Lib Calc
Lib Calc
Hello my friends,
Well, some time later... I create a calculator that can be added into my aplications with HMG. This calc can return the value of operation and/or return the same value to Clipboard.
For me it is very useful, i hope that be for you too.
The original source, was of Marcos Antonio Gambeta. I get it your sample and did a lot of new little functions, and update this for my needs.
In fisrt file "Calc Lib.RAR" you will find the source for recompile and create your lib. You can add the file "Calc.PRG" in you HMG project, if you not want use a lib for that.
In file "Calc.Rar", have a little project with HMG IDE for show this.
My best regards,
PS: Sorry my bad english
My best regards,
- Calc Lib.rar
- Source code, for create your lib
- (3.85 KiB) Downloaded 766 times
- Calc.rar
- Sample for ShowCalc() function
- (584.73 KiB) Downloaded 980 times
Re: Lib Calc
Super! Thanks Vanguarda.
- danielcrocciari
- DBs Used: DBF, MySQL, SQLite
Re: Lib Calc
Muito boa esta LIB.
Daniel Crocciari
Brasil - Japan
Projetos HMGLights
HMGLights Site
Canal do YouTube
http://www.youtube.com/hmglights
Céu Azul Tecnologia & Software
http://www.ceuazul.net
Brasil - Japan
Projetos HMGLights
HMGLights Site
Canal do YouTube
Re: Lib Calc
Great Vanguarda! Thanks for sharing!!
It can turn out to be handy tool for our applications.
BTW, we are having one special thread where we are uploading our UDFs, this routine should be incorporated there also for future reference.
Swapan
Swapan
Re: Lib Calc
Super work! You saved a lot of my time! I've got such a calculator in my old dos programs, but no time to move it to windows. Now, it's ready. Best regards,
Marek
Marek
Re: Lib Calc
Hi all,
Thanks all friends for your kind words.
I´m so glad for this lib be usefull for you as was useful for me.
My best regards,
My best regards,
- mustafa
Re: Lib Calc
Hello Vanguarda
The calculator we needed to put in the applications
you report a mistake that I detected in the MC Button pointing
I think this part of source code.
// This function clean the variable used for add value into memory
Static Function CancelMemo_Click
nMemo := 0
SetProperty("Form1","btnMS","FontBold",.F.)
Calc.ReadHide.SetFocus()
Also if you followed keyboard operations ie without
do it for the mouse all buttons work but want ciando
make no pretense mutiplicación this keyboard is
example 10 * 5 + = 10 when 50 would give
Hola Vanguarda
La calculadora nos hacia falta para poner en la aplicaciones
te reporto un error que he detectado en el Boton MC que apunta
yo creo a esta parte de codigo fuente.
Tambien si haces operaciones por teclado seguidas es decir sin
hacerlo por el raton todas las teclas funcionan pero ciando quieres
hacer una mutiplicación esta no finciona por teclado es decir
ejemplo 10 * 5 + = 10 cuando tendria de dar 50
Un cordial saludo
nMemo := 0
Hola Vanguarda
Un cordial saludo
- error.jpg (64.7 KiB) Viewed 8286 times
Re: Lib Calc
You all right my friend Mustafa.
It is my mistake, please so kind, make download of the new version in bellow, and recompile the library.
Thanks for the info.
My best regards
My best regards
- Calc Lib.rar
- (3.85 KiB) Downloaded 650 times
- mustafa
Re: Lib Calc
Hello friend Vanguarda
I too have made the correction in
this piece from the list changing "Form_1" by
"Calc" and seems to work.
nMemo := 0
SetProperty("Calc","btnMS","FontBold",.F.) // Error -- > Form1
I have made an example to get the Calculator
simply from a menu.
Hola amigo Vanguarda
Yo tambien he efectuado la correccion en
este trozo del listado cambiando "Form_1" por
"Calc" y parece que funciona.
He efectuado un ejemplo para llamar la Calculadora
sencillamente desde un menu.
Un cordial saludo
nMemo := 0
simply from a menu.
Un cordial saludo
- Calc.zip
- (698.75 KiB) Downloaded 628 times
- Alex Gustow
Re: Lib Calc
Hi Vanguarda! Thanks for very good and useful thing!
