPDATEDATA(128)
Called from (b)MAIN(11)
Called from _DOCONTROLEVENTPROCEDURE(6033)
Called from _HMG_GRIDINPLACEEDITOK(1513)
Called from (b)_HMG_GRIDINPLACEEDIT(1066)
Called from EVENTS(821)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5694)
Called from _HMG_GRIDINPLACEEDIT(1299)
Called from _HMG_GRIDINPLACEKBDEDIT(1753)
Called from EVENTS(2213)
Called from DOMETHOD(9080)
Called from MAIN(81)
nekbmm
DBs Used: DBF,SQLite
Re: Grid error while editing data
Post by nekbmm »
mol wrote: Mon Sep 08, 2025 3:36 pm I have a strange error while editing data in Virtual Grid.
It's the same for me!
I'm using hmg 3.44.
Pozdrav NEX.
Hi Marek,
I confirm also this issue.
There is a workaround for the problem: your last column should have a lenght to show this column on screen entirely at initializing your grid.
Please review the updated working code below.
#define COL_RECNO	7
FUNCTION Main()
	public aStru
	PUBLIC aData := {}
	HB_LANGSELECT('PL')
	SET DELETED ON
	SET CENTURY ON
	SET DATE TO GERMAN
	aStru := {;
	scr := ""
   GO TOP
	aData:={}
	i=0
	DO WHILE !EOF()
		SKIP
		i+=1
	ENDDO
      WIDTH 1400 HEIGHT 800 MAIN ;
		WIDTH 1350 ;
		HEIGHT 700 ;
		ITEMS NIL ;
		EDIT ;
		CELLNAVIGATION ;
		VIRTUAL ;
		COLUMNVALID abValid
		ACTION SaveDBF()
	Form_1.Grid_1.ColumnWidth(6) := 230
	Form_1.CENTER
   Form_1.ACTIVATE
	local nRow, nCol
return
	local i
			aAdd(aEmptyRow, "")
			aAdd(aEmptyRow, 0)
	next i
	aAdd(aEmptyRow, 0)
return
FUNCTION UpdateData
	MsgDebug("Writing to aData[" + hb_ntos(nRow) + ","+ hb_ntos(nCol)+"]", xValue)
RETURN .t.
FUNCTION SaveDBF
Yes, I saw that error doesn't occur when last column is whole visible.
Thank you Grigorij for your solution!
