Enhanced Rich Edit Demo
kcarmody
Post by kcarmody »
I've overhauled and enhanced the Rich Edit demo and put it on my web site at http://kevincarmody.com/hmg/SAMPLES/Con ... chEditBox/.
This version uses the justify fix and GetFile/PutFile enhancements that I posted before. See http://www.hmgforum.comviewtopic.php?f=20&t=3995 and viewtopic.php?f=8&t=4009.
This version includes several other enhancements:
  • * Main menu
    * List of recently used files
    * Resizable windows
    * Ctrl-B, Ctrl-I, Ctrl-U supported
    * File name in title, file name and page in status bar
    * Modified flag, caps lock, num lock, insert status on status bar
    * Window size, font name and size, recently used file names stored in registry
    * Paragraph numbering
    * Read and write text files, including workarounds for Unicode text files
    * Other enhancements
The handling of Unicode text files is an issue that I will bring up in another topic.
Kevin
Re: Enhanced Rich Edit Demo
WOW!
Great job, Kevin.
Thanks for sharing!
You should pack all files into one archive before share it.
It's hard to download every resource file one by one.
kcarmody
Post by kcarmody »
Mol, thanks for reminding me about this. I've made a zip file in http://kevincarmody.com/hmg/SAMPLES/Con ... chEditBox/ with the whole demo. Remember to also download the justify and dialog enhancements and rebuild the HMG library. The question about Unicode text files is in viewtopic.php?f=8&t=4031.
Thank you Mr. Kevin
mol wrote:WOW!
Great job, Kevin.
Thanks for sharing!
Sorry, I have no experience with Unicode :-(
Hola Kevin,
Quise compilar tu demo y me sale el siguiente error:
Harbour 3.2.0dev (r1407111333)
Copyright (c) 1999-2014, http://harbour-project.org/
C:/Users/Maquina9/AppData/Local/Temp/hbmk_28a2lo.dir/demo.o:demo.c:(.data+0x778): undefined reference to `HB_FUN_HMG_ISNOTDEFPARAM'
hbmk2[demo]: Error: Ejecutando enlazador. 1
gcc.exe C:/Users/Maquina9/AppData/Local/Temp/hbmk_28a2lo.dir/demo.o C:/Users/Maquina9/AppData/Local/Temp/hbmk_28a2lo.dir/hbmk_41jxts.o C:/hmg.3.3.1/Mios/DemoRichEditBox/_temp.o -Wl,--nxcompat -Wl,--dynamicbase -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -odemo.exe -LC:/hmg.3.3.1/harbour/lib/win/mingw -LC:/hmg.3.3.1/lib
hbmk2: Error: Funci¢n(es) referenciada, no encontrada, pero desconocida:
HMG_ISNOTDEFPARAM()
Sabes a que se refiere ese error al compilar?
Thanks Kevin !
I will give a try as soon as I wiil be at home.
kcarmody wrote:I've overhauled and enhanced the Rich Edit demo...
Thanks Mr. Carmody, tried, no problem, everything is fine :arrow:
May (or may not) a bit think on About page :?
Javier Towar wrote:Quise compilar tu demo y me sale el siguiente error:
Hi boy !
You need learn : real programmers never send anything without adequate tested ;)
Hi boy !
Pues tienes razón en que necesito aprender y mucho, y por eso pregunto, ya que mi conocimiento es escaso y no puedo resolver este problema de compilación, ES AQUÍ EL LUGAR PARA APRENDER O SOLO ES PARA LOS QUE SABEN??? SR. ESGICI???
