Page 6 of 6
Re: ComboSearchGrid
Posted: Mon Feb 11, 2019 1:08 pm
by EduardoLuis
Hola Andy
Lindo ejemplo.
Prodrias publicar el codigo ??
Gracias por compartir
Como realizaste el gif ?? muy interesante y util.-
Eduardo
Hi Andy:
Nice sample
Could you post the code ??
Thanks for share.
How do you produce the gif ?? Very interest and usefull.
With regards
Eduardo
Re: ComboSearchGrid
Posted: Mon Feb 11, 2019 6:30 pm
by andyglezl
Aquí el link del programa que utilizo para los gif.
Here the link of the program that I use for gifs.
https://www.screentogif.com
El código de la busqueda aún está en desarrollo por la necesidad de un cliente
The search code is still under development due to the need of a client.
Re: ComboSearchGrid
Posted: Tue Feb 12, 2019 8:30 pm
by EduardoLuis
Hi Andy:
Thanks for the link
About the code, my request was about the basic routine you perform combining two way of search, looks very usefull, positioning the found item on listbox.-
With regards.
Eduardo
Re: ComboSearchGrid
Posted: Tue Feb 12, 2019 9:07 pm
by andyglezl
OK, Practicamente todo se reduce a esto.
OK, practically everything comes down to this.
Ctes->( DBSetOrder(1) )
cCod := GetProperty( cWind, "TB_Codigo", "Value" )
IF Ctes->( DBSeek( GetProperty( cWind, "TB_Codigo", "Value" ), .T. ) )
cNom := UPPER( ALLTRIM( Ctes->NOMBRE ) )
SetProperty( cWind, "TB_Nombre", "Value", ALLTRIM( Ctes->NOMBRE ) + " " + ALLTRIM( Ctes->APELLIDOS ) )
Ctes->( DBGOTOP() )
DoMethod( cWind, "CB_1", "DeleteAllItems" )
DO WHILE Ctes->( OrdWildSeek( "*" + cCod + "*", .T. ) )
DoMethod( cWind, "CB_1", "AddItem", Ctes->CODIGO +" - " + ALLTRIM( Ctes->NOMBRE ) + " " + ALLTRIM( Ctes->APELLIDOS ) )
ENDDO
Ctes->( DBSetOrder(2) )
Ctes->( DBGOTOP() )
DoMethod( cWind, "CB_2", "DeleteAllItems" )
DO WHILE Ctes->( OrdWildSeek( "*" + cNom + "*", .T. ) )
DoMethod( cWind, "CB_2", "AddItem", Ctes->CODIGO +" - " + ALLTRIM( Ctes->NOMBRE ) + " " + ALLTRIM( Ctes->APELLIDOS ) )
ENDDO
SetProperty( cWind, 'L_Warning', "Value", 'Cliente no encontrado !' )
Re: ComboSearchGrid
Posted: Tue Feb 12, 2019 9:53 pm
by EduardoLuis
Hi Andy:
Thanks. Simple and effectiv.-
Eduardo
Hola Andy:
Gracias. Simple y efectivo
Eduardo
Re: ComboSearchGrid
Posted: Fri Feb 15, 2019 10:01 am
by tonton2
andyglezl wrote: ↑Tue Feb 12, 2019 9:07 pm
Ctes->( DBGOTOP() )
ENDDO
Ctes->( DBGOTOP() )
ENDDO
Bonjour,
Peut on avoir un exemple complet,merci a vous
can you put a sample, thank you
Re: ComboSearchGrid
Posted: Tue Feb 19, 2019 3:50 pm
by jairpinho
Rathinagiri wrote: ↑Wed Apr 24, 2013 4:56 pm
Here I am sharing my experimentation for multi-column combosearchgrid based on Esgici's ComboSearchBox. I was very much longing for a control like in MS Access with multi-column combobox. Now it is possible.
Features of ComboSearchGrid:
- I have used SQLite temporary database and table to optimize the search
- Since the combosearchgrid is based on Virtual Grid there is no limitation as to the number of rows! In the sample I have used 10000 rows. But you can check for more rows and find out how fast it is. Actually there is no program degradation because of the number of rows.
- The text is searched in all the columns.
- Anywhere search is also available
- You can show/hide the headers too.
- SQLite operations are totally hidden and you need not know anything about SQLite.
Please give your suggestions, we can make a better control!
combosearchgrid.zip
Hello Rathi, this is a fantastic function, just missing an example with mysql.
