Export Data XLS/ODS to DBF
wolfgang.schwarz
Post by wolfgang.schwarz »
I'm not sure if I'm right here. I have a problem with open Office Calc. With Excel, the example works very well. I don't know about objects. In the HMG debugger I get the value of ODoc class Win_Oleauto object. Can someone give me the straightening way to read and cache the cell values. With Kind regards
* Converter
* (c) 2017 Wolfgang Schwarz
* Version 1 Build 30
#include "minigui.ch"
PROCEDURE MAIN()
LOCAL oExcel, oWorksheet, i
DEFINE WINDOW Form_Main ;
WIDTH 400 ;
HEIGHT 200 ;
MAIN ;
TITLE 'Excel Test'
DEFINE MAIN MENU
POPUP 'Test Excel / Office '
ITEM 'Start' ACTION ExcelTest()
END POPUP
END MENU
CENTER WINDOW Form_Main
ACTIVATE WINDOW Form_Main
function ExcelTest
# define oSheet
# define oCell
cReadData := Getfile ( { {'Excel Files','*.xls'} , {'CSV Files','*.csv'} , {'OpenOfiiceCalc Files','*.ods'}} , 'Open File' )
*Example: Excel file A1 = Name, B1 PhoneNumber, in A 2 - 10 Name, B 2 - 10 Numbers
if empty (cReadData)
msgbox ("No Data",)
return
*seek now Excel or OpenOfficeCalc
if ( oExcel := win_oleCreateObject( 'Excel.Application' ) ) != NIL
msginfo ("Found Excel")
oExcel := TOleAuto():New( 'Excel.Application' )
if Ole2TxtError() != 'S_OK'
Msginfo ( 'Error in Excel .' )
cStartprogram = "excel"
IF ( oServiceManager := win_oleCreateObject( "com.sun.star.ServiceManager" ) ) != NIL
msginfo ("Found Openoffice")
cStartprogram = "openofficecalc"
msginfo ( "Error - in OpenOffice.", win_oleErrorText() )
return nil
*open exec
if cStartprogram = "excel"
CalcProg = "Excel.Application"
oExcel := CreateObject(CalcProg)
oExcel:Workbooks:Open(cReadData)
oExcel:Visible := .t.
* open office
if cStartprogram = "openofficecalc"
oDesktop := oServiceManager:createInstance( "com.sun.star.frame.Desktop" )
oDoc := oDesktop:loadComponentFromURL( "file:///"+(cReadData), "_blank", 0, {} )
for i = 2 to 10
cTypeA=oExcel:WorkSheets(1):cells(i,1):text
cTypeB=oExcel:WorkSheets(1):cells(i,2):text
msgbox ("Cell A : "+cTypeA + " Cell B : " + cTypeB )
next
msginfo ("Ready Exit Excel",)
oExcel:Quit()
for i = 2 to 10
* this does not work
* oDoc:=getSheets(0)
* getCellbyPosition:=getSheets(0)
* cTypeA=getCellByPosition(i,1)
* msgbox ("Cell A : "+cTypeA)
next
msginfo ("Ready Exit Open Office",)
oDoc:Close( .T. )
Re: Export Data XLS/ODS to DBF
Hola Wolfgang
Porqué no solamente exportar tu archivo ".xls" ó ".ods" como delimitado por comas ","
y lo importas con un Append en tu DBF ???
Hi Wolfgang
Why not just export your file ".xls" or "ODS" as comma delimited ","
And you import it with an Append on your DBF ???
APPEND FROM <xcFile>
[FIELDS <idField list>]
[<scope>] [WHILE <lCondition>] [FOR <lCondition>]
[SDF | DELIMITED [WITH BLANK | <xcDelimiter>] |
[VIA <xcDriver>]]
See:
http://www.hmgforum.com/viewtopic.php?t=1615
wolfgang.schwarz
Thanks for the information on this way I did not even think.
The next problem will be the adoption of the text / CSV format. I am already looking for it in the documents of Open Office. Only the translation does not work properly.
Hi Wolfgang!
You don't need to abandon openoffice.
Please look at my little sample reading data from OpenOffice calc document:
#include <minigui.ch>
function Main
	MsgInfo("start test")
	ReadDataFromOpenOffice()
return
function ReadDataFromOpenOffice
	local oServiceManager,oDesktop,oDocument,oSchedule,oSheet,oCell,oColums,oColumn
	local i
	local cFile := "test.ods"
	local cPath
	//we need to convert file name to url format
	cPath := substr(exename(),1,rat("\",exename()))
	cPath := strtran(cPath, "\", "/")
	cPath += cFile
	begin sequence with { |e| break(e)}
		oServiceManager := TOleAuto():New("com.sun.star.ServiceManager")
		oDesktop := oServiceManager:createInstance("com.sun.star.frame.Desktop")
	recover using e
		oDeskTop := NIL
	end sequence
	IF oDesktop = NIL
		MsgStop("No accesss to OpenOffice","Error")
		RETURN Nil
	oDocument := oDesktop:loadComponentFromURL("file:///"+ cPath, "_blank", 0, {})
	oSchedule := oDocument:GetSheets()
	oSheet := oSchedule:GetByIndex(0)
	for nCol = 0 to 4
		oCell := oSheet:getCellByPosition(nCol,0)
		nCellValue := oCell:value
		cCellValue := oCell:string
		msgDebug(nCol, nCellValue, cCellValue)
	next
	//msginfo ("Ready Exit Open Office",)
	oDocument:Close( .T. )
return
You need to create workseet test.ods
I hope it will give you an idea how to continue your work!
wolfgang.schwarz
That's exactly what I was looking for. But in Excel (2007) also works a CSV file without problems. In the Open Office the text import window with the separation option tab,;; Blank. What I found so far does not want to translate into harbor. The text file is with; separated and writes everything in column A. I now try the CSV data with Fopen and Freadstr read and prepare. But the previous path was better in my program. Thanks for your help
nekbmm
DBs Used: DBF,SQLite
Post by nekbmm »
How to open an excel file to not be raedonly the data input attributes ?
oBook := oDesktop:loadComponentFromURL( "file:///"+cDir+"\Poreska_prijava_pdv.xls", "_blank",0, {} )
oSheet := oBook:getSheets():getByIndex(0)
oSheet:getCellRangeByName( "B10" ):SetString('U PERIODU OD: '+ Dtoc(Datup1) + ' DO: '+ Dtoc(Datup2))
etc...
Thanks.
