Set Date and Time to Operacional System
IMATECH
Re: Set Date and Time to Operacional System
Post by IMATECH »
Hi brain !
Thanks for report :)
I Have Tryed with your sample: But my result is correct: Just one month added
DTOS( F_RM_Push_Date( STOD( '20120131' ), 0, 1, 0 ) )
RESULT := '20120229'
DTOS( F_RM_Push_Date( STOD( '20121231' ), 0, 1, 0 ) )
RESULT := '20130131'
I have maked some changes in the function to be safe from locale date settings ;)
May solve this error (new code edited in my last message : before this post)...
Best regards...
Just Testing...
Just Testing...
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH
Post by IMATECH »
Hi brain !
Thanks again for report :)
Tnx for your immediate response. Yeah! that output is right. I rechecked it again. It was my fault. How about this one.
F_Push_Date( CTOD('01/30/2012'), 0, 1, 0 ) => Result 03/01/2012 instead of 02/29/2012
F_Push_Date( CTOD('01/30/2012'), 0, 1, 0 ) => Result 03/02/2012 instead of 02/29/2012
Tnx a lot again.
Tested: and found no any problem...
F_RM_Push_Date( STOD( '20120130' ), 0, 1, 0 ) == STOD( '20120229' )
But I have a new release for function: Check if initial date have the Last Day of the month...
Function Updated Again...
Less code... better use...
Thank's for reporting possible error's
M., Ronaldo
By: IMATECH
Imation Tecnologia
brain
Post by brain »
Good day. Is there anyone of you can share how to change date and time by using
CallDll32() functions? Tnx and more power.
CallDll32('SetSystemTime', 'Kernel32.dll') what will the syntax for this function? tnx
