Digital Image Processing
Re: Digital Image Processing
franco wrote: Thu Jan 21, 2021 1:03 am Amazing Andy,
Do you think I could take a 2249 kb jpg and resize to 200 kb and still be clear inside hmg this way to redo my internal camera files before
copying and saving them.
mmm...
Bueno, hice una prueba cargando una imagen de 2,143 KB y la salve con este programa y quedó de 565 KB y me parece buena la resolución.
Pero depende que signifique "buena resolución" para cada uno y el fin que le dará a estás imagenes.
mmm ...
Well, I did a test loading a 2,143 KB image and I saved it with this program and it was 565 KB and the resolution seems good.
But it depends on what "good resolution" means for each one and the purpose that it will give to these images.
franco wrote: Thu Jan 21, 2021 1:03 am Do you think I could take a 2249 kb jpg and resize to 200 kb and still be clear inside hmg this way to redo my internal camera files before copying and saving them.
i wonder why you work with CAM instead of Scanner while a CAM have "too much Color"
if you have a Document you need only Black/White so Size of Image is much smaller when compress using JPG.
franco
Post by franco »
I need to take pictures with the camera of a Microsoft go 2 tablet.
The electric motor rewind technicians use the tablets to take pictures of different parts of motors while they rebuild.
They just want to hold tablet and take picture nothing else.
I am waiting for sample picture to post to see if a member (Andy) could show me how to resize with a function inside my program after taking picture.
All The Best,
Franco
Canada
the simplest way is to create control IMAGE of requested size, display your picture in this control and save window to a file.
It should be very easy to realize
this is piece of code of Jimmy AUHE_OHR
   Row    := 0
   Col    := 0
   Width  := BT_ClientAreaWidth("Form_1")
   Height := BT_ClientAreaHeight("Form_1")
   hBitmap := BT_BitmapCaptureClientArea ("Form_1", Row, Col, Width, Height)
   BT_BitmapSaveFile (hBitmap, cFileName, nTypePicture)
   BT_BitmapRelease (hBitmap)
look at this topic: viewtopic.php?f=5&t=6744&p=64793&hilit= ... ile#p64793
WOW !
Realmente me sorprendo de lo que podemos plasmar con nuestra imaginación
Wow
I am really surprised at what we can capture with our imagination
The attachment ChicaMarYTorre.jpg is no longer available
Pude utilizar una Tableta y un Lápiz !!! (Solo instalandolo)
I was able to use a Tablet and a Pencil !!! (Just installing it)
franco
Post by franco »
Holy Cow and WOW,
Thanks to
Andres, Jimmy an Mol
I have this working in a small program. I have shrunk a 3.2mg picture to 652kb. and it is 100% clear for what I need.
I used Mol`s suggestion designed by Jimmy
Amazing and thanks again.
All The Best,
Franco
Canada
La práctica hace al maestro... ;)
Practice makes a master... ;)
TUTORIAL
Tutorial01.zip
(231.43 KiB) Downloaded 126 times
Descarga el programa desde aquí :)
Download the program from here :)
https://www.hmgforum.com/download/file.php?id=10381
Que lo disfruten !!!
Enjoy it !!!
Tutorial02
Tutorial03
"Save as..." next images.
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Mis más sinceras felicitaciones Andy !!!
