Grid 2 CSV
Grid 2 CSV
I had created a function to export grid data to csv format. I think it would be useful to you too.
Kindly check up for any bugs. :)
grid2csv.prg
usage: grid2csv("formname","gridname",lheader)
if lheader is .f. (default) only the data are exported. Otherwise first line will contain header data.
# include "minigui.ch"
function grid2csv(windowname,gridname,lheader)
local filename := ""
local adata := {}
local lines := 0
local i := 0
local aeditcontrols := {}
local count1 := 0
local count2 := 0
local linedata := {}
local xres,aec
local cdata := ""
local aclinedata := {}
local fhandle := 0
local linebreak := chr(13)
local aline := {}
local cline := ''
local ncolumns := 0
default lheader := .f.
filename :=  PutFile ( {{"Comma Separated Value Files (*.csv)","*.csv"}} , "Export to text file (CSV)" ,  , .f. )
if len(alltrim(filename)) == 0
   return nil
if at(".csv",lower(filename)) > 0
   if .not. right(lower(filename),4) == ".csv"
      filename := filename + ".csv"
if file(filename)
   if .not. msgyesno("Are you sure to overwrite?","Export to text file (CSV)")
      return nil
lines := getproperty(windowname,gridname,"itemcount")
IF lines == 0
   msginfo("No rows to save!")
   RETURN nil
fhandle := fcreate(filename)
if fhandle < 0
   msgstop("File "+filename+" could not be created!")
   return nil
i := GetControlIndex ( gridname , windowname )
aEditcontrols := _HMG_SYSDATA [ 40 ] [ i ] [ 2 ]
if lheader
   asize(aclinedata,0)
   ncolumns := len(getproperty(windowname,gridname,"item",1))
   for count1 := 1 to ncolumns
      cdata := getproperty(windowname,gridname,"header",count1)
      aadd(aclinedata,cdata)
   next count1
   aadd(adata,aclone(aclinedata))
for count1 := 1 to lines
   linedata := getproperty(windowname,gridname,"item",count1)
   asize(aclinedata,0)
   for count2 := 1 to len(linedata)
      do case
         case ValType(linedata[count2]) == "N"
            xres := _HMG_PARSEGRIDCONTROLS ( AEDITCONTROLS , count2 )
            AEC := XRES [1]
            AITEMS := XRES [5]
            IF AEC == 'COMBOBOX'
               cdata := aitems[linedata[count2]]
               cdata := LTrim( Str( linedata[count2] ) )
         case ValType(linedata[count2]) == "D"
            cdata := dtoc( linedata[count2])
         case ValType(linedata[count2]) == "L"
            AEC := XRES [1]
            AITEMS := XRES [8]
            IF AEC == 'CHECKBOX'
               cdata := iif(linedata[count2],aitems[1],aitems[2])
               cdata := iif(linedata[count2],"TRUE","FALSE")
         otherwise
            cdata := linedata[count2]
      endcase
   next count2
next count1
for count1 := 1 to len(adata)
   cline := ''
   aline := adata[count1]
   for count2 := 1 to len(aline)
      cline := cline + '"' + _parsequote(aline[count2]) + '"'
      if .not. count2 == len(aline)
         cline := cline + ','
   next count2
   cline := cline + linebreak
   fwrite(fhandle,cline)
next count1
if fclose(fhandle)
   msginfo("Exported Successfully!")
   msgstop("Error in saving!")
return nil
function _parsequote(cdata)
local i := 0
local cout := ""
for i := 1 to len(cdata)
   if substr(cdata,i,1) == '"'
      cout := cout + substr(cdata,i,1) + '"'
next i
return cout
Re: Grid 2 CSV
Thanks to sharing :)
Vanguarda
Re: Grid 2 CSV
Post by Vanguarda »
Hi friends,
Thanks for sharing this nice function with us.
Re: Grid 2 CSV
thank you very much for your input.
regards,
luis vasquez
Re: Grid 2 CSV
Hi Rathi,
Thanks for sharing! :)
Re: Grid 2 CSV
Nice work, Rathi!
Marek "MOL"
