A few days ago, I reread a document that talked about the Class(Y) and for this reason I decided to write this post.
I'm not a guru (these days MrDuck is trying to open my mind to the secrets of HbQt, but he spend a lot of energy with me
From Class(Y) documents:
"What is an Object?
One of the fundamental reasons that object orientation is enjoying such success as a programming paradigm is very simple: the real world is made up of objects....
Classes, Instances and Instance Variables...
A class can be thought of as a template, or specification, for creating an object...
To look at it another way, we can define an object as an instance of a class...", etc. etc.
For a lot of time I use PUBLIC array and FUNCTION to store and retrieve informations to use inside projects, but for a long time, I had the desire to use a syntax like this "LOCAL VarName := PublicVarName:othervar:something".
Some times ago, I rewrite my library and I used object and class.
This (for me) it was a good idea, because I could not avoid some annoying problems during testing of the HMG4 library and I think will help me when I will convert programs.
That's all folk. I leave you to read my source code: it's a derived version of my job. Work fine with HMG3 and HMG4 (the latest example is the goal I wanted to reach). Enjoy with this idea.
Cheers
