Paint Background in Frame Control
Hi all.
Since of the frame control is a transparent window is easy to put a background, painting directly on the client area with ON PAINT event.
I hope you find it useful.
Claudio
* PROGRAMA:  Paint Background in Frame Control
* LENGUAJE:  HMG 3.0.43
* FECHA:     1 Setiembre 2012
* AUTOR:     Dr. CLAUDIO SOTO
* PAIS:      URUGUAY
* E-MAIL:    srvet@adinet.com.uy
* BLOG:      http://srvet.blogspot.com
PRIVATE RGB_Color := BLUE
    DEFINE WINDOW Win1 ;
        WIDTH 800 ;
        HEIGHT 600 ;
        TITLE "Paint Background in Frame Control";
        MAIN;
		  ON PAINT Paint_Background_Frame()
        DEFINE MAIN MENU
            DEFINE POPUP "Change Color"
                  MENUITEM "BLUE"  ACTION {|| RGB_Color := BLUE,          Paint_Background_Frame()}
                  MENUITEM "RED"   ACTION {|| RGB_Color := RED,           Paint_Background_Frame()}
                  MENUITEM "BLACK" ACTION {|| RGB_Color := BLACK,         Paint_Background_Frame()}
                  MENUITEM "USER"  ACTION {|| RGB_Color := {250,100,23},  Paint_Background_Frame() }
            END POPUP
        END MENU
        @  10,100 FRAME frame_1 CAPTION "Frame 1" WIDTH 500 HEIGHT 200 FONT "Times New Roman" SIZE 14 BOLD ITALIC UNDERLINE BACKCOLOR RED FONTCOLOR GREEN
        @ 150,150 BUTTON button_1 CAPTION "Click 1" ACTION MsgInfo ("Frame 1")
        @  50,150 LABEL  label_1 VALUE "Hello HMG World" FONT "Times New Roman" SIZE 14 BOLD  TRANSPARENT
        @ 300,100 FRAME frame_2 CAPTION "Frame 2" WIDTH 500 HEIGHT 200 FONT "ARIAL" SIZE 14 BOLD ITALIC UNDERLINE
        @ 350,150 BUTTON button_2 CAPTION "Click 2" ACTION MsgInfo ("Frame 2")
	CENTER WINDOW Win1
	ACTIVATE WINDOW Win1
Procedure Paint_Background_Frame
  #define OFFSET_INI  10
  #define ROUND_WIDTH  5
  #define ROUND_HEIGHT 5
  FILL_FRAME (GetFormHandle("Win1"),;
              win1.frame_1.ROW + OFFSET_INI,;
              win1.frame_1.COL,;
              win1.frame_1.WIDTH,;
              win1.frame_1.HEIGHT - OFFSET_INI,;
			     RGB_Color,;
              ROUND_WIDTH, ROUND_HEIGHT)
  InvalidateRect (GetFormHandle("Win1"), NIL ,.F.)   // Invalidate all client area
*   FUNCIONES EN C
#pragma begindump
#include <windows.h>
#include "hbapi.h"
// *  FILL_FRAME ( hWnd , y, x, w, h,  {R,G,B}, Round_WIDTH, Round_HEIGHT)
HB_FUNC (FILL_FRAME)
   HWND hWnd;
   HDC hDC;
   RECT rect;
   POINT round;
   HBRUSH hBrush;
   INT R,G,B;
   PHB_ITEM pArrayRect;
   hWnd        = (HWND)    hb_parnl (1);
   rect.top    = hb_parnl (2);
   rect.left   = hb_parnl (3);
   rect.right  = rect.left + hb_parnl (4);
   rect.bottom = rect.top  + hb_parnl (5);
   if (HB_ISARRAY (6))
      pArrayRect = hb_param (6, HB_IT_ARRAY);
      R = hb_arrayGetNI (pArrayRect, 1);
      G = hb_arrayGetNI (pArrayRect, 2);
      B = hb_arrayGetNI (pArrayRect, 3);
      round.x  = hb_parnl (7);
      round.y  = hb_parnl (8);
      hDC = GetDC (hWnd);
      hBrush = CreateSolidBrush (RGB (R,G,B));
      SelectObject (hDC, hBrush);
      DPtoLP (hDC, (LPPOINT) &rect,  2);
      DPtoLP (hDC, (LPPOINT) &round, 1);
      RoundRect(hDC, (int)rect.left, (int)rect.top, (int)rect.right, (int)rect.bottom, (int)round.x, (int)round.y);
      DeleteObject (hBrush);
      ReleaseDC(hWnd, hDC);
#pragma enddump
Re: Paint Background in Frame Control
Thanks a lot Claudio. This will be very useful.
Gracias Dr.
Saludos cordiales :)
chrisjx2002
Post by chrisjx2002 »
Hello,
Thanks for this nice new feature.
I compiled this program but I got an error : undefined reference HB_FUN_INVALIDATERECT
I miss something but what? :(
chrisjx2002
Sorry... It is solved. I used the old 3.0.41 HMG version.
Thanks Rathi, Esgici and Chrisjx2002.
Claudio.
Hola Claudio :
Gracias por el aporte.
A veces es necesario tener o colocar un Frame dentro de la aplicación y aplicar un color apenas un poco diferente, de esa forma magnificar el area de ingreso de datos y resaltar area de información.
otra seria que el Frame se pudiera cambiar solo el color del marco, ya que el Control solo permite cambiar el Font. o color del Caption pero no el color del marco en si.
Hola Claudio :
encontre algunas dificultades en implementar ON PAINT con pintar el control FRAME.
DEFINE WINDOW Stock ;
              AT 5 ,5 ;
              WIDTH 1020 HEIGHT 710 ;
              TITLE "Stock Autoservicio Los Tilos" ;
              ICON 'Carritos';
              NOMAXIMIZE NOSIZE ;
              ON INIT  Stock.Text_8.Setfocus;
	      ON PAINT  Paint_Background_Window()
	      ON KEY ESCAPE ACTION {|| lDeleteallItems := .T. , ThisWindow.Release }
  For nFrame := 1 to 6
  cFrame:= 'Frame_'+alltrim(str(nFrame))
  FILL_FRAME (GetFormHandle("Stock")             ,;
              Stock.&(cFrame).ROW + OFFSET_INI   ,;
              Stock.&(cFrame).COL                ,;
              Stock.&(cFrame).WIDTH              ,;
              Stock.&(cFrame).HEIGHT - OFFSET_INI,;
              {153,255,204}                      ,;
              ROUND_WIDTH                        ,;
              ROUND_HEIGHT)
              msgbox('Pintando Frame:' + alltrim( str( nFrame ) ) )
   Next
  InvalidateRect (GetFormHandle("Stock"), NIL ,.F.)   // Invalidate all client area
intente usar text_8 para recibir el foco despues del inicio, pintar los FRAME y despues enviar el FOCO hacia el TEXt_1 que es la entrada de datos.
veia que no pintaba en control FRAME, asi que pude un mensaje en dicho Procediento y si pintaba. pero el Activarse la ventana asumia el pintado de la ventana pero no de los controles FRAME.
frame 1.jpg (131.45 KiB) Viewed 7390 times
vemos que se pintan los 6 FRAME, el principal y los otros que contienen los refreridos TEXT_x
pero al activarse , no se ven pintados los FRAME.
Hola Daniel.
Estuve haciendo varias pruebas con un frame adentro de otro y con varios controles adentro y no medió ningún problema.
Me podrías enviar a srvet@adinet.com.uy el trozo de código que la definición de la ventana "Stock" y contiene los frame y los controles que tienen adentro, adjuntame la/las imágenes que aparecen adentro del frame, así lo puedo estudiar mejor a simple vista no me doy cuenta porque no funciona.
¿Si eliminas el ON INIT funciona?
Saludos,
Claudio.
Hola Claudio :
Jugando un poco con lo numeros que controlan el 'Pintado' del Control FRAME llegue a 'mas o menos' que quede
como queria , como decia en uno de los POST anteriores (mas arriba) el control FRAME se pierde en un tipo de color, en mi caso RGB 204,255,204
para corregir ese problema use este metodo.
  #define OFFSET_INI   6
  #define ROUND_WIDTH  6
  #define ROUND_HEIGHT 6
   cFrame:= 'Frame_1'
              Stock.&(cFrame).ROW + 2            ,;
              Stock.&(cFrame).HEIGHT             ,;
              {204,255,204}                      ,;
              ROUND_WIDTH                        ,;
              ROUND_HEIGHT)
  cFrame:= 'Frame_2'
              Stock.&(cFrame).ROW + 5            ,;
              Stock.&(cFrame).COL  + 2           ,;
              Stock.&(cFrame).WIDTH -4           ,;
              Stock.&(cFrame).HEIGHT - 8         ,;
              {204,255,204}                      ,;
              ROUND_WIDTH                        ,;
              ROUND_HEIGHT)
  For nFrame := 3 to 7
              Stock.&(cFrame).ROW  +8            ,;
              Stock.&(cFrame).HEIGHT  -8          ,;
              {153,255,204}                      ,;
              ROUND_WIDTH                        ,;
              ROUND_HEIGHT)
   Next
Stock Autoservicio.jpg (165.42 KiB) Viewed 7315 times
Gracias por tu tiempo y dedicación.
