Configuration manager writing to ini file
I wonder if someone has to share configuration manager, which will be configurable - not specific for his application, enable to write selected setting to .ini file (or xml or any else)?
If not, Im starting such a new job.
I want to declare sections, variable in section, variable types, variable ranges and which local or private variable must be se while read from .ini file.
Re: Configuration manager writing to ini file
Interesting ! Can you please explain a bit more?
I'll try prepare some code next week.
I couldn't sleep last night and I thought a lot about this topic.
But, at weekend I don't like to work :-)
ok ! Have a nice weekend!
trmpluym
Post by trmpluym »
Hi Marek,
I do not exact know what your idea is. But in some of my programs I use something like :
MEMVAR cEmailType:="DefaultValue"
if !File("program.ini")
   Begin ini file ("program.ini"")
   Set Section "INVOICE" ENTRY "EmailType" To cEmailType
   End ini
   Get cEmailType Section "INVOICE" ENTRY "EmailType"
   End Ini
And I use a menu item to change the settings:
EXECUTE FILE GetStartUpFolder() + '\' + 'Program.ini'
Theo
