FIF : File(s) into File
Hi
An experimental work to store content of any file to a single file, a table ( .dbf ) (host).
Look at "WhatIsFIF.txt" file or Help\About menu item for details.
Screen shoot :
FIF at work
FIF at work
Source files :
FIF_Src.zip
FIF source files
(66.02 KiB) Downloaded 831 times
Alternative link : https://docs.google.com/file/d/0B0M_tmW ... sp=sharing
Executable :
PS: This post is a kind of continuation of that post : viewtopic.php?f=5&t=2679
Re: FIF : File(s) into File
Looks very interesting.
Muy buena idea Esgici. gracias por compartir
Very good idea Esgici. thanks for sharing
Thank you for sharing, Good
Thanks!
Very interesting.
I'm looking for a solution for automatic update of an HMG application used remotely (via NETIO).
Maybe FIF be part of the solution.
Had you tested with NETIO?
TIA.
Thanks friends :)
Please guide me to learn using NETIO by shortest way :?
esgici wrote:Thanks friends :)
In the samples folder you'll find NETIO.01 and NETIO.02 folders with samples.
Or, you can download harbour nigthly and look at /contrib/hbnetio folder.
Thanks
I'll look.
Congratulations amigo Esgici ! Pretty nice and usefull.
Tahnk you once again for sharing with us !
Czarny_Pijar
Post by Czarny_Pijar »
Impressive, really. However...
On the top of my wishlist are the additional filtering capabilities.
In my imagination it should be 3 ComboSearchBoxes based on 3 lists.
Suppose the lists are:
1st_list.lst {2010,2011,2012}
2nd_list.lst {forest, meadow,swamp}
3rd_list.lst {birds,flowers}
So I could filtrate the photos of forest birds taken in 2011.
The working example of ComboSearchBox (based on the lists), can be found in the the valuable contribution of Dr. Claudio Soto, located in c:\hmg\hfcl\Samples\ComboSearchBox
-------edit:
Although this way is not recommended in the world of relational databases, however this manner could keep the things simple:
1) no additional database for the tags, simply the 3 new fields in the existing one,
2) no additional browse/grid for the tags manipulation (Notepad is enough).
Anyway, the choice is yours.
