OrdScope help
fouednoomen
OrdScope help
Post by fouednoomen »
Dear All ,
How can I replace this function by OrdScope function
set filter to facture->cod_cli=client->cod_cli .and. facture->mont_fac-facture->avance >0
for information the index file is build as the following
use facture
Index on cod_cli+str(mont_fac-avance) tag xsolde to facture
I try this code but it dos not work
sele facture
SET ORDER TO 1
OrdScope(0,(client->cod_cli+'1'))
OrdScope(1,(client->cod_cli+'99999'))
dbgotop()
foued
Re: OrdScope help
Hi Foued :
I use this way ORDSCOPE .
Procedure Vencimientosordenar()
cKey  := ""
cKey2 := ""
 ORDSCOPE( TOPSCOPE    , NIL )
 ORDSCOPE( BOTTOMSCOPE , NIL )
 cKey  := DTOS( Vencimientos.FECHA1.value)
 cKey2 := DTOS( Vencimientos.FECHA2.value)
 dbgotop()  // move the record pointer for the filter to take effect
 ordscope(TOPSCOPE   , "&cKey"  )  // set top scope
 ordscope(BOTTOMSCOPE, "&cKey2" )  // set bottom scope
 Vencimientos.grid_1.refresh
Re: OrdScope help
fouednoomen wrote:...
use facture
sele facture
SET ORDER TO 1
dbgotop()
Hi Foued
Using STR() without length (second) parameter, may cause some problems while building an index key and keys of an index should be same length.
So something like this may help you :
nLengthOfMFacAv := 5
use facture
Index on cod_cli+str(mont_fac-avance,nLengthOfMFacAv) tag xsolde to facture
sele facture
SET ORDER TO 1
OrdScope(0,(client->cod_cli+PADL( '1', nLengthOfMFacAv ) )) // or SPACE(4) + "1"
dbgotop()
And, if we have some sample data for your tables helping you may be more easy.
fouednoomen
Re: OrdScope help
Hi Esgici
Many thanks for your prompt replay
I look for this solution from 3 days
Foued
dhaine_adp
Re: OrdScope help
Post by dhaine_adp »
Hi Foued,
You can also used these commands:
USE EMPLOYEE ALIAS EMPLOYEE NEW VIA RDDSETDEFAULT()
INDEX ON ID Tag ID TO Employee
INDEX ON DOB Tag DOB TO Employee
// At later part or another module of your code you can for example:
USE EMPLOYEE ALIAS EMPLYEE NEW
ORDLISTADD( "Employee" )
ORDSETFOCUS( "ID", "Employee")
To adopt your code you should do:
use facture
** declare these variables below at the top of your function
PRIVATE cTopBound
PRIVATE cLowBound
sele facture
SET ORDER TO 1
cTopBound := client->cod_cli + "1"
cLowBound := client->cod_cli + '99999'
OrdScope(0, "&cTopBound" )
OrdScope(1, "&cLowBound" )
dbgotop()
Danny
Danny
Manila, Philippines
