Generating a readable text string from an array
HGAutomator
Post by HGAutomator »
Still working on this, but need to break for a day or two.
Next TODO is to indent and CRLF some of the subarrays and/or elements, in a way that makes sense to the human eye.
This is different from many of the Array2File or Array2String modules, in that it's strictly textual and readable. At least, that's the goal.
In case anyone wants to take a look, this is a work in progress.
#define CRLF CHR(10) + CHR(13)
STATIC MultiDimensionalArray_s := ""
Function ConvertArrayToString()
	Local ArrayString_s := ""
  Local SampleArray_a := ;
      {"One", "Two", "Three", { "Four", "Five" } }, ;
      { "Six", "Seven" }, ;
      {"Eight", "Nine"} ;
	SampleArray_a := ;
		{ { "Dummy1", "Dummy2" }, "Six", "Seven" }, ;
		{"Eight", "Nine"} ;
  ArrayString_s := "{ " + CRLF + WriteArray( SampleArray_a, 1 ) + CRLF + " }"
	// Send ArrayString_s to file SAMPLEARRAY.TXT
	SET CONSOLE OFF
	SET PRINTER ON
	SET PRINTER TO SAMPLEARRAY.TXT
	? ArrayString_s
	SET PRINTER OFF
	SET PRINTER TO
	SET CONSOLE ON
FUNCTION WriteArray(aArray, Level_n )
LOCAL TypeOfElement_s := ""
LOCAL NthElement_n := 0
LOCAL LengthOfArray_n := 0
LengthOfArray_n := LEN(aArray)
MultiDimensionalArray_s := MultiDimensionalArray_s + Space( Level_n )
FOR NthElement_n = 1 TO LengthOfArray_n
   TypeOfElement_s = VALTYPE(aArray[NthElement_n])
   DO CASE
      CASE TypeOfElement_s = 'A'
         If NthElement_n == 1
            MultiDimensionalArray_s := MultiDimensionalArray_s + " { " + CRLF
         Else
            If NthElement_n < LengthOfArray_n
            Else
               If NthElement_n == LengthOfArray_n
               EndIf
            EndIf
         EndIf
         WriteArray(aArray[NthElement_n], Level_n + 1)
         IF ( NthElement_n == 1 .AND. NthElement_n < LengthOfArray_n )
            MultiDimensionalArray_s := MultiDimensionalArray_s + " },  " + CRLF
         Else
            Else
                  MultiDimensionalArray_s := MultiDimensionalArray_s + " } " + CRLF
               EndIf
            EndIf
         EndIf
      CASE TypeOfElement_s = 'C'
            MultiDimensionalArray_s := MultiDimensionalArray_s + aArray[NthElement_n] + ", "
         Else
            MultiDimensionalArray_s := MultiDimensionalArray_s + aArray[NthElement_n] + " "
         EndIf
      CASE TypeOfElement_s = 'D'
          MultiDimensionalArray_s := MultiDimensionalArray_s + DTOC(aArray[NthElement_n]) + " "
      CASE TypeOfElement_s = 'L'
          MultiDimensionalArray_s := MultiDimensionalArray_s + IF(aArray[NthElement_n], 'T', 'F') + " "
      CASE TypeOfElement_s = 'N'
          MultiDimensionalArray_s := MultiDimensionalArray_s + LTRIM(STR(aArray[NthElement_n] ) ) + " "
      OTHERWISE
          MultiDimensionalArray_s := MultiDimensionalArray_s + 'X' + " "
    ENDCASE
RETURN MultiDimensionalArray_s
SALINETAS24
Re: Generating a readable text string from an array
Post by SALINETAS24 »
HGAutomator wrote: Fri Oct 14, 2022 5:00 pm Still working on this, but need to break for a day or two.
In case anyone wants to take a look, this is a work in progress.......
[/code]
Hola, no tengo claro lo quieres hacer. Mi inglés es malo. :?:
No obstante te paso un programa que te convierte una ARRAY multi en una cadena de caracteres y que la muestra con los distintos niveles. Espero que te sirva para algo.
Saludos cordiales y cervezas virtuales .... :lol:
ARRAYCADENA.rar
(852 Bytes) Downloaded 117 times
HGAutomator
Hi Salinet,
I haven't tested your code yet, but it does look good.
Will check it out in a few days, after catching up on other stuff.
SALINETAS24 wrote: Mon Oct 17, 2022 7:08 pm
[/code]
HGAutomator
Salinet,
Not quite. Your code lines up the elements of the array nicely, but doesn't generate the braces.
Still busy, haven't had a chance to do any more coding this week so far. But the resultant string has to look something like this:
"Six", "Seven" }, ;
{"Eight", "Nine"} ;
Anyway, I'll share when it's done, thanks.
HGAutomator
Not finished yet, but some progress:
STATIC FUNCTION WriteArray( _a, Level_n )
   LOCAL ElementType_s, NthElement_n, ArrayLength_n := Len( _a )
   FOR NthElement_n = 1 TO ArrayLength_n
      ElementType_s = ValType( _a[ NthElement_n ] )
      DO CASE
      CASE ElementType_s = 'A'
         IF NthElement_n == 1
            MultiDimensionalArray_s := MultiDimensionalArray_s + "{ " + CRLF
            IF NthElement_n < ArrayLength_n
               IF NthElement_n == ArrayLength_n
         WriteArray( _a[ NthElement_n ], Level_n + 1 )
         IF NthElement_n == 1 .AND. NthElement_n < ArrayLength_n
            MultiDimensionalArray_s := MultiDimensionalArray_s + CRLF + " }, "
                  MultiDimensionalArray_s := MultiDimensionalArray_s + CRLF +  " }"
      CASE ElementType_s = 'C'
         OutDebug( _a[ NthElement_n ] )
            MultiDimensionalArray_s := MultiDimensionalArray_s + Chr(34) + _a[ NthElement_n ] + Chr(34) + ", "
            MultiDimensionalArray_s := MultiDimensionalArray_s + Chr(34) + _a[ NthElement_n ] + Chr(34) +  " "
      CASE ElementType_s = 'D'
         OutDebug( DToC( _a[ NthElement_n ] ) )
         MultiDimensionalArray_s := MultiDimensionalArray_s + DToC( _a[ NthElement_n ] ) + " "
      CASE ElementType_s = 'L'
         OutDebug( IF( _a[ NthElement_n ], 'T', 'F' ) )
         MultiDimensionalArray_s := MultiDimensionalArray_s + IF( _a[ NthElement_n ], 'T', 'F' ) + " "
      CASE ElementType_s = 'N'
         OutDebug( LTrim( Str(_a[ NthElement_n ] ) ) )
         MultiDimensionalArray_s := MultiDimensionalArray_s + LTrim( Str( _a[ NthElement_n ] ) ) + " "
      CASE ElementType_s = 'B'
         MultiDimensionalArray_s := MultiDimensionalArray_s + 'B' + " "
      OTHERWISE
         OutDebug( 'X' )
      ENDCASE
HGAutomator
Much closer, to what we're trying to accomplish:
   SampleArray_a := ;
      { "One", "Two", "Three", { "Four", "Five" } }, ;
      { "Eight", "Nine", Date(), 123, { || dummyfunc() } }, ;
      { .F., .T. } ;
   ArrayString_s := "{ " + CRLF + WriteArray( SampleArray_a, 1 ) + CRLF + "}"
      DO CASE
            MultiDimensionalArray_s := MultiDimensionalArray_s + DToC( _a[ NthElement_n ] ) + ", "
            MultiDimensionalArray_s := MultiDimensionalArray_s + IF( _a[ NthElement_n ], 'T', 'F' ) + ", "
            MultiDimensionalArray_s := MultiDimensionalArray_s + LTrim( Str( _a[ NthElement_n ] ) ) + ", "
            MultiDimensionalArray_s := MultiDimensionalArray_s + 'B' + ", "
      OTHERWISE
            MultiDimensionalArray_s := MultiDimensionalArray_s + 'X' + ", "
      ENDCASE
So, for the sample array
      { .F., .T. } ;
, the function generates the string
   "Four", "Five"
   "Dummy1", "Dummy2"
 }, "Six", "Seven"  }, {   "Eight", "Nine", 10/19/22, 123, B  }, {
  F, T
SALINETAS24
HGAutomator wrote: Wed Oct 19, 2022 10:41 pm Much closer, to what we're trying to accomplish: .....
Hola HGAutomator, después de unos ajustes este es el resulado
"Six", "Seven" }, ;
{"Eight", "Nine",10/20/22,123,B} ,
{F, T}
Vamos con una cervecita fresquita para todo el personal.....
PROBA.rar
(1.21 MiB) Downloaded 139 times
HGAutomator
Yep, that seems to work.
SALINETAS24 wrote: Thu Oct 20, 2022 6:51 pm
"Six", "Seven" }, ;
{F, T}
