report with huge header
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
If you used to make a report like a picture, many columns, a lot of text in the description of the column then you know what is troubling
This is my solution to this problem, you need to enter the column descriptions and column header text
When build (F9) result is a demo.prg , you can compile it and try it, and what you need to copy-paste to your report program
reporthead.zip
(24.91 KiB) Downloaded 294 times
