Continuando a ideia de DSQLite, onde podemos executar automaticamente a criação, navegação e formulários a partir do desenho do banco de dados, só que agora em MYSQL.
Este projeto foi desenvolvido em HMG 3.1.5 e também precisa da libmysql.dll.
Foi testado com MySql do Wamp Server e também em MySQL instalado em Linux Ubuntu e Linux Mint.
Espero em breve ter uma versão mais amigável e totalmente orientada a objetos.
Sugestôes e críticas são bem vindas.
Continuing the idea DSQLite, which can automatically perform the creation, navigation and forms from the design of the database, only now in MYSQL.
This project was developed in HMG 3.1.5 and also need the libmysql.dll.
Was tested with the Wamp Server and MySql also installed MySQL on Linux Ubuntu and Linux Mint.
I hope to soon have a more friendly and fully object-oriented.
Comments and criticisms are welcome.
DMySQL
- Amarante
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL
DMySQL
- DMySQL.rar
- (1.86 MiB) Downloaded 802 times
Re: DMySQL
Thank you. It will be a wonderful project.
I am using MariaDB in replacement of MySQL. So, it works for MariaDB too.
Re: DMySQL
And, if you use HMGSQL library, it can be extended to PostgreSQL also.
- Amarante
Re: DMySQL
Good News, the goal is to build a function that uses any database, simply informs the type: Mysql, Oracle ... etc.Rathinagiri wrote:And, if you use HMGSQL library, it can be extended to PostgreSQL also.
Re: DMySQL
Is there any installation require for MariaDBAmarante wrote:Good News, the goal is to build a function that uses any database, simply informs the type: Mysql, Oracle ... etc.Rathinagiri wrote:And, if you use HMGSQL library, it can be extended to PostgreSQL also.
Any working example for porting from dbf to MariaDB
Re: DMySQL
Thank AmaranteAmarante wrote: Continuing the idea DSQLite, which can automatically perform the creation, navigation and forms from the design of the database, only now in MYSQL.
Viva HMG
